Blue Light Technologies Flight Stabilizer BL-3G 2D 3D Quad
http://www.bluelight-tech.com/BL-3GMod.htm
BL-3GMod Priced at only $56.00 Has anyone tried one of these on a plane or quadcopter. From the description it looks to be able to work to stabilize just about anything. User Manual: http://www.bluelight-tech.com/Downlo...UserManual.pdf PC Tool overview with 11 pages of settings: http://www.bluelight-tech.com/BL-3GPCTool.htm Gyro range x 7 RC transmitter inputs (Pitch, roll, yaw + 4 real time switches x 6 RC aircraft outputs (Aircraft servos / ESC motor speed controllers) - Applications: RC airplane, heli, multi-copter, gyro evaluation, platform ..stability, general robotics, teaching aid - In-built full speed mini USB for set up and testing (incl firmware upgrade) - Supports all RC transmitters, servos and controllers (Independent I/O) - Multiple input curve options, incl x4 user defined (11 pts) - x 3 PID contollers (programmable) - Special anti-crash and cross wind take off features for novice teaching BL-IM10Mod Here is another model that is interesting: Auto-pilot range x3 Gyro / x3 Accelerometer / x3 Magnetometer / x1 Barometer x 12 RC transmitter inputs (Pitch, roll, yaw + 9 real time sw or sensors) x 8 RC aircraft outputs (Aircraft servos / ESC motor speed controllers) - Fusion Sensor outputs: Raw data, Quaternion attitude, Euler angles, Complementary filter, heading, altitude - Applications: RC airplane, heli, multi-copter, gyro evaluation, platform ..stability, general robotics, teaching aid - Progarmmable aircraft path / pattern flying - All ST MEMS devices with internal registers accessible / programmable Looks like the market is really moving fast. You have all of the stand-alone gyros, the Orange Stabilizer from HK, the Guardian from EagleTree. Just bought my second Guardian before I found this one. Looks like I need to buy a BL-3GMod just for fun.... Cheers, JR |
I talked to Pete with Blue Light yesterday via email. He explained a few versatile things to me about the Iceman and the PRO. You can gang as many servos as you need for each surface. You have control with the software prograbilty to reverse the servos through the gyro and for power hungry servos you can have the signal come from the gyro to the servos but power direct from the battery.pages 10-11 in the manual. Obviously the PRO allows more channels so you can Y servos on right wing from one channel, Y the servos of the left wing on another, and do the same with the elevator. Also pete said that they are 5 months from being available, he said the software for it is almost complete. expected cost between $100 - 150 dollars. He says you can buy direct or through Amazon. He has videos of the software on their website and the control of the unit that you have through the software is awsome. I believe he is a British Aerospace Engineer. Super nice guy to talk very candid and helpful. I may go with one of the regular units first. If it works well I will get the PRO for my giant gas plane. Keep in touch Wil Wil |
I noticed that the English in the manual and on the website was real English and wondered why it was so good. I currently have one EagleTree Guardian and it works great, ordered another from HK yesterday and just placed an order for the Blue Light....That will most like be all the stabilization I should need... As a side note, I decided to give that Orange Stabilizer one more chance on a foamie and found that it is not useable. I tried it last week on a 3DHS Extra and it was almost uncontrollable. You get about 2 to 3 degrees of rotation from 0 to 100% sensitivity. No way that I could adjust the gyro so after 3 attempts I pulled it from the plane. Hopefully there will be a software update to make the Orange useable but until then I am all in with Guardian and Blue Light. I will post results of my experience as soon as my BL-3G Blue Light arrives. Cheers, JR |
Joined Nov 2011
Hi. I just installed the BL-3G gyro in my 2m Icon. Works very well. Very smooth, easy, stable flying even in windy/crosswind conditions. Lots of configurable parameters available via the USB PC software, even has an oscilloscope (live data tab) function so you can see the gyro working. The advanced1 tab was pretty useful to check and calibrate the Tx control outputs (I use a Spektrum DX5e). When configuring parameters via the software when the gyro is installed and connected to servos, make sure the battery is connected too, as the USB current is limited. I like the ability to define your own control curves too, rather than having an expensive complex radio. Sensitivity can also be adjusted in the field with a small screwdriver. All in all I'm very impressed, works great! Steve
How long did it take to receive yours? Cheers, JR |
Hi all, I work at Bluelight Technologies, the company who develops and manufactures the BL-3GRC "ICE-MAN" Gyro. I would encourage you to go to Bluelight website to download all the literature and documentations (bluelight-tech.com). As time goes on you'll also be able to get various pre-designed set up scripts for various aircraft configurations. (In fact I would very much like you to send yours to me if you don't mind sharing so I can put them on line). I'm more than happy to answer any questions you may have.
I read the manual and checked out the website last week and I think that you have the most versatile gyro stabilizer on the market bar none. The price is right. For a full feature, user programmable unit you have the best price point also. Many thanks to you and your company for bringing this to market. I think this is the stabilizer that we were all looking for. Cheers, JR |
2) How hard is it to configure compared to something like the Guardian? Obviously it can be very complex, but will it work out of the box with minimal programming. 3) what is the difference between the "Mod" and "boxed" versions 4) This question is for anybody...Is there anything that the Guardian has, that this doesn't? |
Between my tx and crashed aircraft
Joined Mar 2006
the Blue Light IM10 does not seem to be available yet, but seems to mention accelerometers for keeping level. The currently available Blue Light (3G?) does not seem to have accelerometers for keeping level. |
| Thread Tools | |
| Discussion GPS - - Blue light off after 10 mins | part141 | Hoverfly Technologies | 11 | Aug 09, 2012 11:54 PM |
| Help! Optima 9 RX blue LED won't light | edge_pilot | Hitec/Multiplex USA | 6 | Jul 15, 2012 06:34 PM |
| Gallery Cinestar 8 Gimbal Stability Test and Canon 7D low light test with the Tokina 11-16 | HeliVids | Aerial Photography | 0 | Jun 13, 2012 07:45 AM |
| Discussion GPS not working (blue light only blinks once) | DesertDrones | Video Piloting (FPV/RPV) | 3 | Jun 12, 2012 10:37 PM |
