Old Aug 28, 2012, 02:00 AM
jack3auer is offline
Find More Posts by jack3auer
Joined Jul 2012
Question about charging a LIPO in stages
Hi i recently bought the firebird stratos and it comes with a lipo charger for plugging into my car cigarette lighter socket, only problem is my car is new and will completely shuts the battery off to your headlights and external sockets etc when the ignition is off.
so my battery will not charge unless i am driving somewhere. i drive to and from work every day and it takes about half an hour each way, is it ok to charge fully charge the lipo battery over the course of the two journeys? or will it take longer / damage the battery?
i cannot find an answer to this query
jack3auer is offline Find More Posts by jack3auer
Old Aug 28, 2012, 04:04 AM
bladeskiller is offline
Find More Posts by bladeskiller
Athens
Joined Aug 2008
There is no problem for a lipo battery to charge it in two or more stages. But i would not recommend to charge a plane lipo battery inside your car using the cigarette lighter socket ,especially during driving. Thinking about the failure possibility of the circuity used in all those cheap RTF plane chargers and all those flamable meterials inside a car ,fire hazard is real.
It is better to solder two wires to the charger plug (one red for + and one black for -) and connect it directly to the car battery when your car is stationary and of course the charger and the battery outside the car.
bladeskiller is offline Find More Posts by bladeskiller
Old Aug 28, 2012, 04:07 AM
3JJ is offline
3JJ
Find More Posts by 3JJ
3JJ
Finland, Northern Ostrobothnia, Oulu
Joined May 2012
No harm done. You can stop and start the charging as many times as you want. If you do not want to take a one hour drive after each use, how about getting a power supply with cigarette socket, just make sure it can deliver enough power for your charger.
3JJ is offline Find More Posts by 3JJ
Old Aug 28, 2012, 04:20 AM
Joined Jul 2012
thanks for the replies folks, i am glad to hear that it wont harm the battery to do it in two / three stages.
however I dont think i will be soldering any wires or connecting it to my battery directly as that sounds more likely to cause me (clumsy) an injury than doing it the way suggested in the manual.
Old Aug 28, 2012, 07:07 AM
tacx is offline
Find More Posts by tacx
tacx's Avatar
United States, MI, Washington
Joined Apr 2009
Charging a lipo in your car is not wise.
I find it strange that your power outlets on your car shut off when the ignition is turned off?
tacx is offline Find More Posts by tacx
Old Aug 28, 2012, 07:34 AM
Joined Jul 2012
as i explained, i have to be in the car with the engine running or at least powered on. i am checking the battery every 5 minutes making sure it is not puffing up or getting hot, i do not leave it unattended.
My car is about a year old, the power shut off seems to be designed to stop you flattening the battery by leaving the head lights / side lights on when you finish driving.
i cannot charge the battery without the keys in the ignition and switched on, i wouldn't leave my car unattended with the keys in the ignition ever.
this is (essentially) the device that comes with the stratos
if there is some sort of connector i can get to allow it to charge from the mains supply, that would be better for me
Old Aug 28, 2012, 07:37 AM
grimbeaver is offline
Find More Posts by grimbeaver
United States, MN
Joined Feb 2011
Power outlets in cars have always shut off when the ignition is off, I've never owned a car that doesn't do that. Just turn on the ignition, nothing says you have to start the car, you just have to turn the key far enough.
grimbeaver is offline Find More Posts by grimbeaver
Old Aug 28, 2012, 07:45 AM
Joined Jul 2012
like i said, i could do that, but it I wouldn't want to leave the vehicle unattended with the keys in, nor do i want to sit in my car (unless i am driving).
the question i had was more to do with what the effects of charging the battery in two or three stages might be, rather than how to charge it.
i have charged it this way twice now and just wanted to make sure that i wasn't damaging it or wasting additional time because it needed to be done in one charge.
Old Aug 28, 2012, 08:01 AM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
Not the best permanent solution but for something simple
http://www.walmart.com/ip/Schumacher...ndingMethod=rr
Similiar ones available from auto parts stores, Home Depot. Lowes etc..
You should recharge these after use as the internal battery will last longer if you do not discharge it very much.
Charles
Old Aug 28, 2012, 08:04 AM
The Tug is offline
Find More Posts by The Tug
Barbados
Joined Jan 2011
As the other posters have said no problem charging it that way,what we dont like is you doing it in the car.
The Tug is offline Find More Posts by The Tug
Old Aug 28, 2012, 08:32 AM
Joined Jul 2012
thanks again for the replies, i have read in the manual, that i should never leave the battery unattended when charging etc and as explained i cannot do that anyway.
if i am sat right next to it, checking it by touch and sight every few minutes, plus using the charger as intended what's the potential problem?
Old Aug 28, 2012, 08:52 AM
gonzalo38 is offline
Find More Posts by gonzalo38
South of the Rio Grande..
gonzalo38's Avatar
Chile - South America
Joined Apr 2008
I would never.... ever charge a Lipo in my car since you never know when something is going to happen with them. In just a matter of seconds hey can puff and explode and you wouldn't have time to react.
Why not charge the batteries at home before you go flying ? Buy a cheap charger from Hobbyking that you could use at home or at the field.
LiPo Explosion (2 min 17 sec)
gonzalo38 is offline Find More Posts by gonzalo38
Old Aug 28, 2012, 09:10 AM
Joined Jul 2012
http://www.youtube.com/watch?v=k9mcN...layer_embedded
but couldn't the same thing be possible in my house? setting fire to my house too?
Old Aug 28, 2012, 09:21 AM
United States, MN
Joined Feb 2011
I don't have sound on this computer, but I see a video of a bunch of people wearing jackets. So I'm going to assume they were charging in the cold and over charged the pack completely ignoring the warnings that when charging in cold weather you have to reduce your end voltage. If you treat your batteries right your chance of something going wrong is extremely slim.
Old Aug 28, 2012, 09:32 AM
Joined Jul 2012
i have just looked at a few of these "exploding lipo" videos on youtube and it seems that most of them are of people intentionally exploding / mistreating these batteries or are playing around with batteries that have reached the end of their lives.
This information here:-
http://www.rcmods.co.uk/lipo_battery_safety_tips.php
and here
http://www.bmfa.org/resources/lipobatteries.html
suggests that it is safe to charge them with the included charger for use in a car cigarrete lighter socket, adding other devices and or tampering / soldering wires to it sounds much more likely to cause me problems.
Help! LiFePo4 9.9v question about charging raRaRa Batteries and Chargers 4 Aug 24, 2012 02:33 AM
Help! quick question about running 2 lipos in series... xfatdannx Batteries and Chargers 4 Aug 04, 2012 07:17 PM
Discussion Question about charging lipo's *in* model. mjpnj@yahoo.com Batteries and Chargers 8 Feb 14, 2008 03:56 PM
Purpose of "ramp up" stage in LiPo charging? Neil Walker Batteries and Chargers 11 Nov 29, 2005 10:51 PM
Question about charging 2 lipos in parallel lorents Batteries and Chargers 5 Apr 18, 2005 10:18 PM
