Old Aug 30, 2012, 03:49 AM
HELModels is offline
Find More Posts by HELModels
HELModels's Avatar
Joined Aug 2003
Here's an idea for you. I've had good luck with polyurethane glues and molds. I brushed a thin layer in the painted mold and when tacky, placed polyurethane wetted cloth. Works. I noticed a few voids where I didnt brush it even, but that's easy to prevent with good eyes.
I've also mixed microballoons and polyurethane glue into a shaving cream consistency and used it as a filler. It doesnt expand much. I've often thought it might be capable of a wing, if the right density mix could be found. I have a lost foam pod where I used it as a filler for the wing saddle and there was a lot to fill.
HELModels is offline Find More Posts by HELModels
Old Aug 30, 2012, 04:36 AM
Shedofdread is offline
Find More Posts by Shedofdread
Deniable plausibility
Shedofdread's Avatar
Derbyshire, UK
Joined Aug 2008
In the past, I've done the 'half cores into moulds' method and found that works very well but never had much luck with poured polyurethane cores. However, recently refurbishing an elderly Robbe ASW19, I noticed the cores for those were PU but with veneer skins (and in parts, had gone a little crumbly).
Anyone know how they're done? I thinking the cores need to moulded first then put into another mould with the veneer skins and pressure applied to bond the whole lot together...?
Shedofdread is offline Find More Posts by Shedofdread
Old Aug 30, 2012, 08:04 AM
timbuck is online now
Find More Posts by timbuck
Nothing is easy
timbuck's Avatar
gold coast australia
Joined Aug 2008
In my PU wing I did suffer from crumbling aswell.
Also did have problems with moisture and warping.
I guess ??? Moisture in the wing when wing gets hot expands and warped wings.
This only happens on thin lay up's.
I like the concept of molded cores for light wings.
Another tip...
For every 10'c of temp PU expands twice as fast.
Cooling it Does help...put it in the fridge before you mix it. At a cost of high density..
Tim
timbuck is online now Find More Posts by timbuck
Latest blog entry: More colours
Old Aug 30, 2012, 05:27 PM
josh18 is offline
Find More Posts by josh18
608 km/h!
josh18's Avatar
Australia, QLD, Toowoomba
Joined Jan 2010
Tim, when you put foam into both halves and trimmed later with a wood saw, how did your mould flanges go? I wouldnt mind giving this a go but cant work out the best way of trimming the foam nice and flush without wrecking the mould flanges.
I use a router to trim my spar caps flush with the flange, and thought this might work but the caps are right in the middle of the mould. Routing near the edges of the mould fills me with fear!
I love the sound of foam filled wing moulds (PU and Ampreg) but both seem to come with so many uncertainties and variables. You and Andrew do great actually trying out all these ideas- I always think yeah!...and then no, what if this or that happens.
josh18 is offline Find More Posts by josh18
Old Aug 30, 2012, 06:24 PM
Nothing is easy
timbuck's Avatar
Joined Aug 2008
Nothing...
It's not like you are sawing through a tree. You cut across the wing in a few slices. Cuts like butter.
BUT , I did start off putting tape around the flange.
Doings it this way there are NOT many variables. You don't have to do it all in one piece. In a larger wing do it in 3 or 4 parts. Makes it very easy. If you need a bit more, or you have a hole etc. Just add more.
And in warm conditions , you have all the time in the world to work as you do not have to close the mold.
Also most PU's expand properly above room temp, so you get better expansion lighter wings.
I where to do one again now. I would do it open mold...cut it off , add spars ( carbon sock).. Dig a channel around the LE about 10 to 15mm wide fill with ampreg and close the mold.
You would end up with a wing similar weight to a light v- bagged wing but with better molded Finnish , with a bullet prof LE.
And it would be repeatable every time, variables to a minimum..
Old Aug 30, 2012, 06:42 PM
razortoe is offline
Find More Posts by razortoe
Keep it Simple Stupid
razortoe's Avatar
United States, NC, Raleigh
Joined Jul 2011
After watching the video and considering the alternatives / opinions above, I think the free-rise foam in separate halfs with post-trim joining is the way to go. Much more control, more consistent density, zero voids, and more importantly - less stress
What about making a crappy mold/jig only used to help guide the foam trimming. The mold could be made from high-density, no-skin, flexible foam. It just needs to hold the wing half in alignment and help you cut.
In place of flanges, you could mold in PU-resin guide-rails. PU stands up well to abrasion, and the rails could be made to be replaceable. Their job would be purely to help support and guide a long flush-cut saw blade (no tooth-set) for final trimming.
razortoe is offline Find More Posts by razortoe
Old Aug 30, 2012, 07:44 PM
josh18 is offline
608 km/h!
josh18's Avatar
Joined Jan 2010
Thanks guys- all these ideas are starting to sound VERY apealing! I layed up some tail skins last night. I will do the fill and join today.
