Old Aug 28, 2012, 06:22 PM
benderfly is offline
Find More Posts by benderfly
benderfly's Avatar
Joined Sep 2007
Shouldn't the DEA have to communicate when they are going to invade my airspace?
Went out to fly some FPV under the low clouds today, but someone else beat me to it. Suddenly a MD chopper comes out of the woods to my right and swoops down the hill in front of me. Comes back up vertical, basically does a stall turn, swoops back the other way and starts to circle over the houses/fields below me.
If I had been in the air it could have been a serious issue. It is not right for them to invade my legal airspace unannounced.
benderfly is offline Find More Posts by benderfly
Old Aug 28, 2012, 06:40 PM
Blueshy is offline
Find More Posts by Blueshy
OSUFPV - KF7VFT
Corvallis, OR
Joined Apr 2010
91.119 Minimum safe altitudes: General.
Except when necessary for takeoff or landing, no person may operate an aircraft below the following altitudes:
(a) Anywhere. An altitude allowing, if a power unit fails, an emergency landing without undue hazard to persons or property on the surface.
(b) Over congested areas. Over any congested area of a city, town, or settlement, or over any open air assembly of persons, an altitude of 1,000 feet above the highest obstacle within a horizontal radius of 2,000 feet of the aircraft.
(c) Over other than congested areas. An altitude of 500 feet above the surface, except over open water or sparsely populated areas. In those cases, the aircraft may not be operated closer than 500 feet to any person, vessel, vehicle, or structure.
(d) Helicopters. Helicopters may be operated at less than the minimums prescribed in paragraph (b) or (c) of this section if the operation is conducted without hazard to persons or property on the surface. In addition, each person operating a helicopter shall comply with any routes or altitudes specifically prescribed for helicopters by the Administrator.
Not to mention they're police so they are especially insulated from the law.
They were probably doing a drug sweep of nearby fields. Not much you can
do but see and avoid. Also, it's not "your" airspace. The FAA has said before
that it has domain over everything over the surface.
-Blues
Blueshy is offline Find More Posts by Blueshy
Old Aug 28, 2012, 06:55 PM
arnav is offline
Find More Posts by arnav
I live my life 12oz at a time
arnav's Avatar
United States, FL, Miami
Joined Nov 2011
They are on to you! I hope you have a tin foil hat over your Tx (oh, right, never mind..)
arnav is offline Find More Posts by arnav
Old Aug 28, 2012, 07:40 PM
benderfly's Avatar
Joined Sep 2007
It is definitely a pot sweep, they do it every year.
My point really is that a little courtesy would go a long way. Once the police all start flying UAVs everywhere they will need to be a little more cautious.
Old Aug 28, 2012, 07:59 PM
BCSaltchucker is offline
Find More Posts by BCSaltchucker
fly by night
BCSaltchucker's Avatar
Joined Sep 2011
Will make for interesting times, flying into the 'Drone Age'
BCSaltchucker is offline Find More Posts by BCSaltchucker
Old Aug 28, 2012, 08:25 PM
soulreaper is offline
Find More Posts by soulreaper
Joined Nov 2005
They can't give any one a heads up because that would defeat the purpose of a sting. You should be happy they are out there trying to make the world a safer place.
soulreaper is offline Find More Posts by soulreaper
Old Aug 28, 2012, 08:33 PM
BushmanLA is offline
Find More Posts by BushmanLA
BushmanLA's Avatar
Joined Dec 2005
Unfortunately for us, our founding fathers never thought of aircraft. Therefore you have no airspace. The air one inch above your lawn belongs to the National Airspace.
Pretty lame, but it highlights how important the bill of rights is.
BushmanLA is offline Find More Posts by BushmanLA
Old Aug 28, 2012, 08:40 PM
benderfly's Avatar
Joined Sep 2007
Well yes that is true. Wasn't thinking from the culprit perspective. And you are right those mean green plants will sneak up and get you.
I am a big fan of our armed forces, national guard, national and local law enforcement. But they are always saying safety first yet are the only ones flying at low altitudes trying to find something tha could just as easily be found with a little information technology.
Old Aug 28, 2012, 08:47 PM
Martin Y is online now
Find More Posts by Martin Y
400' ..... NOT
Martin Y's Avatar
Canada
Joined Jan 2009
As pot reflects IR better than other plants throw a bunch of ir leds on batteries in the fields. that will disturb their searching.
http://www.lifepixel.com/infrared-ph...-uses-military
Martin Y is online now Find More Posts by Martin Y
Old Aug 28, 2012, 09:08 PM
JRFlyerFPV is offline
Find More Posts by JRFlyerFPV
No JR tx here!
JRFlyerFPV's Avatar
Eastern ND
Joined Sep 2009
Is this your land? If so, unless the police have a search warrant for your property, I would consider this invasion of privacy.
JRFlyerFPV is offline Find More Posts by JRFlyerFPV
Old Aug 28, 2012, 10:19 PM
benderfly's Avatar
Joined Sep 2007
Where they were hovering and circling is not my land. Just directly in front of my runway.
Old Aug 28, 2012, 11:00 PM
gundamnitpete is offline
Find More Posts by gundamnitpete
Team White Llama!
gundamnitpete's Avatar
United States, TX, Houston
paintball gun.
gundamnitpete is offline Find More Posts by gundamnitpete
Old Aug 28, 2012, 11:13 PM
powerstroke01 is offline
Find More Posts by powerstroke01
powerstroke01's Avatar
USA, CA, Ahwahnee
Joined Sep 2004
We get pot copters flying over our part of the woods everyonce in a while. They fly looooowwww.
powerstroke01 is offline Find More Posts by powerstroke01
Old Aug 29, 2012, 12:01 AM
Daemon is offline
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
You do not own the airspace over your property except where you
might reasonably extend a structure from the ground up into it. While
you may not like that as a property owner, it does mean that as an FPV pilot
you can fly over other people's property without significant restriction.
Where you take off and land is another matter, but posted restricted airspace
aside, you can legally fly over just about anything.
From what I understand, what some municipalities have done is
simply make it illegal to launch and land your camera carrying RC aircraft
from anywhere they have jurisdiction, thus making it practically illegal to
fly over any property within that municipality (targeting the paparazzi).
ian
Daemon is offline Find More Posts by Daemon
Discussion Children shouldn't have to grow up this fast... logan5 Life, The Universe, and Politics 3 Aug 11, 2012 07:24 AM
Discussion Is it my imagination or are a lot of people just mad because they aren't rich? LcJ Life, The Universe, and Politics 92 Aug 05, 2012 11:52 PM
Discussion The dumb things we did... That we shouldn't have. RCWorks Life, The Universe, and Politics 23 Jul 06, 2012 07:33 AM
Discussion This Executive Order is purely innocent, they aren't planning anything... Are they? Dave Campbell Life, The Universe, and Politics 41 Mar 28, 2012 10:47 PM
Discussion Who else uses EPP? Where does it go when they are done? willin Foamies (Scratchbuilt) 7 Dec 28, 2006 01:10 PM
