We've done much testing on quad and hex copters (we have a .txt set up script on our website for this). You can also see here:
Our AHRS will come out later to allow hands free flying. |
1) Mount the gyro (face up or down) and connect it all up so control surfaces move as wanted with the sticks 2) If any gyro actions are the wrong way round do this: - invert the axis (pitch, roll or yaw) at the RC transmitter - then either select the alternative (negative) Gyro output (or invert in the gyro set up s/w) to go to the servo That should do it. As I said we will make all this a lot easier in the next s/w and f/w releases |
Would it be better to wate for the pro to come out |
Sport and some fpv on the side
Latest blog entry: Win a frame
Thank for your honesty I will be getting one of your pro flight controllers as soon as they come out
The voltage drop will relate to how much of a BUMP one part of the 5V rail will see if there is a surge in current. If your battery is plugged into the pin that goes directly to the Internal power, that will be best. But servos will often see "bumps" in power drops when they or other servos pull more power. Battery Internal resistance or the quality of voltage regulation and battery lead thickness for a BEC all come into play. People using weak batteries, thin BEC wires (like those on a cheap ESC that has an internal BEC) all came into factor with people getting drop outs with Spektrum Receivers. Eagletree runs solder across the tops of the +5 & GnD headers to lower the resistance of that bus so it does not matter which plug the power comes in on. Since you are supplying 4 full 3 pin servo wires and the wire diameters are large, that makes your product better for handling higher current servos provided the 5v/gnd bus across those headers have thick traces or solder going across them. The Eagletree supplies that muli connector and only 1 wire provides +5V and ground to the Eagle Tree and the Servos making it require an external solution for higher current draws more than a couple amps. |
| Thread Tools | |
| Discussion GPS - - Blue light off after 10 mins | part141 | Hoverfly Technologies | 11 | Aug 09, 2012 11:54 PM |
| Help! Optima 9 RX blue LED won't light | edge_pilot | Hitec/Multiplex USA | 6 | Jul 15, 2012 06:34 PM |
| Gallery Cinestar 8 Gimbal Stability Test and Canon 7D low light test with the Tokina 11-16 | HeliVids | Aerial Photography | 0 | Jun 13, 2012 07:45 AM |
| Discussion GPS not working (blue light only blinks once) | DesertDrones | Video Piloting (FPV/RPV) | 3 | Jun 12, 2012 10:37 PM |
