Old Sep 01, 2012, 05:25 PM
razortoe is offline
Find More Posts by razortoe
Keep it Simple Stupid
razortoe's Avatar
United States, NC, Raleigh
Joined Jul 2011
Originally Posted by AvB View Post
Pdawg, Troy would be the guy to advise, but from watching his video I think you'd pour then stand the mould with the tip down, and let it fill to the root.
With such a short span, this might work. If i understand correctly though, unless you smear it around all inside surfaces, it won't adhear well to the wing skins. I also remember reading earlier in this thread that, letting it expand out from a puddle doesnt work so well. But please feel free to give it a try and proove me wrong.
razortoe is offline Find More Posts by razortoe
Old Sep 01, 2012, 05:36 PM
AvB is offline
AvB
Find More Posts by AvB
AvB
Wind, hill, ... I'm keen ...
AvB's Avatar
Australia, QLD, Woody Point
Joined Nov 2006
Actually I think that's probably correct. With small panels you shouldn't have any problem doing it within the working time. Smearing it quickly while it's runny means you get good bonding to the surface all over, and the greatest amount of expansion. If you can do that and join them quickly as I did you should get a great result.
AvB is offline Find More Posts by AvB
Old Sep 01, 2012, 08:27 PM
emufingers is online now
Find More Posts by emufingers
I hate propellors
emufingers's Avatar
Australia, SA, Normanville
Joined May 2009
Good to see the foam experiments.
There are plastic self mixing applicators available, but I haven’t been able to get a price. If they were reasonably cheap it would be possible to inject the mix into the closed mould and let it free rise against gravity to the open end of the mould.
There are lots of different foams. Here are some interesting ones. They are all about $25-35 per litre. If the RF100 is not too dense to produce a lightweight wing its hard skin properties would make it very interesting.
Ecofoam MF710 (free rise density of 71 kg/m3) is a two part polyurethane system that comprises of a polyol and isocyanate component. When mixed in their correct proportions produce fine-celled foam . This product is water and HFC blown. The system is designed for use in moulding applications where good skin is required. The foam can be used for moulding components such as imitation wood, computer cabinets, shoe heels as well as for moulding fishing lures. The product can be manually drill mixed (@ a minimum speed 2000 rpm) or processed through a polyurethane foam dispensing equipment.
RFOAM35 is a rigid foam used in applications requiring either thermal insulation or good boyancy properties. Commonly used as void fill in boats, surf skis and moulded fibreglass building panels. Available in 2kg, 10kg & 50kg. Rise density of 35kg/m³
RFOAM100 Rigid Foam 2kg
96kg/m³ - Rigid foam designed for self skinned or structural components. Apart from the hard skin, the final mouldings have high softening temperature combined with high compressive and flexural strengths. Available in 2kg, 10kg & 50kg.
emufingers is online now Find More Posts by emufingers
Old Sep 01, 2012, 09:28 PM
AvB is offline
AvB
AvB
AvB's Avatar
Joined Nov 2006
Need to check out the other foams. Working time is important .. the guy I spoke to said that the higher density foams have shorter working times than the GP330. The GP330 was also available in small quantities ... I think it was $22 for 2 x 500mL tins of polyol and iso. But I hope we can find something with a longer working time.
Old Sep 01, 2012, 10:02 PM
I hate propellors
emufingers's Avatar
Joined May 2009
The technical sheets on these foams are availabkle on the AMC supplies site.
Old Sep 02, 2012, 05:04 AM
two stroke is offline
Find More Posts by two stroke
two stroke's Avatar
Slovenia, Kamnik
Joined Jan 2011
Hi guys!
I also make PU filled wings and tails for stormchaser...
I use 200kg/m foam its realy hard!,i joining the molds with wet seam and layups,i think thats importat you have a realy good wettet layups with epoxy that you want a joint it provide good PU and layup bond.I also make LE edge close with carbon stips so the LE edge is no delaminating and makes LE edge bullet proof
The PU foam cost me 35€ for 2kg-for a wing i use 340g so its cheap..
Simon
two stroke is offline Find More Posts by two stroke
Old Sep 02, 2012, 05:57 AM
AvB is offline
AvB
AvB
AvB's Avatar
Joined Nov 2006
Simon, it was you describing the use of the PU in your Stormchaser that motivated me to try PU!
Old Sep 02, 2012, 07:59 AM
JIM CALDWELL A is offline
Find More Posts by JIM CALDWELL A
Cleveland Cuyahoga, Ohio, United States
Joined Dec 2000
Good foam info here;
http://www.shopmaninc.com/foam.html
JIM CALDWELL A is offline Find More Posts by JIM CALDWELL A
Old Sep 02, 2012, 09:26 AM
I hate propellors
emufingers's Avatar
Joined May 2009
If the foam is suitable this system is ideal. Two part foam with a mixer dispenser gun. A small kit that would do about 5 two meter wings for under $40 inlcuding the gun.
