Not practical to use the a 3 axis gyro for camera / gimbal stability since it has no reference to gravity. The ICE-MAN Pro will have two dedicated outputs (from the PC set up tool you will be able set up the end points and home position), we are working hard to get this product out asap. Looking at the specs on the D922MG Digital Metal Gear Servo 1.8kg it looks like it needs about 80mA at 5v so should be no problem if you have a bunch of these connected up. You can see our initial testing of these two outputs here:
you can see it's not perfect yet, but we'll improve for product launch. Yes currently shipping out of Thailand. Have a UK distributor already and the US distributor will be on line with us within hopefully by end Oct. (Will then also support shipments from Amazon from US to US) |
Rochester, New York
Joined Jan 2006
Hi Papa Jeff,
"Not practical to use the a 3 axis gyro for camera / gimbal stability since it has no reference to gravity. The ICE-MAN Pro will have two dedicated outputs (from the PC set up tool you will be able set up the end points and home position), we are working hard to get this product out asap. Looking at the specs on the D922MG Digital Metal Gear Servo 1.8kg it looks like it needs about 80mA at 5v so should be no problem if you have a bunch of these connected up. You can see our initial testing of these two outputs. ----------------------------------------------------------------------------------------------------- Mark, It is refreshing to have a Mfg. that is accommodating and tells it like it is! You are gaining a great following and it is well deserved! Thank you for your honest comments about your 3G not being practical for gimbal stabilization. Put me on the list for one of the first ICE-MAN Pro models! I will be following this thread and when it becomes available, I will immediately place my order! Papa Jeff |
Mark |
United States, NH, Stark
Joined Sep 2011
Upside Down?
Many RC planes, including a T-28 I have, have all the electronics, servos, battery, etc., mounted in the underside of the plane. Upside down.
Can the gyro be mounted belly-end up? ie, upside down, but still pointed forward? Ted |
But when starting new, you have to check the reversing of all 3 anyway. http://www.mycoolrc.com/gyro/gyrotestpage.html |
I just spent a few minutes with it and I'm also impressed. EXCELLENT documentation and SW interface. I've only scratched the surface but here are some comments
1) Very important to give an out of the box ready to fly experiance WITHOUT manditory PC connection and configuration. Couple this with a "quick start" section. Only thing needed is to set it up to analog servos because as mentioned, Digital is the default. One other possibility is to set CH6 input to Gyro exact gain mode. That makes it more like the eagle tree system. 2) The manual shows in section 2.4.2.1 there is a check mark to enable the gyro on by default w/o a channel connected. But you have to instead uncheck the roll pitch yaw boxes or select ch7 as another function. 3) I really like the function to learn the radio stick range. 4) I'm not sure if it's a config thing but when the gyro is on, moving the sticks does not move the servo to full difflection like when the gyro is off. 5) FINALLY, a 3 axis gyro system where I can switch JUST THE RUDDER off when flying and keep Ail, ELE active. To do this just unclick Ail/Elev in the gyro on/off function in the advanced 2 tab, then resend the config. The whole package is professional, including a screw driver, the cables etc. Maybe adding a square of good servo tape would add to it but, I think mounting is a personal preference for me. The size of the case may present difficulty in mounting but I think this gyro if you have the space will appeal to both the simple and the complex aircraft. I had intended to put the Eagletree in my 1/4.5 scale electric bipe but I think I'll put the BlueLight instead after I get some time on it. Like I said, I've only scratched the surface |
Thanks for the feedback. Yes we will make analogue the default and have it easy 'out of the box' working. Regarding item (4) you just need to follow the range set procedure of section 2.3.3. of the user manual (note this is at release v1.8 now and available at Bluelight website) For the "quick start" section you mention, do you think a set up wizard is required that asks the user a set of questions about what he wants to do is necessary, or just a single tab page that is visible (and the other pages invisible) is a good way to go? (Other pages can then be set to visible for advanced users). |
For what it's worth I flew it for the first time today.
Results were fine but I only got in one flight clearly need to do more work on the gains and tuning. The twin outputs on each axis are great for simplifying setup! I also wonder if it would be an idea to have it set up out of the box for a "conservative" set of gain defaults instead of mid-range as at present. That is: Analog servos Moderate gain on Roll Low gain on Pitch Nothing on Yaw Then folks can start adjusting things to suit their particular needs, but if they just plugged it in and fly they couldn't go far wrong. Starts out as a conservative roll and pitch damper and move on from there. Just a thought. John Quote:
Will take a look at that, for sure we're changing default to Analogue servos. What plane did you do your first flying with? Mark |
| Thread Tools | |
| Discussion GPS - - Blue light off after 10 mins | part141 | Hoverfly Technologies | 11 | Aug 09, 2012 11:54 PM |
| Help! Optima 9 RX blue LED won't light | edge_pilot | Hitec/Multiplex USA | 6 | Jul 15, 2012 06:34 PM |
| Gallery Cinestar 8 Gimbal Stability Test and Canon 7D low light test with the Tokina 11-16 | HeliVids | Aerial Photography | 0 | Jun 13, 2012 07:45 AM |
| Discussion GPS not working (blue light only blinks once) | DesertDrones | Video Piloting (FPV/RPV) | 3 | Jun 12, 2012 10:37 PM |
