Old Aug 30, 2012, 05:37 PM
robe_uk is offline
Find More Posts by robe_uk
Metallica
robe_uk's Avatar
Londonderry UK
Joined Nov 2004
Build Log
Rob's CNC Hotwire foam cutter
Hi all
Well this is not so much a build log as the cutter is built, I thought I would present a series of pictures showing its construction, you never know someone might be interested
I have been interested in building a foam cutter for some time but never could settle on a design, drawer slides right through to linear rails etc, I have been watching more and more people using cncrouterparts linear rail system and thought i would base my cutter on that design.
Anyway on to the pictures, i'll add descriptions to each one
robe_uk is offline Find More Posts by robe_uk
Old Aug 30, 2012, 05:40 PM
robe_uk is offline
Metallica
robe_uk's Avatar
Londonderry UK
Joined Nov 2004
aww **** where did the pictures go, I had 30 with descriptions, give me some time to redo. I'll post just a few pre post
Old Aug 30, 2012, 05:56 PM
robe_uk is offline
Metallica
robe_uk's Avatar
Londonderry UK
Joined Nov 2004
Heres the pictures with no descriptions incase it was a time out thing
Old Aug 30, 2012, 06:15 PM
robe_uk is offline
Metallica
robe_uk's Avatar
Londonderry UK
Joined Nov 2004
1&2 - are cncrouterparts inspired bearing blocks for x axis.
3 - flat bar used for x axis rails, 1meter long 80mm wide and 10mm thick, heavier than I would have like but its what the local supplier had.
4 - leadscrews are M8 stainless steel thread rod, end turned down to 1/4'' for motor couplings I have.
5&6 - bearing block with skate bearing for holding lead screw.
7&8 - bearing block on the end of the rail with leadscrew installed, held by two screws going up through the rail. The leadscrew is held with nuts on each side of the bearing to keep movement to a minimum. The flat bar rail is bold on top of 40x0mm unistrut.
9 - motor on x axis coupled to leadscrew with flew coupling, dont think addition bearing support is needed at this end due to low forces required with a foam cutter. The motor mount is held same is bearing mount with screws through the rail
Old Aug 30, 2012, 06:23 PM
robe_uk is offline
Metallica
robe_uk's Avatar
Londonderry UK
Joined Nov 2004
10,11&12 - Y axis bearing plate. The Y axis is using a different method for travel, it is using al extrusion with skate bearings running on their edges. I expect the extrusion will wear but guess it will be minimal due to the low forces. Two sets of bearings on one side are fixed while the single set can be tightened in to remove slack. You can see how the bearings are held and spaced with washers. Front side you can see the Y leadscrew with custom delrin nut
Old Aug 30, 2012, 06:30 PM
robe_uk is offline
Metallica
robe_uk's Avatar
Londonderry UK
Joined Nov 2004
13 - Y axis motor coupled and motor mount
14&15 - top view of Y motor mount, the bolt in 15 holds the mount onto the top of the extrusion, there is a recess in the mount for the extrusion to sit into and maintain alignment with the bottom plate. The complete Y axis is held onto the x carriage with a single bolt through into the extrusion the same as the Y motor mount is held
16&17 - Y bottom plate, the bearing keeps the leadscrew smooth, the nut on the screw help hold it from pulling down on the motor coupling
Old Aug 30, 2012, 06:39 PM
Ward Hagaman is offline
Find More Posts by Ward Hagaman
Ward Hagaman's Avatar
San Diego
Joined Mar 2003
Very Nice!
Ward Hagaman is offline Find More Posts by Ward Hagaman
Old Aug 30, 2012, 06:40 PM
robe_uk is offline
Metallica
robe_uk's Avatar
Londonderry UK
Joined Nov 2004
18&19 - side view of x carriage and y axis plate, the yellow part is FR4 which holds the bow wire
20 - front view of x carriage, show another delrin nut, not anti-backlash but is ok. The x bearings are bolted to a piece of 18mm mdf which has been painted with silver hammerite
21 - connector plate for the motors so that cutter can be put away easily.
22&23 - views of complete tower.
24 - two towers are bolted to top of router table
Old Aug 30, 2012, 06:41 PM
robe_uk is offline
Metallica
robe_uk's Avatar
Londonderry UK
Joined Nov 2004
Originally Posted by Ward Hagaman View Post
Very Nice!
Old Aug 30, 2012, 06:51 PM
robe_uk is offline
Metallica
robe_uk's Avatar
Londonderry UK
Joined Nov 2004
25 - simple bow, 15x15mm al tube with 10mm fibreglass rod, the rod can hold wire with good tension.
26 - custom clamp to attach power to bow
27- power supply i use, run at 2amp seems to work for me.
28,29&30 - custom control box with hobbycnc hotwire controller, no longer made, i dont use the bow function yet.
31-33 couple of things i cut to test the cutter.
thats a quick summery of the pictures, feel free the ask
Old Aug 30, 2012, 06:56 PM
Wazmo is online now
Find More Posts by Wazmo
Duane, LSF IV
Wazmo's Avatar
No. VA
Joined Nov 2004
FWIW, you can edit your post with the photos (click the Edit button in the lower right corner of that post), click the Go Advanced button, click the Manage Attachments button under the text box, and edit the photo captions. The text will show up under each photo in the post, as well as when viewing the attachments individually.
Wazmo is online now Find More Posts by Wazmo
Old Aug 30, 2012, 07:21 PM
robe_uk is offline
Metallica
robe_uk's Avatar
Londonderry UK
Joined Nov 2004
Nice one, done now
For Sale 12v 32a powersupply w/free hotwire foam cutter eyeofinsanity Aircraft - General - Miscellaneous (FS/W) 3 Apr 20, 2012 10:03 PM
For Sale CNC Hotwire Foam Cutter LPU blake374 Aircraft - General - Miscellaneous (FS/W) 1 Feb 08, 2012 09:25 AM
For Sale CNC Hotwire Foam Cutter joe manor Aircraft - Sailplanes (FS/W) 5 Oct 22, 2011 08:03 AM
Article Hotwire Foam Factory's 24"-48" Hotwire Bow Cutter, Hot Knife & Plane Build Review 78dave Flight Accessories 20 Nov 02, 2009 05:13 PM
Discussion Wanted: some one with a CnC hotwire cutter to cut me up a sheet of foam... Draconious Foamies (Scratchbuilt) 0 Jul 17, 2007 02:06 AM
