Old Aug 28, 2012, 10:53 AM
drebsdorf is offline
Find More Posts by drebsdorf
Joined Aug 2012
Question
Newbie with Two Year old 8S lipo's, Pictures (edit, its also an e-bike)
Hi there
I bought this 8s battery two years ago, to this month. Along with two 4s 1 year old batteries.
I've used them <50 times, but they've been in heavy use powering an e-bike. And now it looks slightly bloated, but I have zero experience grading "bloatation"?
Would you fly?
http://imgur.com/a/vufNx#3 (gallery) and possibly for how long?
I don't mind being on the safe side and disposing it if need be.
Best regards
drebsdorf is offline Find More Posts by drebsdorf
Last edited by drebsdorf; Sep 02, 2012 at 02:13 PM. Reason: title, if everyone is interrested
Old Aug 28, 2012, 12:15 PM
rick.benjamin is offline
Find More Posts by rick.benjamin
Reduce the drama...
rick.benjamin's Avatar
USA, OR, Damascus
Joined Apr 2004
Hi Dreb
Welcome to RCG
I think that your batteries are a little puffy, due to "heavy use".
I would use them, charge them outside, away from flammables.
Have you measured individual cell voltages, before and after charging?
If the numbers aren't too lopsided, they are still useful for now.
What load are they subjected to?
rick.benjamin is offline Find More Posts by rick.benjamin
Old Aug 28, 2012, 12:38 PM
peak is offline
Find More Posts by peak
Joined Mar 2006
What e-bike? How did it work? I've been thinking of this for my "Iacocca" ebike. The SLAs are dead and no replacements.
peak is offline Find More Posts by peak
Old Aug 28, 2012, 12:43 PM
Joined Aug 2012
Hi, thanks for your reply.
To put it bluntly, this exact thing:
Electric Bicycle - 1st test run, 50 kph (1 min 32 sec)
The ESC been upgraded to this http://www.hobbyking.com/hobbyking/s...dProduct=10332 200A
I did a couple of 12S runs @ 85 km/h with two 8S and two 4S, mainly run in 8S series.
Its a slip drive, so I maybe only stalled it once when i blew out a 100A HK.
Old Aug 28, 2012, 01:04 PM
7oneWo1f is offline
Find More Posts by 7oneWo1f
AMF Years
7oneWo1f's Avatar
Joined Nov 2011
Cool project, and smart move on the disc breaks and helmet.
7oneWo1f is offline Find More Posts by 7oneWo1f
Old Aug 31, 2012, 10:05 AM
Joined Aug 2012
I measured my 8S pack
Voltage, from when i put it into storage mode, ranges from 4.11 to 4.14.
The one 4S measures 4.0 on the first cell from negative, and the rest are 4.16 - 4.19. Charged State.
The other 4S measures 4.19 across the board, so I assume thats fine, also its charged state.
A follow up question, would you parallel couple the 2 x 8S batteries, and if so, what should thier respective voltage difference be? +- 0,5V?
Old Aug 31, 2012, 10:07 AM
Joined Aug 2012
My experience, unless you buy a LIFEPO4 pack on ebay or somewhere else, you're wasting your money. Also, buy a hub motor! Heads up, a 48V 20Ah pack only discharges 25A, 35A burst, mostly.
Old Sep 01, 2012, 09:00 AM
TJWright is offline
Find More Posts by TJWright
Three cards shy of a full deck
TJWright's Avatar
United States, WA, Vancouver
Joined Aug 2012
Very cool idea...what motor are you using??
how long have you been working on this......??
TJWright is offline Find More Posts by TJWright
TJWright is offline
TJWright's Avatar
Joined Aug 2012
Can you post some close ups of the power set up ??
Old Sep 01, 2012, 09:02 AM
TJWright is offline
TJWright's Avatar
Joined Aug 2012
I would really like to build one of these set ups to ride to work.
what kind of range or miles per charge do you get ??
Old Sep 02, 2012, 02:08 PM
Joined Aug 2012
Why certainly, but I just wan't to underline how incredibly dangerous this is. My build is far from perfect, or pretty, but it does work, sorta, not really.
This is an updated build where I put everything in a sidemounted bag, mostly to keep a low profile
Here are some images, I would start with the one of the fire-extinguisher. http://imgur.com/a/mIuIs
This setup needs a spark terminator/resistor to connect the batteries safely.
There's an Amp/h meter rated for 200A and a voltage display in the side pouch, a small multimeter on the handle bars is probably easier.
Control is done with an ohm resistor throttle replacing the knob on a servo controller. This is documented in plenty of places.
Theres a powersource for the servocontroller and cooling fan running off the two 3S batteries.
Unfortunately I don't see hobbyking listing the motor anymore, its a Turnigy 80-100-B 130Kv, 60-80cc equivilant i think. I would recommend a smaller diameter motor if you can find it with equally low rpms. Since the gearing is dependt on the wheel size. Maybe 50-80A range.
I put it together in a week, waiting for the parts took the most time. Then winter pretty much happend and I had to put away. Come summer i drove it to work plenty of times, pulling my mate along @ 50 Then 100A controller exploded and one of the 8S batteries puffed. These RC parts are very fragile / not inexpensive, I also spent two rear tires.
I drove it for 25 Km once, going along at 25-40. With 2x8S.
Discussion How's this for gun control? 71 year old shoots gunmen trying to rob cafe srt8madness Life, The Universe, and Politics 12 Jul 18, 2012 09:16 PM
Sold Sold! Walkera V120D02s rtf with slipper clutch and devo 8s, 8 lipos, $230 obo shipped ForceFedDSM Aircraft - Electric - Helis (FS/W) 1 Jul 05, 2012 08:53 PM
Discussion Saudis order 40 lashes for 75 year old woman for mingling with two men arukum17 Life, The Universe, and Politics 17 Mar 09, 2009 12:22 PM
How about pictures of some old radio (20 years old or more)? FLYRCM Radios 9 Dec 02, 2005 10:53 AM
Newbie with 8 year old looking to fly! louisd Beginner Training Area (Aircraft-Electric) 16 Dec 16, 2004 10:34 AM