Check out the videos to see the control that the gun gives.
http://www.abbuildingproducts.com.au...os-pa-2819.php
and its in Australia
Old Sep 02, 2012, 11:26 AM
pdawg is offline
Find More Posts by pdawg
Need 4 Speed!
pdawg's Avatar
United States, OH, Dayton
Joined Apr 2004
Emufinger,
The idea of being able to spray the foam in the mold is amazing! Correct me if I'm wrong but from what I've read so far, based on AvB's initial experience and Troy's post and BjB video, the insulation type foams may not be ideal?
pdawg is offline Find More Posts by pdawg
Latest blog entry: Visiting Edwards AFB
Old Sep 02, 2012, 01:10 PM
jirvin_4505 is offline
Find More Posts by jirvin_4505
working to the closest cm
jirvin_4505's Avatar
brisbane australia
Joined Nov 2002
Very nice foam application!
Hey that is some very cool videos - the controll of the foam application looks amazing.
Thanks to Avb reference to two stroke's posts I had an enjoyable time going through the crunchy planks thread. Some very cool PU stuff going on!
Reading there I was reminded of a technique of soaking ordinary sponge in epoxy and wringing it dry to use as a space filling method. I used it many years ago to stiffen up the rearend of power plane fuselages.
Not sure of the mechanical properties? I do recall that it was susceptible to delaminating but it was a very limited application. In the crunchier plank thread there is reference to using it as a filler in vertical tails.
(to do... Add links)
Cheers Jeff
jirvin_4505 is offline Find More Posts by jirvin_4505
Old Sep 02, 2012, 01:23 PM
A10FLYR is online now
Find More Posts by A10FLYR
Dean
A10FLYR's Avatar
USA, CO, Littleton
Joined Apr 2005
I think that foam lacks rigidity. Seems to me you can prchase it in a rattle can from Home Depot.
A10FLYR is online now Find More Posts by A10FLYR
Old Sep 02, 2012, 03:25 PM
razortoe is offline
razortoe's Avatar
Joined Jul 2011
My spray-foam insulation guy explained there are several different kinds they use. There's a slower kicking door-and-window foam, which when cured reminded me of slightly rigid cotton-balls. i.e. no good for us.
He says the kind they typically spray in between open-wall studs (sheeted on one-side only), is 1lb/ft³ but it kicks in 2-seconds. Again, no good for our purposes.
The spray insulation available here is called 'Great Stuff'. Whatever it's density is, it kicks almost instantly, so no good.
That spray gun looks useful, though from the vids, the foam seems to kick really quickly. There's no mention of the mix ratio used in the kits not whether it's adjustable. If you wanted to use your own foam, you'd have to feed it from a pressure pot of sorts. Seems it would be a good setup if you were doing this for production. I'm not sure how useful it would be for hobby use.
From my reading, the higher-density foams seem to have a longer pot-life. Since 4 or 6 lb density was already suggested, the longer time may be just the ticket. Though it'll certainly be a heavier wing.
Old Sep 02, 2012, 08:51 PM
I hate propellors
emufingers's Avatar
Joined May 2009
From what I can see, the gun does a fixed 50:50 mix, which woukld suit most of the foams on the market. It is a low pressure gun so this is what I am thinking.
Get hold of a gun.
Get two small old lpg cylinders
Place the ingredients of you selected foam in each of them
Drill extra holes in the walls of the tanks and fit a compressed air fitting to be supplied from compressor. They are easy to drill btw)
Hang the tank upside down, or modify the tap assesmbly to draw from the botton of the tank ( an extension tube)
Connect the gun to the usual threaded outlets. Use standard gas fiittings to convert
Start on a low pressure say 10 psi and work up until desired spray pattern is achieved.
The gun bleeding technique in the videos should still work
There is also a solvent for PU foam advertised if things go hard.
Voila a mixer gun for fifty bucks and 15 litres iof handi foam to insultate you hot box.
Old Sep 02, 2012, 08:59 PM
AvB is offline
AvB
AvB
AvB's Avatar
Joined Nov 2006
I am happy with the technique I used, and I think the benefits of full-area-spreading the mixed liquid and closing the wing mould are 1) best possible adhesion of foam to skin; and 2) you can use a light foam but get some compression of the expanded foam in the mould (back pressure) which increases the density against the skin, which is where you need it most. The only issue with the technique was the need to work fast and have extra hands, but that's doable. I'm planning to do more with the technique and the only thing I'd like to change is to source a foam with a longer working time. The RFOAM35 seems to have a slightly longer foaming time - 30 secs longer if their figures are accurate, which could help. But for me, at this point there's no problem to solve ... the technique has produced a good result and I'm sure that with more refinement I can get it even better.
Discussion Dow 1/2" super rigid foam Polyisocyanurate Rigid Foam Insulated Sheathing inline300 Foamies (Scratchbuilt) 7 Aug 15, 2009 05:55 PM
Discussion Moulded Wing, or Foam Core...Which Do You Prefer? Kenny Sharp Hand Launch 10 Nov 13, 2006 04:38 AM
Discussion Rigid Polyurethane Foam wing cores? moreil Hand Launch 9 Jul 11, 2006 04:01 AM
