Letchworth, Great Britain (UK)
Joined Jul 2004
I use a bit of stiff 22 gauge copper wire to pull leads through. It can usually be bent into a shape that will help it get round difficult corners, and is then rigid enough that it can be pushed round the bend once it gets round the obstruction. Fold over the end into a loop first, so it won't simply skewer itself into the foam at the bend. Try starting at the end nearest to the obstruction.
P.S. Obviously too late now, but in the future you should use the old leads to pull the new leads through -- solder the ends together and the new leads will pull in as you pull the old leads out
I just solved a similar problem on my Wild Hawk by using a heavy gauge heated wire to melt a larger channel from the rear of the cockpit to the motor housing through the fuselage area above the wing. The original two small diameter wires were replaced by three much larger diameter wires for a brushless motor, and the channel was just too small. I was able to bring the wires out at the front of the motor housing, just where they needed to be.
Joined Jul 2012
Thanx for all your advice. However after 30 mins of trying the various approaches I gave up and opted for this solution. I simply heatshrinked the three wires together and cut a small opening in the canopy, attached some velcro to the Wire and to the top of the plane, and voila:[ATTACH]
Perhaps not the most aerodynamic or elegant of solutions, but at least this way the wires will keep cool! This setup also allows me to rip the wires out when I want to, exchange motor ESC etc. Happy puppy! Now let's see if she flies and nothing burns up due to the longer wire lengths... |
| Thread Tools | |
| Discussion How to prevent servos on the new PZ UM F4U Corsair from getting wet? | sparkyz | Micro RTF | 10 | Aug 16, 2012 04:05 PM |
| Question is it better to lengthen the esc motor leads or battery leads? | tankreefer | Power Systems | 9 | May 16, 2012 03:16 PM |
| For Sale SkySurfer or Bixler stock engine | Maddmax | FPV/RPV - Equipment and Vehicles (FS/W) | 0 | Apr 12, 2012 10:25 AM |
| Discussion Bixler a.k.a SkySurfer tendency to flare | MarLi | Beginner Training Area (Aircraft-Electric) | 5 | Nov 07, 2011 01:23 AM |
| How many hcarges from this lead acid could I get? | ch2s | Batteries and Chargers | 2 | May 30, 2004 01:13 PM |
