Old Aug 30, 2012, 06:35 PM
crd is offline
crd
Find More Posts by crd
crd
Always thinkering
crd's Avatar
United States, FL
Joined Nov 2006
New Product
CXN - Retractable FPV Pan/Tilt Camera Mount ... Now Available
THIS POST IS OLD, NEW 2015 Version coming soon.
Well guys after been out for a while, I'm getting back into designing some new FPV pods and update my current ones.
Here is a FPV pod I first designed for my SkyWalker but never had the chance to use it, it uses a Standard Servo for the retract arm, a winch sail 360 degree servo for pan and a mini servo for the tilt.
I'm making a design to use a mini servo in the pan for those with mini CCD cameras, the big 360 degree servo is more for GoPro's and the mount will be different.
UPDATE: Now Available in 1/8" Grade A MDF or 1/8" ABS plastic (limited quantity) PM me for details
It will require the following:
1) Standard servo for "RETRACT"
2) Standard servo for "PAN" (I'm using a GWS S125 sail winch servo 360 degree rotation) servo plate adapter included so you can use a micro servo if desired.
3) Micro servo for "TILT"
Total weight with servos installed 145 grams, measurements are in the picture, it will require a 70mm by 70mm hole for FULL RETRACT on any position. (if you center the camera before retraction you can use a smaller hole) Camera used measures 32mm x 32mm x30mm
YOU CAN ORDER THEM HERE
CXN Retractable FPV Pan & Tilt Camera Mount (0 min 30 sec)
This is how it looks mounted on a Sky Walker
crd is offline Find More Posts by crd
Old Aug 30, 2012, 07:48 PM
vertcnc is offline
Find More Posts by vertcnc
Illinois, USA
Joined Aug 2009
Looks sweet. I guess you would need to make sure you had the pan & Tilt servos centered before you tried retracting or it would get hung up. If you didn't know it and landed, could be some damage. Want one. When is the first production run.
vertcnc is offline Find More Posts by vertcnc
Old Aug 30, 2012, 08:00 PM
crd is offline
crd
crd
Always thinkering
crd's Avatar
United States, FL
Joined Nov 2006
They dont have to be 100% centered to fully retract but Im trying to design everything to retract on any position but so far it will not.
Old Aug 30, 2012, 08:29 PM
vertcnc is offline
Illinois, USA
Joined Aug 2009
Well if you have the pan on a self centering stick, like the one normally used for the rudder maybe it wouldn't be a problem. That normally the channel I use for pan anyway. Or maybe a mix in the radio where a switch would center the pan and tilt.
Old Aug 31, 2012, 12:46 PM
crd is offline
crd
crd
Always thinkering
crd's Avatar
United States, FL
Joined Nov 2006
Video on first post
Old Aug 31, 2012, 02:25 PM
nakelp86 is offline
Find More Posts by nakelp86
Nakelp
nakelp86's Avatar
United States, NJ, Union
Joined Sep 2004
Love it will be great for new plane Pinguin,
but I would attatch the largest cam (3cm x 3cm) and see if it fits through the hole. Otherwise you are limited to board only cameras :-(
nakelp86 is offline Find More Posts by nakelp86
Old Aug 31, 2012, 02:41 PM
crd is offline
crd
crd
Always thinkering
crd's Avatar
United States, FL
Joined Nov 2006
The version 2 is designed for this camera with 36mm x 36mm x 30mm mounting plate dimensions https://urbandrones.3dcartstores.com...e.asp?#page-78
The GoPro mount is also coming soon
Old Aug 31, 2012, 02:52 PM
nakelp86 is offline
Nakelp
nakelp86's Avatar
Joined Sep 2004
GREAT !!!
rough $$?
Old Aug 31, 2012, 03:08 PM
boopidoo is offline
Find More Posts by boopidoo
On a holiday?
boopidoo's Avatar
Uppsala, Sweden
Joined Sep 2008
I'd like to see a video with a camera attached (any camera). Isn't the hole too small for that?
boopidoo is offline Find More Posts by boopidoo
Old Aug 31, 2012, 03:10 PM
nakelp86 is offline
Nakelp
nakelp86's Avatar
Joined Sep 2004
My post above :-)
Old Aug 31, 2012, 03:19 PM
crd is offline
crd
crd
Always thinkering
crd's Avatar
United States, FL
Joined Nov 2006
GREAT !!!
rough $$?
CHEAP hehe, I will be making them in ABS Plastic and Plywood.
Old Aug 31, 2012, 03:24 PM
crd is offline
crd
crd
Always thinkering
crd's Avatar
United States, FL
Joined Nov 2006
will do tonight or tomorrow, the camera doesnt hit the hole ring on my cad designs but I will a camera tonight and see.
Old Aug 31, 2012, 07:12 PM
crd is offline
crd
crd
Always thinkering
crd's Avatar
United States, FL
Joined Nov 2006
Video on first post
Old Aug 31, 2012, 10:23 PM
nakelp86 is offline
Nakelp
nakelp86's Avatar
Joined Sep 2004
Just to be on the safe side (in case of larger 36mm cam) I would make that pase plate hole a bit bigger.
Old Sep 01, 2012, 06:43 AM
crd is offline
crd
crd
Always thinkering
crd's Avatar
United States, FL
Joined Nov 2006
All depends on the plane, the base plate on the video is for Easy Star, Sky Surfer and Bixler planes, for larger planes like the Sky Walker the base can be bigger and then you will be able to use a GoPro mount if desired. I will post a video of the GoPro mount later today.
New Product Pan, Tilt, Retractable Camera Mount johnorama UAV - Unmanned Aerial Vehicles 71 Sep 01, 2014 08:06 PM
Wanted XAircraft CM130-TPS Pan/Tilt Camera Mount Guntars Aircraft - Electric - Multirotor (FS/W) 0 Mar 03, 2012 08:07 AM
Sold Fatshark FPV 5.8Ghz with two pan tilt camera mounts and voltage OSD $315 shipped stretch1100 FPV Equipment (FS/W) 5 Jan 29, 2012 04:01 PM
New Product Hobby King has a new Fiberglass Pan-Tilt Camera Mount for FPV CrashingDutchman FPV Talk 79 Nov 04, 2010 10:03 AM
New Product Pre-order: Hobbyking FPV Fiberglass Pan-Tilt Camera Mount L-Size CrashingDutchman FPV Talk 10 Jul 24, 2010 09:17 PM
