Old Aug 27, 2012, 09:07 PM
Dave8888 is offline
Find More Posts by Dave8888
United States, AZ, Seligman
Joined Nov 2011
Please Help with Building 3-Point Hydro From Plans
I have plans are for a 15" hydro. I want to build it 24" to 26". It says the bulkheads and keel are made of 1/8" balsa. I am thinking of making them out of 1/8" plywood and covering it with 1/32" plywood. I want to run somewhere around a 3000kv electric motor and of course make it radio controlled (plans say it's a tether boat). What do you think? Am I building it strong enough? Light enough? Thanks for any input.
Dave8888 is offline Find More Posts by Dave8888
Old Aug 27, 2012, 11:16 PM
boaterguy is online now
Find More Posts by boaterguy
Thermite + ice = Big boom.
boaterguy's Avatar
Canada, ON, Ottawa
Joined Apr 2009
Skin it with 1/32 and then glass it, not sure on a good glass weight, maybe 5-7 ounce.
3000kv would be good on 3S, use the turnigy/seaking 90 or 120 amp ESC. You won't be needing that much but it hardly costs more so go for the extra protection.
What size motor are you planning?
boaterguy is online now Find More Posts by boaterguy
Old Aug 28, 2012, 12:12 AM
Dave8888 is offline
Joined Nov 2011
Don't know what size motor yet. I am now going to build boat smaller. I am on a very tight budget and just got a 25 amp ESC for the project. So it will now be a motor that will fit that ESC.
Old Aug 28, 2012, 12:34 AM
boaterguy's Avatar
Canada, ON, Ottawa
Joined Apr 2009
Build it down at ~20" then. You won't be able to run a 24" boat very quickly on 25 amps, even on a 4S setup.
Try to find a 2840 or 2850 motor (something with 28 as the first two) at around 2800-3000kv.
If it's that size, use balsa as the plans reccomend.
Old Aug 28, 2012, 12:37 AM
Dave8888 is offline
Joined Nov 2011
Thanks for the help.
Old Aug 28, 2012, 07:25 AM
wparsons is offline
Find More Posts by wparsons
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
I'd go with around 16" and a 450 outrunner or 2040 inrunner to keep amp draw down. You'll want a conservative kv rating so you don't have to run tiny props. Something in the 2500-2700kv range on 3s should be ok with a 30-32mm prop.
wparsons is offline Find More Posts by wparsons
Data 4 point hydro 3 point hydro mxz70017 Racing Boats - Electric 48 Oct 26, 2015 03:17 AM
Help! A sensitive plea for help.... David A Ramsey Life, The Universe, and Politics 147 Jun 27, 2012 09:01 AM
Help! traxxas slayer 3.3 engine probs.new to rc pleas help! tpapendick Nitro and Glow Power Cars 3 Apr 25, 2011 09:30 PM
Discussion Help with building from paper plans ozzi supercub Foamies (Scratchbuilt) 4 Jan 05, 2009 08:04 PM
