Joined Jul 2010
The cheapest way (but not necessarily the lightest) to achieve the filleting you want is to mix microballoons with 30 min epoxy to the consistency of peanut butter. Spread that into place and after it cures you can rough and fine sand it to the shape you need. I've never had any problems with any kind of paint including dope, enamels, poly, or two-part epoxy sticking well to it.
For larger fillets where there must be significant build-up (such as wing saddles) I use this product: http://www.aircraftspruce.com/catalo...s/superfil.php It's not cheap but you get enough to do a lot of models and it appears to have a good shelf life. It's very light and easy to work with. It seems to stick well to balsa but you may want to put a thin coat of finishing resin down first just to harden the balsa a bit and ensure adhesion for the superfil. The superfil sands and finishes nicely and every paint I've tried sticks well. Curt |
| Thread Tools | |
| Question What Aircraft Do You Want, That No One is Making? | Seria17hri11er | Electric Plane Talk | 124 | Feb 27, 2013 10:07 AM |
| Question What Aircraft Do You Want, That No One is Making? | Seria17hri11er | Fuel Plane Talk | 35 | Jan 06, 2013 05:13 PM |
| Discussion Taking pics from a quad, how do you acquire? | spacecase | Aerial Photography | 9 | Jun 29, 2012 10:09 AM |
| Question How do you take your Lipo batteries to the field? | Left Coast DJ | Batteries and Chargers | 26 | May 26, 2012 05:02 PM |
| Question What Aircraft Do You Want, That No One is Making? | Seria17hri11er | Fuel Jet Talk | 3 | May 20, 2012 01:43 PM |
