Old Oct 31, 2012, 10:03 PM
AUSELECTRIC is offline
Find More Posts by AUSELECTRIC
Joined Nov 2004
Well AvB is looking at DS and Slope flying where crashing is inevitable
Mick
AUSELECTRIC is offline Find More Posts by AUSELECTRIC
Old Nov 01, 2012, 02:43 AM
AvB is online now
AvB
Find More Posts by AvB
AvB
Wind, hill, ... I'm keen ...
AvB's Avatar
Australia, QLD, Woody Point
Joined Nov 2006
Agreed Razortoe, those are wise words. But John's point is correct ... my passion is building tough planes. I doubt that anything much I do is going to get "out there" because I'm finding the building process incredibly difficult and I can't see myself keeping it up with the amount of energy I've put in in the last year or 2! But if in the future anybody ever had anything nice to say about my planes, I'd like it to be "man those planes were tough!"
I was just saying to Asto today that designing and building the Scratchos was the thing that took my DS skills up quite a few notches over the last year and a bit ... just being able to put in so many hours flying, crash landing into the lantana etc, with little or no repair work.
Every SCratcho wing made so far is still intact and flying! (except the light PU one). Well, 6 of them are flying and 2 have yet to be flown. Several of them have survived big crashes and got back in the air with very little work. Hard foam cores, fibreglass rod leading edges, Innegra hinges and expanding epoxy foams (in various combinations), and PU foam filled fuselage booms are the way to go!
AvB is online now Find More Posts by AvB
Old Nov 01, 2012, 03:43 AM
josh18 is offline
Find More Posts by josh18
608 km/h!
josh18's Avatar
Australia, QLD, Toowoomba
Joined Jan 2010
Hey Andrew I agree with you too. Even though I dont build full cores like you, all my layups are pretty beefy, and like you all my wings are still intact. Nearly all have been crashed and a couple really bad. A tough plane is worth two I reckon because you can just keep flying them when normal ones would be busted- Along with your wallet!
josh18 is offline Find More Posts by josh18
Old Nov 08, 2012, 06:22 PM
AvB is online now
AvB
AvB
AvB's Avatar
Joined Nov 2006
More on the goodness of the expanded-in-mould PU core.
I reported recently that I'd busted the wing on the light PU wing Scratcho, and that the weak link in the construction was that the edges are not locked together. The PU is not a strong bond. This was proven in that crash when the skin really opened up and peeled off like a banana skin from the wingtip.
Anyway … I thought the busted wing was a throwaway, but Rhys looked at it and said “so why don’t you just cut both wingtips shorter ?” So I did, very roughly and quickly, using an old Caracho tip as a template for tapered tips, hacking and gouging and just taping the skins together. The damn thing flew brilliantly – that’s another story … http://www.rcgroups.com/forums/showt...09787&page=873
What I wanted to show here is how good the cut off tip is. This piece was just hacked off quickly with multiple slices of a Dremel disc, so there’s black carbon dust in the surface. You can also see in cross section the 2 x 1.3mm thin f/glass kite spars stuck under the skin.
I wish you guys could pick this piece up and feel it, because it is just totally stiff. If that was blue foam, you’d be able to twist it a bit. This piece is amazingly light and stiff. I am really impressed. Remember, the skin is one layer of 120gm carbon and one layer 100gm glass. The skin in the other photo is a piece from the busted side.
I am sure that this method has great potential. Such a fast method, so much stiffness for a light layup and light weight. No need for a spar. But we have to lock the edges together. When I get the time I’m planning to do the following:
Lay up and cure skins. Trim and put mixed PU in both sides (this step needs a few guys on hand to get coverage within 40 seconds or so from mix) then put a waxed mylar splitter plate over one half, put the other half on top, and clamp together. Unclamp in an hour or 2, peel off the mylar, and you'll have 2 flush fitting sides fully solidly pressure-filled with PU foam. Then scrape the foam back a few mm from the edges all around. Dribble a bead of Sicomin 170 around the edges. Join the mould again and I’m sure the final result will be one of the strongest light wings ever made
Old Nov 08, 2012, 10:41 PM
threcixty is offline
Find More Posts by threcixty
Not landing late ever again
threcixty's Avatar
United States, TX, Frisco
Could you mist the skins with epoxy, or something compatable with PU, to make the bond stronger?
