Old Sep 07, 2012, 04:36 PM
Logan4169 is offline
Find More Posts by Logan4169
Joined Nov 2011
And if you are getting 50 degrees of crab, you should be flying a kite, not a Cub.
Logan4169 is offline Find More Posts by Logan4169
Old Sep 07, 2012, 04:42 PM
cwolfe is offline
Find More Posts by cwolfe
cwolfe's Avatar
United States, TX, Spring
Joined Aug 2011
Maybe not 50
Ok, there's a 6mph out there this evening. I really wanted to fly my Ultimate and T-34, but I'll break out the Cub and try to get some video
I'm not trying to be a dumas here at all. I've only been flying roughly a year as I said, but I've been in the aviation business for a long time. What I'm doing is not difficult, but YES the plane is traveling sideways.
cwolfe is offline Find More Posts by cwolfe
Old Sep 07, 2012, 04:52 PM
Gerry__ is offline
Find More Posts by Gerry__
Bye Bye VP Aug 2010 - Aug 2012
Gerry__'s Avatar
United Kingdom, London
Joined Jan 2005
Originally Posted by cwolfe View Post
Maybe not 50
Have you understood what I said regards slip and crab. If not, have a search for definitions of these terms on the Internet
Gerry__ is offline Find More Posts by Gerry__
Latest blog entry: Foamie Resurrection
Old Sep 07, 2012, 04:55 PM
jasmine2501 is offline
Find More Posts by jasmine2501
Rocket Programmer
jasmine2501's Avatar
United States, AZ, Mesa
Joined Jul 2007
It doesn't matter... you said it was impossible, therefore it must be done. There is no way around it now, you are going to see the impossible on video.
jasmine2501 is offline Find More Posts by jasmine2501
Joined Nov 2011
Maybe not 50
Yes, at an angle to the flight path over the ground.
Interestingly, the only aircraft that can NOT crab or slip is a balloon. Side slip is a different matter though, and while I agree in principle that 3 ch. birds can't be slipped, the word impossible is truly out of place here.
Old Sep 07, 2012, 04:59 PM
Gerry__ is offline
Gerry__'s Avatar
Joined Jan 2005
I won't see it, but the uploader will. All I will see is a 3ch plane crabbing across the ground due to a side wind component.
No need for anyone to shoot from the hip when places like Wikipedia have all the information needed to understand what's going on.
Old Sep 07, 2012, 05:03 PM
Gerry__ is offline
Gerry__'s Avatar
Joined Jan 2005
Interestingly, the only aircraft that can NOT crab is a balloon. Side slip is a different matter though, and while I agree in principle that 3 ch. birds can't be slipped, the word impossible is truly out of place here.
Ok, I'll grant you that a bent up 3ch plane can side slip, but it want fly straight any more than a straight 3ch plane can side slip.
Old Sep 07, 2012, 05:09 PM
Gerry__ is offline
Gerry__'s Avatar
Joined Jan 2005
Is it possible for 2+2 to equal 5? No, it's not and it's the same with aerodynamic laws.
Old Sep 07, 2012, 05:10 PM
Joined Nov 2011
Right, I was also thinking of the fact then when the rudder is first introduced, the immediate reaction of the aircraft is to slip, which sets up the differences between the wings that result in the roll. Sketchy? Absolutely, but it does make "impossible" an inappropriate word.
Then there is the thrust offset angle, which....
You get the idea.
Old Sep 07, 2012, 05:17 PM
Gerry__ is offline
Gerry__'s Avatar
Joined Jan 2005
You get the idea.
[EDIT in still air or a head/tailwind] Can you fly a 3ch plane along the runway centreline, with the nose pointing in a different direction? No, you can't, not for more than a moment or unless it's all bent up. Is it worth introducing such nebulous examples into these kinds of discussions?
Old Sep 07, 2012, 05:18 PM
Rocket Programmer
Joined Jul 2007
Ah yes, Wikipedia.. well known as a paragon of accuracy
Old Sep 07, 2012, 05:20 PM
Joined Nov 2011
Gerry post 160 is an example of exactly what you CAN do, that is crab. You can not slip!
Old Sep 07, 2012, 05:22 PM
Gerry__ is offline
Gerry__'s Avatar
Joined Jan 2005
Are you saying that the descriptions of these aerodynamic conditions, as explained on Wikipedia, are wrong? The last time I checked them they were bang on.
Old Sep 07, 2012, 05:26 PM
Rocket Programmer
Joined Jul 2007
No i don't recall making any such assertion. Checked the page to be sure too.
Gerry__ is offline
Gerry__'s Avatar
Joined Jan 2005
You know what I meant. You can't fly down the centreline in a crosswind , blah blah blah...heading same as course, blah blah,
Discussion Reversing ailerons with dual aileron setup on DX6i ejohn Radios 3 Oct 01, 2012 11:03 AM
Discussion About to put ailerons on my radian. What do I need? (Servos, etc) qwerty11 Electric Plane Talk 10 Jun 05, 2012 10:24 AM
Question Whats up with the 'Q' and 'S' on the Tx Sculptor Beginner Training Area (Heli-Electric) 9 Mar 30, 2012 03:41 PM
Discussion Tuff Trainer in a Tree... Teacher and Dad's Neighbor's Brother Shows up... what a day DJO Electric Plane Talk 19 Mar 14, 2012 06:15 PM
Discussion Help setting up v-tail function with Eclipse 7 - no ailerons robh Hitec/Multiplex USA 5 May 23, 2009 09:56 AM
