Old Aug 30, 2012, 07:31 AM
3flyguy3 is offline
Find More Posts by 3flyguy3
3flyguy3's Avatar
United States, IL, Waukegan
Joined Apr 2012
Question
Nylon, plastic or metal clevis
On a 29oz (or so) pusher jet what is recommened for servo/control horn connection, nylon, plastic or metal clevis? Metal or carbon pushrods?
3flyguy3 is offline Find More Posts by 3flyguy3
Old Aug 30, 2012, 08:43 AM
solentlife is online now
Find More Posts by solentlife
222 km/hr Parkjet flyer
solentlife's Avatar
Latvia, Ventspils pilsēta, Ventspils
Joined Jan 2010
Now not everyone will agree with me but here goes :
a) Control rods : I prefer combination rods of wood centre and then metal rod ends, but that's on big models where you have space in fuselage to fit. My next is bowden cable in tube ... bicycle cable and outer basically ... with soldered on threaded ends.
Third would be wire rods in tubes as many are fitted with today.
If it is all metal rod - then the best is to mount servo as close to surface as possible to shorten the rod.
b) Clevis - this is a matter of real personal preference but I'll give my 2 cents worth.
I used to use metal clevis wherever possible .. usually Dubro or similar. But stopped using them as they all tended to lose the springiness and 'arms' bent.
I changed to plastic / nylon with metal pins through for my large models, and all plastic / nylon for lesser ... Why ? They kept their springiness .. the metal pin versions were definitely strong enough, the smaller were self-locking ...
If a pin or locking failed - they're cheap enough to have a box full and change.
I haven't mentioned the rod to screw retainer that a lof are appearing with. A barrel with nut to the control horn .. pass control rod through .. tighten screw. Brilliant idea .. all my EDF's have them ...
If anyone doubts the strength of nylon / plastic clevis - then I dare this :
Connect up a rod / clevis and get an old crashed model ... connect clevis to a surface. Now pull on the blighter - I bet the surface or horn gives way before the clevis.
There is a final comment as well ... I prefer Z bends inside the model - as they are far better than any clevis for permanent fixture ... and you only need one end for adjustment - better to keep that accessible outside.
Nigel
solentlife is online now Find More Posts by solentlife
Old Sep 09, 2012, 05:45 AM
Waltjg is offline
Find More Posts by Waltjg
Waltjg's Avatar
Crystal River Fl.
Joined Jul 2008
I don't use any! I use Z bends, when set up properly, light, simple, and no failure issues. I always try and place my servos close to the flight surface and they work very well with small diameter wire. W
Waltjg is offline Find More Posts by Waltjg
Discussion Metal or plastic case for DJI F450 jasper7821 Multirotor Talk 1 Jul 10, 2012 05:14 PM
Discussion Wooden props or nylon/plastic props. Jam1e Fuel Plane Talk 16 Mar 10, 2012 08:32 AM
Discussion metal pushrod to plastic clevis MrBen. The Builders Workshop 6 Feb 15, 2011 04:10 PM
Sold glow airplane parts, servo screws, pin hinges, servo arms, metal/nylon clevis, axles justplainold Aircraft - General - Miscellaneous (FS/W) 2 Apr 10, 2010 07:12 PM
Wanted 8 -32 plastic or nylon bolts with hex head or allen heads BrianSmith Aircraft - General - Miscellaneous (FS/W) 3 Mar 28, 2009 06:28 AM
