Old Aug 27, 2012, 03:23 PM
jespicer1 is offline
Find More Posts by jespicer1
Joined Aug 2012
k&B 45 sportster
I have a old sportster that is in great condition. The motors runs really strong swinging a 11 4 prop. I noticed the prop shaft is slightly bent and a few threads are bad. Does any one know where to get a new shaft?
Mecoa.com is not shipping parts. I tried them and got an automated response.
jespicer1 is offline Find More Posts by jespicer1
Old Aug 27, 2012, 03:33 PM
earlwb is offline
Find More Posts by earlwb
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
Ask about if anyone has one or not they could sell or give you, like you just did.
You could also try Ebay or other online stores like that and see if they have something too.
Yeah MECOA is moving to a new location and it might be a while before they get it all organized again.
earlwb is offline Find More Posts by earlwb
Old Aug 27, 2012, 05:24 PM
earlwb is offline
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
You could just buy another used engine and use it or part it out as needed too.
here is one http://www.rcgroups.com/forums/showthread.php?t=1719311
Old Aug 27, 2012, 07:44 PM
datsunguy is offline
Find More Posts by datsunguy
Joined Jun 2011
An 11x4 is way too small a prop for that engine.
datsunguy is offline Find More Posts by datsunguy
Old Aug 27, 2012, 07:59 PM
earlwb is offline
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
I had totally forgotten about it, but the .45 Sportster uses a 1/4x28 threaded prop stud shaft that screws into the crankshaft end. Since MECOA isn't able to ship parts yet, you can try ordering one from Fox Manufacturing as they use the same size prop stud on their engines too.
http://www.foxmanufacturing.com/inde...oducts_id=1009
Yeah I run a 11x6 prop on my .45 engines.
Old Aug 27, 2012, 09:28 PM
jeffie8696 is offline
Find More Posts by jeffie8696
TEAM BOCA
jeffie8696's Avatar
United States, IA, Muscatine
Joined Oct 2009
Earl ya beat me to it. Or you could run to the hardware store and grab a piece of all thread and make your own. Or just a long threaded bolt and cut it off.
jeffie8696 is offline Find More Posts by jeffie8696
Old Aug 28, 2012, 06:04 AM
earlwb is offline
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
They normally don't sell 1/4x28 threaded items at the hardware store. It is a odd thread size. You usually run into the problem when you need a new 1/4x28 prop nut for a engine.
The specialty stores online have them though.
http://www.boltdepot.com/Socket_cap_...-8_1_4-28.aspx
and threaded rod too
http://www.fastenal.com/web/products...l.ex?sku=47058
But be gentle with the threaded rod as it isn't hardened like the ones from the manufacturer are or the socket cap screws.
Old Aug 28, 2012, 10:46 AM
TEAM BOCA
jeffie8696's Avatar
Joined Oct 2009
We have a Fastenal store here, so I am spoiled.
Old Aug 28, 2012, 12:16 PM
Joined Aug 2012
What size prop should I use on this? It is in a Kadet Senior.
Is 15% nitro with 15% lube fuel ok for this engine?
Old Aug 28, 2012, 01:19 PM
earlwb is offline
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
11x6 prop. The fuel is OK too. But I much prefer a fuel with at least a little castor oil in it, thus the fuels with a blend of synthetic and castor oil are what I consider the best to use. The engine works good with some castor oil in the fuel.
Old Aug 28, 2012, 01:35 PM
Joined Jun 2011
The Sportster series ran on bigger props. The instructions said 11x7 or 12x6. Some have used as big as 13x6 with good results. That engine has no ball bearings and the piston is chromed aluminum and the cylinder is aluminum. There is not much to rust so straight synthetic is OK.
Old Aug 28, 2012, 02:03 PM
Joined Aug 2012
I am having a friend that works in a machine shop make a prop stud for me. It will be made of stainless steel.
Old Aug 28, 2012, 05:21 PM
Joined Jun 2011
Stainless steel may be a bit tough. The crank would break before the threaded rod even bent.
Old Aug 28, 2012, 05:24 PM
TEAM BOCA
jeffie8696's Avatar
Joined Oct 2009
15% lube? way too low, I would use a minimum of 20%. Its a bushing airplane engine not a ball bearing car engine.
Old Aug 29, 2012, 10:57 AM
Joined Aug 2012
Could I add some caster oil to the fuel?
Sold K&B 45 sportster-used **Pricing change** Mike Fortune Aircraft - Fuel - Engines and Accessories (FS/W) 1 Nov 24, 2012 10:23 PM
Wanted Muffler for K&B .45 Sportster rmpRMP Aircraft - Fuel - Engines and Accessories (FS/W) 1 Aug 21, 2012 07:52 PM
Sold K&B Sportster 45 w/ muffler davedwards Aircraft - Fuel - Engines and Accessories (FS/W) 0 Jul 10, 2012 04:52 AM
Sold K&B 45 sportster-used Mike Fortune Aircraft - Fuel - Engines and Accessories (FS/W) 2 Jul 05, 2012 09:25 AM
Help! K&B .45 Sportster (old engine) Kyle G. Engines 16 Apr 02, 2006 10:58 AM
