Not to throw water on the fire, but direct communication with the manufacturer would probably get better results than a post in consumer advocacy on the Ezone. While your complaints are valid, I'm not sure they will ever reach the proper people by a posting in this forum.
A great addage is to "never accept a no from someone who can't say yes to begin with" Azarr www.azarr.com |
Newark, DE USA
Joined May 2001
Bill,
IMHO it's a design defect if inappropriate materials are used in an inappropriate manner. Or visa versa. ![]() It's easily fixed on the Terry by gluing blocks on the underside of the wing to fit snugly in the fuse. I learned it on ezone. It works well enough that I had to install CF rods on the leading edges of the wings to stop the divots I was getting from landing in a field with small saplings all over. I once cartwheeled it too. The wings haven't twisted off. Terry RB |
Wilkes-Barre/Scranton, Pennsylvania, United States
Joined Nov 2000
I have experienced the same problem and solved it just as RB has. In my answer to the original post this had slipped my mind which is not too unusual these days.
In retrospect I must agree that the use of inappropriate material is a design flaw. Graupner should have included some method of locking the wing in place to avoid the damage we encountered. I was lucky as my damage was very slight. |
I've always thought that the main problem with the Terry fuselage breakout was because there is no third point to prevent the wing from pivoting. Locally we fixed the problem by inserting a plywood piece about 1/2 in deep in a slot cut in the fuselage at the location of the foam insterts. The real problem solver was a nylon bolt at the trailing edge. If I had it to do over again, I would remove the molded portion that holds the nylon inserts and add a reinforced ply piece that could be drilled and tapped. That with a dowel at the front or a bolt at the rear should stop the problem.
| Thread Tools | |
| An Open Letter to CC (happy customer) | Danal Estes | Castle Creations | 1 | Sep 03, 2003 04:23 PM |
| Dander uppage (an open letter) | lrsudog | Life, The Universe, and Politics | 11 | Jun 14, 2003 04:45 PM |
| An Open Letter to All Those I have Dealt With Recently....... | jimmy6819 | Aircraft - Electric - Airplanes (FS/W) | 14 | Oct 29, 2002 02:18 PM |
| An open letter (Email) to Stephan Gasparin (CO2 motor Mfg'r) | JonB | Scale Electric Planes | 1 | Mar 14, 2002 10:46 AM |
| An open letter to all Local Hobby Shops..... | Crete1 | Vendor Talk | 7 | May 19, 2001 01:16 PM |