Old Aug 30, 2012, 09:54 PM
Troy is offline
Find More Posts by Troy
Caution:Makes sharp left turns
Troy's Avatar
United States, CA, Lake Forest
Joined Feb 1999
Originally Posted by AvB View Post
Wow that video is excellent! Very very well done and great info. It answered a few questions (eg the bit about side drag against the container, and the bits about orienting vent holes ... ) Thanks heaps Troy.
A lot of questions ran thru my mind while watching it.
1) The effect of humidity ... we get a lot of variation, from over 90% in summer to down to 23% in westerly winds. Hmm, I wonder whether that's a big problem? And if so, how to manage it?
2) Colouring of the foam sounds interesting ... a white foam colour under a glass skin would provide a good light coloured backing so that you could use less yellow/ white paint.
3) Most importantly, from your experience Troy, if you were doing this, how would you do it? Basically I want to be able to lay up the wing skins in the mould ... I guess it's best to cure them first ... add the various hardware, and then add foam to fill the thing and close the mould and have it fully expand. A few bubbles etc aren't going to be a big deal ... the foam is there to support the skins and to absorb impacts. Are there better types of foam? Are there foams with longer working times??? I'd really appreciate any advice. I guess it's possible that there are no PU foams that will provide the answers, and maybe I'll go back to vac bagging blue foam half-cores in place etc. But I'd like to check out all the options. I'm after simple methods that can be done in the back shed, that provide durability ... and a 98% result rather than perfection.
I think I would use a higher density foam, do an open rise on each half, and trim to the flanges. I actually have some skins in a wing mold that are waiting for me to do this. I have tried to inject foam with the molds closed but I didn't have enough working time. It would work much better if I had one of our meter-mix dispense equipment set up with foam. But I also want to see how it can be done without equipment.
Troy is offline Find More Posts by Troy
Old Aug 30, 2012, 10:46 PM
Jim.Thompson is online now
Find More Posts by Jim.Thompson
Entropy is happening!
Jim.Thompson's Avatar
Australia, NSW, Bellingen
Joined Aug 2008
Crumbling problems.
Originally Posted by Troy View Post
I think I would use a higher density foam, ............
Is the higher density foam likely to crumble less as has been reported several times here Troy? Do you know?
That is the only thing that concerns me at all with the method. I am tempted to give it a go myself. Maybe the hot wire cut blue foam cores method first.
Jim.
Jim.Thompson is online now Find More Posts by Jim.Thompson
Old Aug 31, 2012, 04:50 AM
josh18 is offline
608 km/h!
josh18's Avatar
Joined Jan 2010
Hey, I did an open pour this arvo and cut it off with a hacksaw- no worries. I joined them with PU and now Im just waiting for it to dry. Looks pretty promising!
My foam is a pretty high density- 96kg/cubic metre (does that sound right?) Anyway it sets very hard, not like Ampreg sounds, but heaps harder and stiffer than blue foam. It doesnt seem that brittle either.
So I'll see what happens when I crack it open!
Old Aug 31, 2012, 05:07 AM
AvB is offline
AvB
Find More Posts by AvB
AvB
Wind, hill, ... I'm keen ...
AvB's Avatar
Australia, QLD, Woody Point
Joined Nov 2006
I've been thinking I can't judge much about my wing till the control surfaces are cut. I just did them now. There are no bubbles along the cut edges, none at all. I am really surprised ... I thought most likely there would be the odd void, but the foam is really very homogeneous all along. And it seems to have lost very little in bend and torsional rigidity after cutting the hingelines. This is a good wing.
Great work Josh. You're covering a lot of ground fast!
AvB is offline Find More Posts by AvB
Old Aug 31, 2012, 05:45 AM
josh18 is offline
608 km/h!
josh18's Avatar
Joined Jan 2010
Thanks Andrew, I popped it just before and Im happy to say Im VERY happy with it! It seems very tough and is really stiff. Its heavy, but Its made with 879gsm quadraxial glass which Ive also been playing around with. I dont know why I didnt try foam filled wings long ago- its so easy and seems to come out so good! I reckon Im gonna get the scorcher wing mould ready to make a wing this way tomorrow.
Heres a pic
Old Aug 31, 2012, 05:57 AM
AvB is offline
AvB
AvB
AvB's Avatar
Joined Nov 2006
879gm!! That's insane!
Old Aug 31, 2012, 06:57 AM
Nothing is easy
timbuck's Avatar
Joined Aug 2008
Sweet josh well done.
96kg is what I used to use. And I agree, it doesn't crumble nearly as much. Hurry up and make a PUorcher ..
Tim
Old Aug 31, 2012, 09:26 AM
Troy is offline
Troy's Avatar
Joined Feb 1999
Cool stuff Josh.
Discussion Dow 1/2" super rigid foam Polyisocyanurate Rigid Foam Insulated Sheathing inline300 Foamies (Scratchbuilt) 7 Aug 15, 2009 05:55 PM
Discussion Moulded Wing, or Foam Core...Which Do You Prefer? Kenny Sharp Hand Launch 10 Nov 13, 2006 04:38 AM
Discussion Rigid Polyurethane Foam wing cores? moreil Hand Launch 9 Jul 11, 2006 04:01 AM
