Old Sep 22, 2012, 01:32 PM
Custom quad builder
tech69x's Avatar
United States, TX, Spring
Joined Apr 2012
Here you go
http://www.amazon.com/gp/browse.html...A2RTHSZRQB79ZY
tech69x is offline Find More Posts by tech69x
Latest blog entry: Win a frame
Old Sep 22, 2012, 01:51 PM
DCDetector's Avatar
Joined Sep 2012
I got my Bluelight BL-3GRC Gyro today and am trying to get it connected. I understand the connections with the exception of the power. I'm not sure how it would hook to my RX in my P51. Here is some pictures that might help. I'm just not getting how I need to connect my current(ESC) connection to the gyro to give it power? Any help would be greatly appreciated.
Port 1. on the gyro goes to the Elevator/Pitch in on the RX
Port 3. on the gyro goes to the Ailerons/Roll in on the RX
Port 5. on the gyro goes to the Rudder/Yaw in on the RX
So where does the power/ESC connect? How do I get power to the gyro?
DCDetector is offline Find More Posts by DCDetector
Old Sep 22, 2012, 03:10 PM
Bona Fide Cub Nut
CurtissP40's Avatar
Northwest Oregon
Joined Jan 2006
Originally Posted by tech69x View Post
thanks!!
CurtissP40 is offline Find More Posts by CurtissP40
Old Sep 22, 2012, 05:46 PM
Fly Low Fly Fast Fly Often
jjr2001's Avatar
Glendale, Arizona
Joined Jul 2007
http://www.bluelight-tech.com/Downlo...UserManual.pdf
Check page 8 if your servo current is going to be less than 2 amps.
Cheers, JR
jjr2001 is offline Find More Posts by jjr2001
Old Sep 22, 2012, 06:41 PM
DCDetector's Avatar
Joined Sep 2012
Got it mounted and tested. Waiting for the wind to die down to give it a fly.
Video of testing
http://www.youtube.com/watch?v=c3iXA...1&feature=plcp
Old Sep 23, 2012, 12:11 AM
ancora imparo
jj604's Avatar
Melbourne, Australia
Joined Jul 2005
No. You wait for it to be windy to give it a fly. That's the whole point.
Had mine out today in gusty winds up to 35km/hr (20 mph) in the old test bed Bixler with wheels. Take off and landing was perfectly easy even for a klutz like me - no way I could do this without it and enjoy it.
It's a nice complement to my Guardian. They do different jobs. This is a very professional and configurable 3 axis damper. Nice piece of work.
jj604 is offline Find More Posts by jj604
Old Sep 23, 2012, 01:27 AM
FPV in Hawaii
iskess's Avatar
United States, HI, Kailua
Joined Feb 2012
Can you expand on why you think this works along side the Guardian? It seems like they do exactly the same job, except the Guardian has attitude hold like the Pro will.
Why put both in one plane?
iskess is offline Find More Posts by iskess
Old Sep 23, 2012, 02:01 AM
ancora imparo
jj604's Avatar
Joined Jul 2005
Sorry, that might not have been entirely clear. I have both - but in different planes. Both planes happen to be pretty similar. At the moment the Blue Light is in a Bixler, the Guardian in an EasyStarII. Both work great.
I was just making the point that they are optimised for slightly different things but with a lot of overlap.
IMO the Blue Light gives you all the control you might ever possibly need over a 3 axis gyro but that's all, the Guardian is stronger as a fit-and-go stabilizer. The 2D levelling mode of the Guardian is limiting if you want maximum control of the aircraft but excellent as an on-board "copilot" and panic button. The current Blue Light can't do that. However, even in 3D mode the Guardian is not as tuneable as the Blue Light.
They are both extremely well thought out, high quality items - unlike a lot of the cheap stabilizers that are appearing. The HK Orange in particular is going to wreck a few models.
You are correct that the Blue Light Pro will be more like the Guardian but I would think be even more attractive for those who want maximum configurability. All 3 will have their own advantages.
John
Old Sep 23, 2012, 05:06 AM
DCDetector's Avatar
Joined Sep 2012
Did the upgrade on both firmware and software and the chatter seems to have all but gone. The ailerons seem to be very responsive but I see little movement from the elevator and rudder. Not near as obvious as the aileron response. Also, when I plug the USB cable in, after a few seconds, I get a content twitch from the rudder. A signal about every 1 second moves the rudder.
Old Sep 23, 2012, 05:23 AM
Manufacturer
IceManPro's Avatar
Joined Sep 2012
Did you re-send all parameters to the BL-3GRC?
