Old Oct 25, 2012, 11:17 AM
cracksmeup is offline
Find More Posts by cracksmeup
cracksmeup's Avatar
United States, IL, Joliet
Joined Jun 2009
I have seen guys make saftey switches out of deans plugs and there is a compnay that does make a safety plug but i lost their link. I remember when they had a switch on the esc's and thought they got rid of them because of cost . I just roll the dice and make sure everything is at low before i plug stuff in but i should start using plugs for safety. I set up my planes with the props off now after i had one take off in my living room last year and hit my older transmitter and cut one stick shorter than the other,plus i had to clean my shorts out . lmao joe
cracksmeup is offline Find More Posts by cracksmeup
Old Oct 25, 2012, 12:46 PM
Freddie B is offline
Find More Posts by Freddie B
Addicted to building...
Freddie B's Avatar
Omaha Nebraska
Joined Feb 2006
Joe, you are making me laugh again. And yes electrics are dangerous too, not just nitro birds!
Fred
Freddie B is offline Find More Posts by Freddie B
Old Oct 25, 2012, 01:27 PM
Freddie B's Avatar
Omaha Nebraska
Joined Feb 2006
Joined the elevator halves, and installed the hinges. Glued the assembed parts to the stabilizer. Then I tack glued tail end cap in position to sand it to final shape. Put a layer of light fiberglass and resin on the end cap since this is the easiest way to cover a compound curved part like this.
Fred
Old Nov 05, 2012, 09:34 AM
Freddie B's Avatar
Omaha Nebraska
Joined Feb 2006
Time flys (also) LOL. With all the activity around home and Halloween, not to mention family and friends affected by Hurricane Sandy, not a lot of airplane stuff going on. So slowly I am working on applying the fuselage Silkspan covering and final panels and caps. SLOW is all I can say to describe it, and driving me crazy!
I have only 2 photos to show because who wants to see covering going on, LOL. First is I routed some foam out of the tail cap before gluing it into place. Then I fashoned a bottom front cover that I glued onto the fuselage, with the only treatment being the manila folder card stock and glass reinforcement because this butts up to the wing's LE when mounted.
I hope to finish the covering soon and start final assembly of the bits and pieces because it is time to move onto other projects that need completion (Walt and Dave)!
Fred
Old Sep 27, 2014, 06:42 PM
Tsavah is offline
Find More Posts by Tsavah
Watt Waster
Tsavah's Avatar
Joined Oct 2010
Cartoon A-10
Hard to believe this thread has more, or less died.
Tsavah is offline Find More Posts by Tsavah
Old Sep 27, 2014, 10:03 PM
Freddie B's Avatar
Omaha Nebraska
Joined Feb 2006
Ha, ha. Actually I almost did in 2011. Last worked on this, or any airplane for that matter, 2 years ago.
It hasn't been easy or fun, but life and family does come first, even for old guys.
Got past most of that but had to put the models down for about 2 years now. I hope by Spring to be back with many of my good friends here on RCG. Hang in there because this is one build I have in protected, ready to finish in short order status.
Fred
Old Sep 27, 2014, 10:07 PM
Wilfor is online now
Find More Posts by Wilfor
RC Adddict
Wilfor's Avatar
Canada, BC, Williams Lake
Joined Jan 2010
Fred fantastic to see your still kicking and getting everything worked out. Your skill and personality has been missed. Good luck with everything and looking forward to your builds when you get back
Chris
Wilfor is online now Find More Posts by Wilfor
Old Sep 27, 2014, 10:15 PM
Freddie B's Avatar
Omaha Nebraska
Joined Feb 2006
Chris
Thanks Chris.
I missed you as well. Hope the family is well. I feel exactly the same about you and many others here. I appreciate the boost of good will right about now. I really miss you all and will be eager to return.
I almost bought a bike last month, but that too would be silly because timing is not right!
Take care
Fred
Discussion A-10 Wart Hawg Cartoon Fattie... Rusty-Gunn Foamies (Scratchbuilt) 335 May 15, 2014 07:24 PM
Discussion How to make fatty cartoon planes gonzalito Foamies (Scratchbuilt) 10 Apr 17, 2012 02:03 PM
Wanted Cartoon fattie planes LIZZAY Aircraft - Electric - Airplanes (FS/W) 4 Apr 13, 2012 01:06 PM
