Old Aug 29, 2012, 09:12 AM
WyDiablo is offline
Find More Posts by WyDiablo
Arkansas
Joined Jul 2008
Dji f550
Currently I fly the DJI F550 naza with DX7 and AR7010 rx. On 9-8-2012 I will order the gps upgade. I have not installed the AR7010 as of yet I"m waiting on my gps right now. Soooo the question is how to go about setting up the failsafe on the AR7010 and setting my DX7 up with the gps. I have a video on how to attach the gps to the hexa but nothing more. I think I will need my flight mode switch for the Att/Failsafe/man mode and my gear switch for gps correct.?
WyDiablo is offline Find More Posts by WyDiablo
Old Aug 29, 2012, 09:22 AM
Tahoe Ed is online now
Find More Posts by Tahoe Ed
DJI Support
Tahoe Ed's Avatar
Las Vegas/Lake Tahoe
Joined Feb 2010
You need your flight mode switch for Man/ATTI/GPS or you cannot calibrate the compass. You can use Aux 2 for IOC and set a mix on the Gear channel for RTH/Failsafe.
Tahoe Ed is online now Find More Posts by Tahoe Ed
Site Sponsor
Old Aug 29, 2012, 10:31 AM
rampa202 is offline
Find More Posts by rampa202
United States, MD, Annapolis
Joined Jun 2011
Does a DX7 not have two 3-position switches?
rampa202 is offline Find More Posts by rampa202
Old Aug 29, 2012, 11:54 AM
edugimeno is offline
Find More Posts by edugimeno
United States, MI, Rochester Hills
Joined Aug 2012
What I did was setting up a 3 position channel and make sure with End-Points that the 3 positions matched the areas for Manual-Atti-GPS. That's pretty easy to do with the Naza Assistance software.
Then I made a mix on another 2 posi switch so it added a percentage to the Mode switch, so it made it shift to a Fail Safe area. Again easy with the naza sw.
With this you can already invoke the manual naza-built-in failsafe mode. Also you will want to setup the automatic Fail Safe in case you lose range in the TX or it gets an interference. For that you will have to set the switches in the way they tripped the Fail Safe mode, and do whatever functions your receiver needs to be set to FS.
Then check at home with the Naza Assistant sw, go to the TX calibration page, turn your TX off and check that the slider for the Mode gets into the FailSafe area.
edugimeno is offline Find More Posts by edugimeno
New Product DJI-F550 Hexa ARF+NAZA Kits Now in Stock At RcHobbyHelicopter johnIn2SonAZ Multirotor Talk 4 Feb 10, 2015 09:19 AM
Discussion DJI F550 Hex Build, with 2-axis NEX-5N/GH2 Gimbal... GGoodrum Multirotor Talk 9560 May 27, 2014 11:06 PM
Build Log DJI F550 NAZA ARF COMPLETE BUILD and DJI NAZA ASSISTANT w/ TX CALIBRATION >VIDEOS< patrick21x Multirotor Talk 11 Nov 30, 2012 07:13 PM
Discussion DJI F550 Hexa Custom Build by AddictiveRC johnIn2SonAZ Multirotor Talk 31 Mar 18, 2012 04:23 PM
