Old Aug 28, 2012, 04:09 PM
itsme2 is offline
Find More Posts by itsme2
United States, TN, Maryville
Joined Mar 2011
Who Makes The Best Prop Balancer For Plastic Electric Plane Props?
Thread title says it all.
Also what is the best way to balance a plastic prop (remove material)?
Thank you!
itsme2 is offline Find More Posts by itsme2
Old Aug 28, 2012, 04:15 PM
rcalldaylong is offline
Find More Posts by rcalldaylong
Dude, I do fly all day long!
rcalldaylong's Avatar
San Jose, California
Joined Dec 2007
Thank you!
Best?
Best is relative. How much are you willing to pay? and does it make sense to pay that when the $15 ones will do the job just fine.
https://www.hobbyking.com/hobbyking/..._balancer.html
Anyways, check out this thread
http://www.rcgroups.com/forums/showthread.php?t=73843
rcalldaylong is offline Find More Posts by rcalldaylong
Old Aug 28, 2012, 04:27 PM
signflyer is offline
Find More Posts by signflyer
2^p - 1
signflyer's Avatar
United States, MO, Springfield
Joined Feb 2003
I had one of the fancy magnetic ones, but switched to this $4.99 one and like it just the same.
signflyer is offline Find More Posts by signflyer
Old Aug 28, 2012, 07:21 PM
yorkiepap is offline
Find More Posts by yorkiepap
yorkiepap's Avatar
SW PA
Joined Aug 2010
I like the Dubro prop balancer I have. I generally just gently wipe the back of the heavy blade with 80grit sandpaper till I remove enough material for proper balance.
Denny
yorkiepap is offline Find More Posts by yorkiepap
Old Aug 28, 2012, 07:28 PM
RCAddict16 is offline
Find More Posts by RCAddict16
United States, VA, Ashburn
Joined Apr 2012
Ehhh....I use a piece of CF hahaha.
RCAddict16 is offline Find More Posts by RCAddict16
Reply With Quote  (Disabled)
Old Aug 28, 2012, 07:30 PM
Beemerider is offline
Find More Posts by Beemerider
Beemerider's Avatar
Joined Mar 2012
This one was recommended to me by a 40 yr veteran flyer at our local field.
http://www.headsuprc.com/servlet/the...alancer/Detail
Beemerider is offline Find More Posts by Beemerider
Old Aug 29, 2012, 11:59 PM
Butch777 is offline
Find More Posts by Butch777
Livermore, CA
Joined Sep 2004
I use a drill bit, as big as I can fit in the hole, and then set 2 glasses next to each other, with the smooth ends of the drill an the lip of the glass and the prop hanging in the middle. Cheap!!
Butch777 is offline Find More Posts by Butch777
Old Aug 30, 2012, 12:02 AM
seeingeyegod is offline
Find More Posts by seeingeyegod
seeingeyegod's Avatar
United States, OR, Portland
Top Flight power point magnetic here.
seeingeyegod is offline Find More Posts by seeingeyegod
Old Aug 30, 2012, 12:23 AM
Murocflyer is offline
Find More Posts by Murocflyer
Promoting Model Aviation...
Murocflyer's Avatar
United States, CA, Tehachapi
Joined Nov 2005
Thank you!
See here; http://www.rcgroups.com/forums/showthread.php?t=1696090
It's too easy to make a prop balancer. But if you are going to get a good one, might as well get a good one.
http://www.mountainmodels.com/produc...roducts_id=549
Frank
Murocflyer is offline Find More Posts by Murocflyer
Old Aug 30, 2012, 12:26 AM
Murocflyer's Avatar
Joined Nov 2005
That is the one I have.
Works good enough for me.
Frank
Old Aug 30, 2012, 02:01 AM
ZSimon is offline
Find More Posts by ZSimon
Canada, ON, Mississauga
Joined May 2011
I use greatplanes one above. cheers.
The magnetic ones are the best from what I hear.
ZSimon is offline Find More Posts by ZSimon
Discussion Who makes the best trex 500 tail rotor ? wc_wickedclown Electric Heli Talk 4 Aug 27, 2012 09:02 PM
Discussion Who makes quality large scale electrics? Axizor Electric Plane Talk 12 Aug 04, 2012 05:39 PM
Discussion Who makes a good Homing beacon for lost plane? sothpaw Electric Plane Talk 4 Jul 19, 2012 08:11 PM
Help! Looking for someone who makes a 20x6 Carbon Fiber Prop PrimalV Fuel Plane Talk 3 Jun 27, 2012 08:23 PM
