Espritmodel.com Heli Air
Old Aug 29, 2012, 09:53 AM
Live FPV or Die
VRflyer's Avatar
Montreal,Canada
Joined Feb 2002
Easystar II FPV (new version from Multiplex)
Last time I ordered an Easystar, I received the new version. I prefer this new version, the motor mount is better made, removable stabilizer, longer fuselage etc. Everything look good quality. No motor included
My setup:
motor: unknown
ESC: 30A with BEC use for all servos
prop: folding prop included with Easystar
receiver: Sherrer 8ch
Lipo: 2200mAh
Video will be add after maiden flight will be done
Camera: RCV922 (linear reg use to lower to 5V)
transmitter: 900Mhz 500mW (freq:1040Mhz)
antenna: dipole hand made
panning servo: HXT900 modified with two resistors
VRflyer is offline Find More Posts by VRflyer
Old Aug 29, 2012, 10:05 AM
Project Tormentor is flying!
United States, WA, White Salmon
Joined Nov 2005
Very clean build! Looks like its going to be a fun ship! So how do you like the 3d video easystar? Does the 3d video help with flying low and around obstacles?
philthyy is offline Find More Posts by philthyy
Old Aug 29, 2012, 10:22 AM
Live FPV or Die
VRflyer's Avatar
Montreal,Canada
Joined Feb 2002
I love it very much, the 3D view is awesome and work really well. It does not help to fly around obstacle because it miss me the headtracker for that purpose. But the view in 3D when I fly thrue obstacles is amazingly cool. I don't use 3D goggle available on the market, mine as been modified to get two video input jack, so I use two Tx onboard the plane and two rx on ground
now go back to the Easystar II. if you have any questions about 3D, send me a PM
Old Aug 29, 2012, 10:27 AM
Joined Nov 2005
Heh. Sorry, didn't want to hijack the thread! So, on the Easystar II, I like how clean the dipole is. BUT, I am extremely happy with my BlueBeam set (at 2.4ghz) on my Multiplex Mentor. How well does the dipole work? Have you tried CP antennas?
Old Aug 29, 2012, 11:49 AM
Live FPV or Die
VRflyer's Avatar
Montreal,Canada
Joined Feb 2002
I'm very satisfy with the result I got with simple dipole antenna cut at the good lenght, very few video dropout in direct line of sight up to 1km, so I never tried the cp antenna. I never go beyond 1 km.
I forget to say that I don't use the standard 900mhz receiver, I prefer far more the Lawmate receiver with the standard dipole sell with it, but it have only two channels compatible. The receiver is mount on my headset.
Old Aug 30, 2012, 02:50 PM
Shadrack's Avatar
Winnipeg
Joined Feb 2002
Looks great VR. Will be copying. What is flight time with the 2200?
Shadrack is offline Find More Posts by Shadrack
Old Aug 30, 2012, 03:10 PM
Live FPV or Die
VRflyer's Avatar
Montreal,Canada
Joined Feb 2002
10 min at full power and around 25 with no wind with my previous easystar and the same setup
Old Aug 30, 2012, 03:59 PM
AP-stick
ggtronic's Avatar
Montreal
Joined Nov 2005
subscribe...
nice built ! lots of good idea...
ggtronic is offline Find More Posts by ggtronic
Old Aug 30, 2012, 04:23 PM
Live FPV or Die
VRflyer's Avatar
Montreal,Canada
Joined Feb 2002
Originally Posted by ggtronic View Post
subscribe...
lol
thank my friend. You will try it yourself next time we fly together
Old Aug 30, 2012, 07:32 PM
North vancouver, B.C. Canada
Joined Apr 2008
Looks great I want one too
David22 is offline Find More Posts by David22
Old Aug 30, 2012, 10:04 PM
Shadrack's Avatar
Winnipeg
Joined Feb 2002
what size battery will it hold stock? Heard there is a bigger area for the battery. How about CG adjustment?
Old Aug 30, 2012, 10:43 PM
Live FPV or Die
VRflyer's Avatar
Montreal,Canada
Joined Feb 2002
the nose is longer, but it make no advantage for heavier battery because heavier battery will need to be install more in the back of the fuse and you will need to remove foam to install a battery there.
In fact it would fly well with lighter battery that we can install way in front insidethe nose. 1000mah would last around 10 min in no wind condition. not very usefull...
Old Aug 30, 2012, 11:29 PM
Joined Apr 2008
2200 4 cell in orrigional ez star flys easy 35 minutes
This is with motor on all the time
It's all I your motor and prop choice
But most important is aerodynamics
Good combo of motor and bat and prop makes Ezstar fly long time
Wind also makes world of difference, as high winds make for shorter flight times
To heavy increase amp draw so not to large battery
2200 4 cell works great! Fly fast at low amps
Nice weight for Ezstar
Old Aug 31, 2012, 11:07 AM
snelan's Avatar
Joined Jul 2012
Awesome plane man! Probably one of the cleanest FPV planes I've ever seen. Definitely the cleanest Skysurfer/Easystar/Bixler!
The only concern I have is with that door on the bottom on hard landings. After a while it may become bent, or snapped, etc.
Also, you may want to make that dipole a vee, it'd be pretty simple and you could probably still fit it on the tail from looking at the pics. Even just a very slight vee improves banking video quality.
snelan is offline Find More Posts by snelan
Old Aug 31, 2012, 12:04 PM
United States, FL, Palm Beach
Joined Jan 2011
Cool. Which seller did you buy the kit from?
viper522 is offline Find More Posts by viper522
Sold PRICE REDUCED Multiplex easystar II EBerris Aircraft - Electric - Airplanes (FS/W) 2 Jun 28, 2012 12:14 PM
Sold Multiplex EasyStar Receiver Ready Version davew478 Aircraft - Electric - Airplanes (FS/W) 1 May 05, 2012 06:40 PM
Sold Multiplex EasyStar Kit Version davew478 Aircraft - Electric - Airplanes (FS/W) 5 May 05, 2012 03:33 PM
Help! Easystar II - which version? kjur Beginner Training Area (Aircraft-Electric) 13 Apr 04, 2012 08:36 PM
Discussion Multiplex EasyStar I & II 2011 - A discussion of anything EasyStar & sometimes more kevinhines Foamies (Kits) 9413 Dec 31, 2011 07:57 PM