IceManPro is offline Find More Posts by IceManPro
Old Sep 23, 2012, 06:52 AM
DCDetector's Avatar
Joined Sep 2012
Yes.
Old Sep 23, 2012, 08:41 AM
Manufacturer
IceManPro's Avatar
Joined Sep 2012
Yes.
Will check it out..
Old Sep 23, 2012, 09:23 AM
jjr2001's Avatar
Glendale, Arizona
Joined Jul 2007
John
Indeed,excellent summary John.
The Blue Light is a very versatile unit. With the 6 outputs you can get it setup on planes or quads that have just about any servo configuration or rotation.
It can also be set to be enabled by a switch on the TX and the overall gain can be adjustable from a pot on the TX.
With 4 programmable inputs you can have access to many parameters that you can change in flight from the TX.
Well designed pots on the BL3G allow easy setup of individual gains on the unit itself.
I have two Gardians, One BlueLight BL3G, and one "Orange" that is more like a lemon, even if it only cost 15 bucks.
The "Orange" is not installed in anything and will not be unless the "pot" issue is fixed.
I will be ordering at least one more Blue Light in the future.
The BL3G will have a library of configurations that you can download.
Right now there are only a few available but I would imagine that after people start using it they will send in their configs and the library will grow.
You can find them here:
http://www.bluelight-tech.com/DownloadsExamples.htm
Cheers, JR
Old Sep 26, 2012, 02:12 PM
Joined Jun 2009
Why not ALWAYS use the high-power setup?
The only disadvantage I can see is that it needs an extra male-to-male servo lead i.e. five instead of four of them.
This would seem to be more than offset by a gain in safety.
Am I missing anything?
chris3142 is offline Find More Posts by chris3142
Old Sep 26, 2012, 10:56 PM
Manufacturer
IceManPro's Avatar
Joined Sep 2012
Cheers, JR
BL-3GRC ICE-MAN Gyro V2.0 s/w now out..
I fly fast and want fast gyro response but my RC Tx only outputs pulses at 15ms. Would be good to increase to say 6ms to support my fast digital servos
-with the BL-3GRC YOU CAN
Would be good to fly my delta wing slowly on landing to save on runway length
- With the BL-3GRC YOU CAN add flaperon function even for delta wing
I have a big aircraft which needs lots of runway to land. Some sort of speed brake would be good
- with the BL-3GRC YOU CAN with two stage flaps, third stage ailerons up for air-brake / 'crow' function
I have a big beast of a plane with dual wing servos, even two opposing servos for the rudder. Would be good to have just one controller
- With the BL-3GRC YOU CAN with two configurable outputs per axis
I like to teach my novice friend how to fly but he has a habit of veering off to the side of the runway on take-off. Would be good to have very large gyro rudder gain just at take off
Would be good not to have to re-trim my aircraft after a long time or remember which RC Tx has the trim saved. Great if the gyro can automatically save the trim settings
- with the BL-3GRC YOU CAN just pick up any RC transmitter and set all trims to zero
I like to fly fast but want good stability during slow landings with flaps or flaperons
- with the BL-3GRC YOU CAN set real time two gain switch for fast / slow flying
I am a bit of a novice and only have a small area to fly in, would be good to find a way to keep the turns tight and stop flying away so far. I'm still a bit nervous about using the rudder myself, would be good if some rudder could be applied during my turns
I have a foamie flying wing aircraft would be good to hide a controller inside the wing
- with the BL-3GMod YOU CAN. The MOD version is a small 35mm square, thin PCB, you can cut off or de-solder the pins, connect (solder) only the inputs and outputs you want, and have a flying wing with controller/flaperon function/gyro buried inside.
Such a low price too, talk about a game changer! I work for Bluelight so don't take my word for it, check out the user manual and PC set up s/w before you buy. http://www.bluelight-tech.com/Downloads.htm
Discussion GPS - - Blue light off after 10 mins part141 Hoverfly Technologies 11 Aug 09, 2012 11:54 PM
Help! Optima 9 RX blue LED won't light edge_pilot Hitec/Multiplex USA 6 Jul 15, 2012 06:34 PM
Gallery Cinestar 8 Gimbal Stability Test and Canon 7D low light test with the Tokina 11-16 HeliVids Aerial Photography 0 Jun 13, 2012 07:45 AM
Discussion GPS not working (blue light only blinks once) DesertDrones Video Piloting (FPV/RPV) 3 Jun 12, 2012 10:37 PM
