Old Mar 03, 2013, 08:29 PM
apejovic is offline
Find More Posts by apejovic
Spain, CN
Joined Dec 2011
Ive been following your work and must say your design is pure art.
Im working on a similar setup and would like to know what kind od power distribution are you using is it a board or wire?
apejovic is offline Find More Posts by apejovic
Old Mar 04, 2013, 06:52 AM
holco is offline
Find More Posts by holco
holco's Avatar
The Netherlands
Joined Mar 2007
This are pure copper plates 0,9mm thick and minimum 11AWG.
holco is offline Find More Posts by holco
Old Mar 04, 2013, 06:56 AM
holco is offline
holco's Avatar
The Netherlands
Joined Mar 2007
Flexacopter Kratos Build Up (2 min 33 sec)
Flexacopter Kratos Build Apart (2 min 14 sec)
Old Mar 09, 2013, 03:56 AM
holco is offline
holco's Avatar
The Netherlands
Joined Mar 2007
After some tuning the Kratos with the YS-X6 fly's super steady and smooth, between manual and GPS/altitude lock mode we see no difference at all in stability
GPS/altitude lock is extreme good, we don't talk about decimeters but more like centimeters accuracy!!
This was with 2a3 Bf, we are curieus how it will hold up with more wind.
ESC's and motors show a temp rising of no more than 20 after a flight of 13 min (AUW 9kg)
Looks like we got a faulty batch of Radian's they are continue drifting on all the slew mode's axels, hope we can solve this quickly.
Some photo's,
Old Mar 10, 2013, 07:33 AM
holco is offline
holco's Avatar
The Netherlands
Joined Mar 2007
Installed 8 pieces EC-2 extension cables, now it's much easier to reach the ESC program plug's for programing
Old Mar 16, 2013, 03:33 AM
holco is offline
holco's Avatar
The Netherlands
Joined Mar 2007
Boring video
Still needs a bit of tuning but we are getting closer
Filming the Kratos (6 min 23 sec)
Old Mar 16, 2013, 05:16 PM
holco is offline
holco's Avatar
The Netherlands
Joined Mar 2007
Screenshot from the Kratos edition ESC blackbox provided by MGM, I am a noob with stuf like this but I know that this is a very quick response time.
Full size link: http://www1.picturepush.com/photo/a/...SC/400Hz-1.jpg
Old Mar 19, 2013, 04:08 PM
holco is offline
holco's Avatar
The Netherlands
Joined Mar 2007
ESC comparison test.
In real live the motor has to pull 1200g so to get the same rpm for the test I mounted the extra lipo under the motor.
Xoar 14x6 propeller
Plettenberg Orbit 15-24
All three tests on a 6S lipo and exactly the same conditions, only the ESC's are swapped.
Flexacopter ESC Kratos edition, tuned on smoothness
Flexacopter MGM Kratos edition ESC tuning. (0 min 32 sec)
Mystery 40A with SimonK firmware
Mystery 40A SimonK (0 min 57 sec)
Phoenix Ice 50 with the 4.02 firmware, timing on his highest but the Orbit needs more
CC Ice 50 4.02 firmware (0 min 59 sec)
Old Mar 24, 2013, 04:24 AM
holco is offline
holco's Avatar
The Netherlands
Joined Mar 2007
Ever wondered how much silicone wire is needed to connect everything on a Kratos?
16,8 meter 16AWG (motor / ESC)
11,2 meter 22AWG (lichting / buzzer)
Old Mar 30, 2013, 06:33 PM
holco is offline
holco's Avatar
The Netherlands
Joined Mar 2007
5kg payload test
Just aded the payload without FC tuning.
7 min flying time and 13280mAh used of the 16000mAh in total.
Al up weight 13,94kg
Total weight of the used lead 4980 gram
Case for holding the weight 83 gram
ESC's max 21 above ambient temp
Motors hand warm after 7min +/- 35
Nominal Amp draw 110 A / max Amp draw +/- 135 A
Flexacopter Kratos timed flight with 5kg payload (9 min 53 sec)
Old Apr 01, 2013, 09:00 PM
apejovic is offline
Spain, CN
Joined Dec 2011
Nice test, what pids did you end up using with the X6? pitch and roll sensistivity around 80-90?
Old Apr 03, 2013, 06:33 PM
ghostrider2005 is offline
Find More Posts by ghostrider2005
Moyock, NC
Joined Jun 2005
I guess you have probably heard that FreeFly is releasing a direct drive gimbal. It makes me want to pull the trigger on ordering your Kratos. Do you have any onboard video since you have had a chance to do some tuning?
ghostrider2005 is offline Find More Posts by ghostrider2005
Old Apr 04, 2013, 03:37 PM
holco is offline
holco's Avatar
The Netherlands
Joined Mar 2007
Just a day with the Kratos (4 min 37 sec)
Old Apr 04, 2013, 07:00 PM
Moyock, NC
Joined Jun 2005
Thanks for posting. The video looks very promising. Keep up the good progress.
Old Apr 05, 2013, 03:47 AM
holco is offline
holco's Avatar
The Netherlands
Joined Mar 2007
Build Log Flexacopter ---The Making Of--- holco Multirotor Talk 709 Nov 27, 2014 01:37 AM
Discussion Theoretically using a Naza to control an Octocopter? Kahuna717 Multirotor Talk 15 Apr 01, 2013 02:40 AM
Discussion Make octocopter with least 15kg payload zowex Multirotor Talk 30 Oct 19, 2012 09:09 AM
Help! Seeking Qualified Builder for an Octocopter Project Canoctocopter Power Systems 3 May 02, 2012 03:15 AM
Discussion Will this work for an octocopter frame design? webgeek Multirotor Talk 6 May 13, 2011 03:44 PM
