Old Aug 30, 2012, 06:46 PM
Atomic Skull is offline
Find More Posts by Atomic Skull
Atomic Skull's Avatar
Joined Dec 2011
Hobbyking tail rotor shaft 42.8mm - cheap extended tail rotor shaft
Bought a couple of these with my last order because they looked exactly like the "old style" Tarot ones (with a groove instead of a hole, the new Tarot ones now have a hole like the Align ones). Well they do seem to be almost exactly the same as the old Tarot ones except that the shaft is slightly longer meaning you can use these now instead of flipping the grips.
Atomic Skull is offline Find More Posts by Atomic Skull
Old Sep 26, 2012, 10:23 PM
FerretMaster is offline
Find More Posts by FerretMaster
Foam Recycler Par Exalance
FerretMaster's Avatar
United States, AZ, Casa Grande
Joined Dec 2010
Could you post a link to the part?
Sounds like a part I need for my "custom" four blade tail rotor.
FerretMaster is offline Find More Posts by FerretMaster
Old Sep 29, 2012, 02:01 PM
2Doggs is offline
Find More Posts by 2Doggs
Two helis flying
2Doggs's Avatar
North West Louisiana
Joined Nov 2009
http://www.hobbyking.com/hobbyking/s...n_HS1203_.html
The last lot I bought were 43mm long, compared with 41mm for Align sport ones.
2Doggs is offline Find More Posts by 2Doggs
Help! E500 top rotor spinning loosely/extended shaft extraction issue jack 17 Coaxial Helicopters 6 Mar 28, 2012 04:21 PM
Question 3-bladed rotor for 8mm shaft Phoinix Scale Helicopters 1 Apr 19, 2010 12:21 PM
Idea cheap tail rotor shaft aftica Micro Helis 1 Jan 13, 2007 06:55 PM
cheap upgraded shogun tail rotor shaft tabbytabb Mini Helis 0 Jul 23, 2004 01:35 AM
