Espritmodel.com Heli Air
Old Jan 26, 2013, 02:56 PM
Ruitech's Avatar
The Netherlands, UT, Utrecht
Joined Aug 2012
A DD gimbal, based on the Freefly 3 axis gimbal should not be a problem. I just hope they will make a upgrade version to replace the servo's for Direct Drive motor's & a control unit to drive them (like Alexmos)
Ruitech is offline Find More Posts by Ruitech
Old Jan 26, 2013, 06:19 PM
holco's Avatar
The Netherlands
Joined Mar 2007
work in progress
holco is offline Find More Posts by holco
Old Jan 27, 2013, 07:56 AM
Joined Jan 2013
Looks like a really nice and tidy machine. So that dampening system actually runs through the top plates? All that wire can't be light though, have you weighed it yet?
Pelagic is offline Find More Posts by Pelagic
Old Jan 30, 2013, 11:37 AM
holco's Avatar
The Netherlands
Joined Mar 2007
After testing a lot of motors we decided to go for a Plettenberg Orbit motor for our Kratos
Motor test for our new Flexacopter Kratos (8 min 45 sec)
Old Jan 30, 2013, 01:02 PM
vAMPire
Germany
Joined Aug 2010
Wow, what a monster at 10KW peak!
One question concerning the wire dampeners, do they only work properly on compression would they be also effective on tensile load?
Henni is offline Find More Posts by Henni
Old Jan 30, 2013, 02:32 PM
holco's Avatar
The Netherlands
Joined Mar 2007
More like 1300W
Old Jan 30, 2013, 05:00 PM
vAMPire
Germany
Joined Aug 2010
I was assuming that you were going to use 8 of them in total ;-)
So what about the wire dampeners, secret information? Like the fact that they seem to be very effective yet very easy and cheap to make (not talking about the perfection u do)
Old Jan 30, 2013, 05:11 PM
holco's Avatar
The Netherlands
Joined Mar 2007
You right with 8 of them 10,4KW
Total lifting power 33,6kg
For sure no secret, google is your friend lots of information about wiredampers.
Old Jan 31, 2013, 12:27 AM
Will fly for food
ilektron's Avatar
United States, CA, Carlsbad
Joined May 2011
I have to ask. Couldn't you get away with much smaller COTS wire-dampeners than custom machined ones? I recognize half the fun may be designing your own...
ilektron is offline Find More Posts by ilektron
Old Jan 31, 2013, 02:01 AM
holco's Avatar
The Netherlands
Joined Mar 2007
The wiredampers on the Kratos are designed for lifting High-End Pro camera's in the range of 4>6kg, simple remove 4 of them and you are in the range of 1>3kg camera's, fine tuning is also possible by simple removing single wires with a 1.3mm hex driver, no glue is used with this dampers.
You can buy of the shelf wiredampers (also not cheap!!) but than you don't get the flexability we have now and it wil spoil the looks
Don't know what COTS means though
Old Jan 31, 2013, 02:12 AM
topgearuk's Avatar
United Kingdom, London
Joined Dec 2003
Which ESC's are you using? Look similar to YGE's
topgearuk is offline Find More Posts by topgearuk
Old Jan 31, 2013, 02:21 AM
holco's Avatar
The Netherlands
Joined Mar 2007
That's our own water proof coated 32bit 6S-60A ESC with actif braking made by MGM.
Old Jan 31, 2013, 02:47 AM
topgearuk's Avatar
Joined Dec 2003
Very nice! I'm sure they will work great... Any reason you went with Active braking?
Old Jan 31, 2013, 03:04 AM
holco's Avatar
The Netherlands
Joined Mar 2007
Better rpm decreasing respons, especially with large prop's.
But with the software tool you simply can adjust it from 0>100
video#3 How to Program X-SERIES Speed Controller Using PC (2 min 20 sec)
Old Jan 31, 2013, 03:15 AM
topgearuk's Avatar
Joined Dec 2003
http://www.youtube.com/watch?v=xB8sfhl1gmw
Makes total sense!
How's that wiring up coming a long? That's my favorite bit.. Lol
Build Log Flexacopter ---The Making Of--- holco Multirotor Talk 659 Apr 25, 2013 02:49 AM
Discussion Theoretically using a Naza to control an Octocopter? Kahuna717 Multirotor Talk 15 Apr 01, 2013 02:40 AM
Discussion Make octocopter with least 15kg payload zowex Multirotor Talk 30 Oct 19, 2012 09:09 AM
Help! Seeking Qualified Builder for an Octocopter Project Canoctocopter Power Systems 3 May 02, 2012 03:15 AM
Discussion Will this work for an octocopter frame design? webgeek Multirotor Talk 6 May 13, 2011 03:44 PM
