This thread is privately moderated by RHTizzy, who may elect to delete unwanted replies.
Old Aug 30, 2012, 01:00 PM
RHTizzy is offline
Find More Posts by RHTizzy
RHTizzy's Avatar
The Netherlands, NH, Bussum
Joined Feb 2012
Build Log
Motors & Liftpower
From what I gather I have more lift than I need as the current build comes to a total of 750gr
I found these specs:
Order No. - Model No. - KVRpm//v - Weight - Motor Dimensions - Shaft Size - Prop/ recom - Battery - Idlecurrent - Loadcurrent - Power(Watt) - ESC(A) - Ri (Ω) - Pull (Approx)
221215 - A2826-15 - 930 - 50g - Ф27.7*26.3mm - Ф3.17*37mm - 9x6/9x3.8 - 2-3Li-Po - 0.4A - 9.5A - 100 - 30A - 0.139 - 330g
So I was thinking I might try these should have enough lift if I stay under a kilo and would also give more airtime per battery
220414 - A2812-14 - 1400 - 22g - Ф28*11.5mm - Ф3.17mm - 6030/7040 - 2-3Li-Po - 0.4A - 3.2A - 60 - 10A - 0.270 - 200g
They probably wouldn't handle as well but I'm not sure what would happen and I've no idea whether I'd like it or not...
RHTizzy is offline Find More Posts by RHTizzy
Old Aug 30, 2012, 02:11 PM
RHTizzy is offline
RHTizzy's Avatar
Joined Feb 2012
RCTimers motors
Found a great document containg all the specs which I converted to a spreadsheet
Old Aug 30, 2012, 04:21 PM
RHTizzy is offline
RHTizzy's Avatar
Joined Feb 2012
ordering these instead
220817 - A2822-17 - 1100 - 38g - Ф28*22mm - Ф3.17x33mm - 8x5/8x4 - 2-3Li-Po - 0.4A - 5.6A - 80 - 20A - 0,192 - 300g
Sold Brand NEW Multiplex twister stock motor and fan Himax Motor Shipped $25 sherlockshah Aircraft - Electric - Power Systems (FS/W) 4 May 07, 2012 04:27 PM
Sold motors motors motors! chyorn Aircraft - Fuel - Engines and Accessories (FS/W) 4 Apr 16, 2012 08:57 PM
Sold Parkzone Motor for Spitfire...the old version of the Spitfire with a brushed motor mondo1948 Aircraft - Electric - Power Systems (FS/W) 0 Mar 03, 2012 08:23 PM
Discussion ~100W 2s motor, what motors are efficient these days? saitrix Power Systems 0 Feb 27, 2012 02:13 AM