threcixty is offline Find More Posts by threcixty
Old Nov 08, 2012, 11:33 PM
AvB is online now
AvB
AvB
AvB's Avatar
Joined Nov 2006
The PU is adhered to the skins OK. It's the bond between the top and bottom skins, where they are butted up next to each other at the mould join, that needs to be made strong. Normally in a hollow mould method you'd put splooge around the edges and have it hold the 2 halves together, but the pressure of the PU expanding in this method will just push any such goo out of thru the join and into the flange area.
Old Nov 09, 2012, 07:46 PM
Odysis is offline
Find More Posts by Odysis
Life begins at transition
Australia, VIC, Sale
Joined May 2007
I've seen a build where a small strip of depron is used to hold the splooge in place. Maybe it'll act as a plug to stop the PU pushing and splooge out?
Odysis is offline Find More Posts by Odysis
Old Nov 09, 2012, 11:26 PM
AvB is online now
AvB
AvB
AvB's Avatar
Joined Nov 2006
Actually that's a good thought. You could use a thin socked foam rod, wet out and place behind the LE.
Old Nov 09, 2012, 11:42 PM
Odysis is offline
Joined May 2007
Yup, who am I to argue with Herr Huf?
http://www.su27.de/seite30.htm
He's not pumping it full of foam, but the idea's pretty similar...
Old Nov 10, 2012, 01:11 AM
timbuck is online now
Find More Posts by timbuck
Nothing is easy
timbuck's Avatar
gold coast australia
Joined Aug 2008
Now that's alot of work.. amazing.
timbuck is online now Find More Posts by timbuck
Latest blog entry: More colours
Old Nov 12, 2012, 09:39 PM
ALEX HEWSON is online now
Find More Posts by ALEX HEWSON
Remember... Fly for fun!
ALEX HEWSON's Avatar
Christchurch, New Zealand
Joined Jul 2005
Well Rob found a great product here recently. Its called Endurathane.
It holds together very well and hasn't got the brittle characteristics of other 2 part PU foams I have seen. It comes out a cross between high density EPS and EPP. But super light.
Oh and nice tight beads. The warmer you cure it, the closer the cell structure
I'm going to use it for my RT42s
ALEX HEWSON is online now Find More Posts by ALEX HEWSON
Old Nov 12, 2012, 09:42 PM
Jim.Thompson is online now
Find More Posts by Jim.Thompson
Entropy is happening!
Jim.Thompson's Avatar
Australia, NSW, Bellingen
Joined Aug 2008
What impressive work!
Jim.Thompson is online now Find More Posts by Jim.Thompson
Old Nov 12, 2012, 09:58 PM
AvB is online now
AvB
AvB
AvB's Avatar
Joined Nov 2006
Alex, checking out the tech pdf sheet, Endurathane looks exactly the same as the Erapol GP330 I used.
Old Nov 12, 2012, 10:00 PM
AvB is online now
AvB
AvB
AvB's Avatar
Joined Nov 2006
Here are the tech sheets:
Old Nov 12, 2012, 10:11 PM
Joined Jul 2005
Just put some into my first RT42 fuse, and mixed up another batch, curing at 38 degrees C.
Wondering if there is a magic temp to cure at...
Discussion Dow 1/2" super rigid foam Polyisocyanurate Rigid Foam Insulated Sheathing inline300 Foamies (Scratchbuilt) 7 Aug 15, 2009 05:55 PM
Discussion Moulded Wing, or Foam Core...Which Do You Prefer? Kenny Sharp Hand Launch 10 Nov 13, 2006 04:38 AM
Discussion Rigid Polyurethane Foam wing cores? moreil Hand Launch 9 Jul 11, 2006 04:01 AM
