Old Aug 29, 2012, 01:21 AM
alan2 is offline
Find More Posts by alan2
Joined Aug 2012
Help. Cannot get started with Flamewheel and DJI
Help!
Have installed DJI Naza into Flamewheel 450 (in fact bought them as a package). Cannot get the RX and TX to bind or proceed with the Assistant Software. For example, don't know the serial number although the instructions say 'already entered' it does not appear on the software screen.
VU shows steady green but no apparent communication from theTurnigy 9X to its companion receiver (I suspect it's something I am doing wrong with the Turnigy...)
alan2 is offline Find More Posts by alan2
Old Aug 29, 2012, 08:48 PM
rampa202 is offline
Find More Posts by rampa202
United States, MD, Annapolis
Joined Jun 2011
You don't need to know the serial number to use the assistant software. My serial number doesn't appear either.
If your RX is not bound to the TX that has nothing to do with the NAZA. Just read the instructions in the manual on how to bind the RX. Also the NAZA has to be powered up from the lipo in order to communicate with the assistant software
Russ
rampa202 is offline Find More Posts by rampa202
Old Aug 31, 2012, 06:59 AM
er9xuser is offline
Find More Posts by er9xuser
Slovenia, Ljubljana
Joined Sep 2011
RC HobbyKing Bind Addtional Turnigy 9X 2.4 GHz 8Ch Receiver (V2) (4 min 46 sec)
er9xuser is offline Find More Posts by er9xuser
Old Sep 05, 2012, 01:54 AM
alan2 is offline
Joined Aug 2012
Well, I've now got the RX bound (steady red led inside plus sticks cause display changes in assistant software) but I cannot get any motor spinning. I have flashing orange led when the USB is disconnected. I very much appreciate the various helpful remarks but I'd like especially to hear from anyone who has actually got the combination of the Turnigy RX and the DJI Naza working?
Old Sep 05, 2012, 03:58 AM
Sad Sack is offline
Find More Posts by Sad Sack
What's a servo?
Australia, QLD, Brisbane
Joined Nov 2008
Alan, you really need to get onto the Naza thread and start reading.
The reason no motor is spinning is because the quad needs to be "armed" before it will respond to inputs.
Before you can do this, you need to ensure it wont fall into failsafe by trimming your endpoints in your TX for your flight mode switch.
If none of this sounds familiar, than the best advice for you is to get onto the thread for a few hours and read the setup guides.
Make sure you know you can disarm the quad before you take it for its maiden.
Sad Sack is offline Find More Posts by Sad Sack
Old Sep 05, 2012, 03:34 PM
alan2 is offline
Joined Aug 2012
Thanks for reply. *None* of this is familiar. I don't even know where the thread is that you mention!
Old Sep 05, 2012, 03:36 PM
alan2 is offline
Joined Aug 2012
Further to that Mike, I did trim my end points for the flight mode switch so that the blue showed up, but still failsafe showed up on the bottom bar. I also applied CSC. No luck still
Old Sep 05, 2012, 04:06 PM
Sad Sack is offline
What's a servo?
Joined Nov 2008
This one.
http://www.rcgroups.com/forums/showthread.php?t=1536553
Spend a lot of time reading and learning, also read the Naza manual.
Old Sep 05, 2012, 06:52 PM
alan2 is offline
Joined Aug 2012
I have. What I really want is to hear from someone who has actually successfully used a Turnigy RX with a Naza-M. The blinking yellow light I am getting is shown in the Naza manual as a TX problem, and under those circumstances of course I have a failsafe condition. Yet the RX appears to be successfully bound to the TX moving the allocated switch moves the Assistant pips from one end of the scale to another. All the advice I'm getting seems good and I thank you for it. But no-one has confirmed yet that they have successfully put this particular combination into action. I will try the thread you mention.... Just tried it. Have already consulted that thread, complete with 'I want' and talk about discounts. Nothing that bears on my problem. However, I have posted a question.
New Product DJI Flamewheel F450 Clone Gadget-Geek Multirotor Talk 181 Apr 13, 2015 11:12 AM
Sold DJI 330 Flamewheel Frame thefokker Aircraft - Electric - Multirotor (FS/W) 1 Feb 16, 2012 05:09 PM
Wanted DJI Flamewheel frame baldwinc Aircraft - Electric - Multirotor (FS/W) 5 Feb 15, 2012 12:26 PM
Sold DJI Flamewheel 450 + 2830-13 850Kv Motors FE Obsessed Aircraft - Electric - Multirotor (FS/W) 2 Jan 29, 2012 11:13 AM
Sold DJI F450 flamewheel quad frame kauaicuda Aircraft - Electric - Multirotor (FS/W) 2 Dec 14, 2011 06:33 PM
