Old Jan 14, 2013, 10:42 PM
IceManPro is offline
Find More Posts by IceManPro
IceManPro's Avatar
Joined Sep 2012
Good question, I'm still here :-)
IceManPro is offline Find More Posts by IceManPro
Site Sponsor
Latest blog entry: BL-3G Independent review
Old Jan 15, 2013, 07:28 AM
Papajeff is offline
Find More Posts by Papajeff
AMA 869451 / FAA 13675
United States, NY, Rochester
Joined Jan 2006
Originally Posted by IceManPro View Post
Hi PapaJeff, Still working out the details, sorry can't give any precise details just yet..
Mark
Happy New Year, Mark! I think that an update on the "Pro" might get this
thread back on track. With the Multi-copter guys, there is still a need for
a FC that can equal the NAZA with GPS at a realistic price, In addition,
a gimbal stabilization controller with an easy method to change values,
would be well received.
Papajeff is offline Find More Posts by Papajeff
Old Jan 16, 2013, 05:15 AM
IceManPro's Avatar
Joined Sep 2012
Hi Papajeff, happy new year to you too. still working on the pro, will let you know when I have a better visibility of completion. Will also post some progress vids when I can. For the BL-3GRC gyro part we again have stock now (in US there has anyway always been stock on Amazon.com). Some magazine reviews in the pipeline, I'll pass on the details when I have them.
Mark
Site Sponsor
Old Jan 16, 2013, 04:33 PM
hapfarr is offline
Find More Posts by hapfarr
Joined Jul 2011
Mark
Please disregard this
hapfarr is offline Find More Posts by hapfarr
Old Jan 17, 2013, 05:35 AM
Papajeff is offline
Joined Jan 2006
Mark
Thanks for the update and I'll be looking foreward to your introduction of the
Pro.
Old Jan 31, 2013, 05:50 AM
jaccies is offline
Find More Posts by jaccies
The Netherlands, LI, Venray
Joined Dec 2008
Mark
Mark
where to buy in Europe ?
jaccies is offline Find More Posts by jaccies
Old Jan 31, 2013, 11:00 PM
IceManPro's Avatar
Joined Sep 2012
Originally Posted by jaccies View Post
Mark
Hi jaccies, currently we're still discussing about distributors for EU, but you can anyway buy direct from our website. Please see here
Site Sponsor
Old Feb 01, 2013, 07:09 AM
jaccies is offline
Joined Dec 2008
thanks, i live in the Netherlands, i ordered one today , please USD25 Declared value on package , thanks
Old Feb 03, 2013, 10:27 PM
IceManPro's Avatar
Joined Sep 2012
Thanks for the order, will sort it..
Mark
Site Sponsor
Old Feb 13, 2013, 09:29 PM
IceManPro's Avatar
Joined Sep 2012
For the BL-3GRC ICE-MAN gyro we're thinking of adding the following additional features: I'm interested to know if these would be useful to people:
1) Balance of twin prop engines (primarily for take off), ie to counter any yaw movements with differential throttle, to help out the rudder for these aircraft.
2) Ability to change the control range on output channels individually (ie for large scale planes where two servos are used, but located in different positions). This can be done today but only with one channel. See here
3) Support for tri-copter multi-rotors.
Any further suggestions would be appreciated if you have any ideas.
Mark
Site Sponsor
Old Feb 14, 2013, 02:31 AM
FinnCat is offline
Find More Posts by FinnCat
Joined May 2012
Mark
1) Excellent. I use now throttle differential with my twin engine Catalina, rudder channel acting as master. It helps but take-off is still a tricky business. I have been thinking of gyro controlled differential, but but... This would be very useful.
2) Excellent. With just tx controlled systems servo travel setting is easy, but adding a flight controller between is causing a lot of trouble. Even mechanically.
Suggestion: Waterproof casing -option. I have a lot of water planes, and there is water all over no matter what. Permanent waterproofing is easy but keeping the possibility to access the pots etc. is not.
Edit: this waterproofing applies winter time flying too. Now it is winter in the northern hemisphere, perfectly fine weather for flying but snow gets all over.
FinnCat is offline Find More Posts by FinnCat
Old Feb 14, 2013, 04:18 AM
IceManPro's Avatar
Joined Sep 2012
Hi Finncat, thanks for your comments and suggestion. Interesting idea about waterproofing, but I'm not so sure how big the market would be for it. With the ICE-MAN gyro you can anyway just set an input to act as a real time gain control so this can be controlled via the pot on the RC Tx. So the permanent waterproofing may be the better option.
Mark
Site Sponsor
Old Feb 14, 2013, 02:08 PM
FinnCat is offline
Joined May 2012
Mark
What about such arrangement that gains could be adjusted alternatively not by pots but from the program? Then all the settings could be done via USB or otherwise remotely (Bluetooth -> cell phone app!? ).
Getting rid of the need to access the pots in the plane would also give much more freedom to select the mounting place - big advantage for many plane builders I guess.
/Ari
Old Feb 14, 2013, 08:57 PM
IceManPro's Avatar
Joined Sep 2012
/Ari
Hi Ari, this is already in place (via USB). You can see it here on the professional 1 page..
here
Regarding wi-fi, the BL-3GRC has a UART interface too, so a builder could connect a commercially available RF communications unit and then via a whole host of commands (already in place) access and modify many parameters of the gyro remotely.
Site Sponsor
Old Feb 15, 2013, 01:21 AM
FinnCat is offline
Joined May 2012
here
OK, sorry, I thought that the pots are always part of the equation. I'll go back to my cave and study more. When you see white smoke coming out of the chimney, a new pop...sorry plane with Ice-Man Gyro has born. If it's grey smoke I need a new unit.
/Ari
Discussion GPS - - Blue light off after 10 mins part141 Hoverfly Technologies 11 Aug 09, 2012 11:54 PM
Help! Optima 9 RX blue LED won't light edge_pilot Hitec/Multiplex USA 6 Jul 15, 2012 06:34 PM
Gallery Cinestar 8 Gimbal Stability Test and Canon 7D low light test with the Tokina 11-16 HeliVids Aerial Photography 0 Jun 13, 2012 07:45 AM
Discussion GPS not working (blue light only blinks once) DesertDrones FPV Talk 3 Jun 12, 2012 10:37 PM
