Old Aug 27, 2012, 11:25 PM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
Build Log
Wicked Powered 50mm Screamer EDF
Here is my build thread on thew new Screamer 50mm EDF
I bought the airframe from: www.hobbyb.com
note: the airframe only kit has no control horns or control rods included so you will have to come up with your own.
Power system:
Wicked 6000 KV motor
Wemotec 50mm Microfan
Pentium 40 amp ESC
Lipo will be a 3S 1800.
Don
Wicked Powered 50mm Screamer EDF Jet (3 min 36 sec)
The Don is online now Find More Posts by The Don
Old Aug 27, 2012, 11:29 PM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
Here are some photos.
1. No added wire length is needed on the motor/ESC
2. Fan area prep is typical for the wemotec as on the other 50mm models
3. I found the lower hatch was barely glued on so pulled it all off. Makes installation or servo wires and ESC much easier.
4. I did remove a little foam where the ESC is located to make it fit easier.
Don
Old Aug 27, 2012, 11:35 PM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
Here is the thrust tube template I made with centering ring. print out "full size" or "actual size", do not "fit to paper" or similar wording in your print manager.
I will post photo tomorrow of the thrust tube install.
Don
Old Aug 28, 2012, 01:15 AM
Joined Aug 2011
interested in this build.
i have just taken delivery of my ARF screamer.
i will fly it on the stock setup for now however i may go the wemo / 6000kv setup down the track.
quick question will my 3s 1300mah 45c nanotech be up to the task with the wemo / 6000kv combo?
jim350 is offline Find More Posts by jim350
Old Aug 28, 2012, 02:05 AM
check for reversed controls
alpea 41's Avatar
United States, CA, Chino
Joined Oct 2007
Watching
alpea 41 is online now Find More Posts by alpea 41
Old Aug 28, 2012, 12:43 PM
chuck
santa barbara, CA
Joined May 2009
not if u want to use the power, imo. i tried that and it was very hard amp wise on that size battery. voltage sag will also be a issue.
chuck.
chas650r is offline Find More Posts by chas650r
Old Aug 29, 2012, 07:00 AM
Joe 1320's Avatar
United States, FL, Sebring
Joined Feb 2006
I found the lower hatch was barely glued on so pulled it all off. Makes installation or servo wires and ESC much easier. I did remove a little foam where the ESC is located to make it fit easier.
Don
I thought about removing the forward duct but never did. Mine was glued fairly secure. It might be worth a little light glass cloth along the lip, I'll have to see how it holds up over time.
Joe 1320 is offline Find More Posts by Joe 1320
Old Aug 29, 2012, 08:04 AM
Joined Aug 2011
Well just spooled up my ARF screamer kit and the stock fan is really badly out of balance and rubbing on one side.
Never had an EDF unit so bad :-(
Lesson learned should have just purchased the airframe.
Instead of mucking around with it i have ordered a wemo / het 6000kv setup as i was ultimately going to upgrade anyway.
Will have to use throttle management with my 3s 1300 45c batteries
Old Aug 29, 2012, 08:09 AM
Joe 1320's Avatar
Joined Feb 2006
I never understood how the manufacturer can put in a fan that rubs on initial startup. . If you want to part with the motor, send me a PM with how much you might want for it.
Old Aug 29, 2012, 04:33 PM
Trash Hauler emeritus
herk1's Avatar
Maryland, USA
Joined Oct 2006
I'm thinking of moving my Wemo/Wicked 6000 setup from my Skyangel F-16 into one of these so I can use a bigger battery. Any idea if the CG might work out OK with a 3S 2200 up front, like I have in my Skyangel T-45? Or if that would be nose-heavy, how hard would it be to move the fan back? Does the inside of the exhaust duct taper down more narrow as it goes aft (as it appears to do on the outside), or is it the same inside diameter all the way back?
herk1 is offline Find More Posts by herk1
Old Aug 29, 2012, 11:31 PM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
I only use 3S1800s on the 6000 Wicked/Wemo setup as I basically fly full throttle the whole flight as I like the speed so I need the bigger lipo. If you flew around part throttle a 1300 may be OK but that is personal flying preference I guess. I just like fast :-)
Don
Old Aug 29, 2012, 11:34 PM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
I think I can get to balance OK with a 1800 mah, not sure on the 2200 but can tell you in a day or so. I need to get my fins painted then glued on so I can do a CG check but with no fins on I am close to the 45mm from the inlet lip (assuming that is the correct CG) so a 2200 may be possible.
Don
Old Aug 31, 2012, 01:22 AM
No mods no glory!
micromantis's Avatar
United States, CA, Redwood City
Joined Nov 2010
Hey Don,
Thank you again for another trust tube template and ideas for the build. Here is my Fire Fox Screamer, very fast with your WW 6k kv unit.
Dons WW 6K kv motor / 50mm Microfan
CC Ice Lite 50
TP 1300 3S 65-130C
Morgan Mills Rare Bear control rod covers
micromantis is offline Find More Posts by micromantis
Old Aug 31, 2012, 08:02 AM
alpea 41's Avatar
Joined Oct 2007
Nice colors micro.Top Gun Aggressor sometime in the future
Build Log Wicked powered Jpower 50mm Mig-15 EDF The Don Don's RC 55 Nov 28, 2014 10:54 PM
New Product Skyangel NEW PRODUCT Screamer 50mm EDF Sport Jet www.hobbyb.com Australia 31 Oct 13, 2013 08:00 AM
Mini-Review Skyangel-J/Power Screamer 50mm EDF Joe 1320 Foamy EDFs 143 Jun 30, 2013 07:48 PM
Build Log Wicked Powered 50mm Jpower T-33 EDF The Don Don's RC 21 Jul 26, 2012 02:07 PM
Build Log Wicked Powered Jpower 50mm T-45 EDF The Don Don's RC 32 Aug 07, 2011 04:31 PM
