Old Sep 17, 2012, 11:12 PM
Piece is online now
Find More Posts by Piece
Wake up, feel pulse, be happy!
Piece's Avatar
Joined Aug 2009
The Slow Stick flies much, much better if you trim those droops off the tips at the first rib. I know that's probably an older video and you'e probably aware of that mod by now, but it's still worth mentioning.
It becomes even more fun when you can backflip it (not loop, BACKFLIP) in its own length.
Piece is online now Find More Posts by Piece
Old Sep 19, 2012, 10:52 AM
jsipprell is offline
Find More Posts by jsipprell
Joined Jul 2011
Originally Posted by jasmine2501 View Post
Yeah lateral G-forces throwing your body out the windows. In a regular plane, we "center the ball" by using rudder and ailerons together, so that the passengers don't feel the rocking. If done correctly and with no visual reference point, you can do it such that the passengers don't even know you made a turn.
It's common knowledge, but I've never understood that. Even with a perfectly coordinated bank I can still feel the initial rotation and final rollout due to inertia. It's a very mild sensation, but I figure if I can feel it so can everyone else.
jsipprell is offline Find More Posts by jsipprell
Old Sep 20, 2012, 07:21 PM
alibongo is offline
Find More Posts by alibongo
alibongo's Avatar
United Kingdom, England, Dorset
Joined Apr 2010
Originally Posted by stuball56 View Post
I am learning, so far only on RF. I have built a Polaris, but am getting a trainer first. So why are there trainers with 3 channels? Rudder and elevator only, no ailerons? Seems like if you trained and learned on a 3 channel, then when you go to 4 you wont have a clue on how to control the aircraft using ailerons. I just think for me, anyway, it is far better to have a trainer that is a full 4 channels. I am torn between the Flyzone Switch or the Nexstar Mini EP. Both have thier advantages and disadvantages. I really like both actualy.
Why do professional full-size pilots start with piston-engine planes, then jet trainers, then obsolete jet fighters before they climb aboard the Eurofighter or an F16?Do you think it is because their mentors feel they need education in the history of aviation?Or do you think it might just be that they need to progress their skills through more and more demanding aircraft? Tricky question, isn't it?
alibongo is offline Find More Posts by alibongo
Old Sep 20, 2012, 08:08 PM
cold wombat is offline
Find More Posts by cold wombat
cold wombat's Avatar
Australia, WA, Perth
Joined Jul 2011
Time to watch the show. Again.
<Pulls up deck chair. Cracks open tinny.>
Carry on gents, I'm ready now.
cold wombat is offline Find More Posts by cold wombat
Old Sep 21, 2012, 01:48 AM
Rockin Robbins is offline
Find More Posts by Rockin Robbins
Drone offender FA377YHFNC
United States, FL, DeLand
Joined Mar 2009
I'll help you do one of those tinnies there, mate! We can do a little tinny formation flying.
Rockin Robbins is offline Find More Posts by Rockin Robbins
Old Sep 21, 2012, 02:30 AM
Joined Jul 2011
<Reaches into esky, passes Flying Dog brew to RR>
Anyone else up for the show?
Old Sep 21, 2012, 11:16 AM
jasmine2501 is offline
Find More Posts by jasmine2501
Rocket Programmer
jasmine2501's Avatar
United States, AZ, Mesa
Joined Jul 2007
If it's in a glass bottle, it's not a Tinny, right?
jasmine2501 is offline Find More Posts by jasmine2501
Old Sep 21, 2012, 06:34 PM
Joined Mar 2009
Close enough! Specially for us Yanks.
Old Sep 21, 2012, 09:45 PM
Joined Jul 2011
Pedantry!
Tally ho stuball56 old chap, I believe you've had your cue. On with the show!
Old Oct 01, 2012, 11:01 AM
GerryStarkeson is offline
Find More Posts by GerryStarkeson
Joined Aug 2012
Originally Posted by rtbates View Post
Please do a little research. There's a clue out there IF YOU LOOK...So far you're missing even a hint of a clue, NO offence...
Having tried both, I will prefer ailerons even if there were NO RUDDER AT ALL.
GerryStarkeson is offline Find More Posts by GerryStarkeson
Old Oct 02, 2012, 10:05 AM
Joined Mar 2009
You're an experienced flier. Your observation is disqualified.
Old Oct 05, 2012, 06:29 PM
OkiThumper is offline
Find More Posts by OkiThumper
Closed Account
Joined Feb 2006
I've tried both too; with a little sense of humor, vintage fliers prefer rudder even if there were NO ELEVATOR AT ALL.
OkiThumper is offline Find More Posts by OkiThumper
Old Oct 06, 2012, 08:59 PM
chuck75 is offline
Find More Posts by chuck75
Georgia
Joined Jun 2007
Over thirty years ago, I had the opportunity to "fly" a real F-15 simulator.
Several times, I ended up using the backup "standard" instruments because the heads up display had too much info, and was confusing. The backups told me enough to understand what the heads up was displaying. Glass cockpits are much more common today, down to SEL aircraft.
Each technology builds on the previous one. Needed pilot response time becomes much shorter as you transition from simple to complex to jet.
chuck75 is offline Find More Posts by chuck75
Old Oct 06, 2012, 11:28 PM
Closed Account
Joined Feb 2006
Originally Posted by chuck75 View Post
Over thirty years ago, I had the opportunity to "fly" a real F-15 simulator. Several times, I ended up using the backup "standard" instruments because the heads up display had too much info, and was confusing. The backups told me enough to understand what the heads up was displaying. Glass cockpits are much more common today, down to SEL aircraft. Each technology builds on the previous one. Needed pilot response time becomes much shorter as you transition from simple to complex to jet.
About the same time while at McDonnell Douglas, I had an opportunity at flying a second generation Navy trainer jet simulator. A friend knew one of the engineers in the simulator lab. It was a DEC Vax based simulator, fixed base but had a hydraulic joy stick. If you were nearing a stall, it would shake, wheel hit the runway, it would jerk. After several attempts 2 miles out, I made my first carrier landing.
Since model flying is different than flying the real thing (even real pilots must learn how to fly R/C), I've never bothered comparing model flight to real aircraft experiences.
Old Oct 07, 2012, 10:29 AM
Joined Jul 2011
Originally Posted by Rockin Robbins View Post
Essentially an excellent trainer is a free flight airplane trimmed properly with radio assist. That way you have complete faith that the plane can fly itself and you just help guide it around the sky at first. You're not making it fly.
And, believe it or not, with the more demanding planes that remains true. Free flight is a great way to start learning to fly!
Isn't that really what all fixed-wing flight is? Just guiding the plane around the sky while it flies itself?
For real flying you obviously need a heli.
Discussion Reversing ailerons with dual aileron setup on DX6i ejohn Radios 3 Oct 01, 2012 11:03 AM
Discussion About to put ailerons on my radian. What do I need? (Servos, etc) qwerty11 Electric Plane Talk 10 Jun 05, 2012 10:24 AM
Question Whats up with the 'Q' and 'S' on the Tx Sculptor Beginner Training Area (Heli-Electric) 9 Mar 30, 2012 03:41 PM
Discussion Tuff Trainer in a Tree... Teacher and Dad's Neighbor's Brother Shows up... what a day DJO Electric Plane Talk 19 Mar 14, 2012 06:15 PM
Discussion Help setting up v-tail function with Eclipse 7 - no ailerons robh Hitec/Multiplex USA 5 May 23, 2009 09:56 AM
