Old Oct 23, 2012, 05:39 PM
Mike Smart is offline
Find More Posts by Mike Smart
Mike Smart's Avatar
Aylesbury, Buckinghamshire, Great Britain (UK)
Joined Jan 2000
Yes, great work Pat, a very interesting build thread
Mike Smart is offline Find More Posts by Mike Smart
Old Oct 23, 2012, 10:19 PM
Pat Lynch is offline
Find More Posts by Pat Lynch
a.k.a Maltone
Pat Lynch's Avatar
Australia, NSW, Goulburn
Joined Jan 2005
Thanks for the encouragement guys - but mostly I'm just following the plans.....
Darook - probably I'll use 'canopy glue' - stick plastic OK and is slightly flexible after drying clear.
Shnokey - There is a vertical longintudinal bulkhead on the centreline under the gunners platform that 'might' give a bit of protection! But I have envisaged having a dummy nose for first flights (if they happen!)
I did a bit of experimenting - the 'solid' areas mostly have normal small windows fitted to them and they also are in the area that blends into the fuselage so I've made them from .4mm ply allowing sanding, and in sections to allow some measure of double-curvature. Seems to work OK. The windows will be glazed from behind later after painting. One section of the ply panels is actually a hatch so that detail will be done later too..
More experimenting. Since the birdcage section is basically circular/slightly oval, I figured that provided a piece of clear plastic had the right fore-and-aft curvature, plus some degree of side-to-side, I might find some stuff in the house that could be used as plugs to pull heated clear plastic sheet over it. Two candidates gave me almost all the curves needed. The electric kettle, and a wine bottle with a slender neck The bottle gave some material suitable for panels close to the nose and the kettle was OK further back. A few bits of 'shirt box' plastic were tried and one taped to the frame - a bit rippley but I'll work on that with thicker plastic. At least the idea works
Pat
Pat Lynch is offline Find More Posts by Pat Lynch
Old Oct 24, 2012, 01:37 AM
darook is offline
Find More Posts by darook
darook's Avatar
Johannesburg, South Africa
Joined Apr 2006
Aaaaah..... Good ol' "Russell Hobbes" 'Stralian cookware for shaping ww2 bomber canopy.
darook is offline Find More Posts by darook
Old Oct 24, 2012, 05:54 AM
a.k.a Maltone
Pat Lynch's Avatar
Joined Jan 2005
Russell Hobbs boils water pretty well too......!
I did some more of the ply panelled segments after trying to coax some 2-way curves into the 1/64 ply. I soaked some panels and clamped them around a wine bottle and got a very small amount of convex shape but not much. Didn't matter too much up on the thick end anyway. The big rectangular hole near the top will be a sliding hatch - glazed, and will be added later.
Some more ply needs to go underneath where bomb sights etc are placed.
Dummy rear cabin bulkhead will be fitted later with the cabin doors etc.
Now I'm looking for a clear plastic hemisphere to do the nose turret with. A search of a toy store will probably bring some suitable packaging......
Pat
Old Oct 24, 2012, 02:46 PM
floss is offline
Find More Posts by floss
floss's Avatar
Auckland, New Zealand
Joined Sep 2005
The front crew of these He111's must have felt pretty exposed sitting in that glasshouse with the RAF buzzing around trying hard to ruin their day. Not a nice place to be sitting in a belly landing either.
Great job Pat, enjoyable to watch and see it developing. From my memories of my Matchbox 1.72 scale He111 the nose turret had a slightly droopy look to it.
Steve
floss is offline Find More Posts by floss
Old Oct 24, 2012, 02:56 PM
a.k.a Maltone
Pat Lynch's Avatar
Joined Jan 2005
Thanks Steve - yes, from all accounts the crew felt a bit vulnerable - OK in the early European Blitzkreig conditions where there was little opposition but when a determined enemy appeared..... But, it does give a scale modeller lots of room to 'tart it up a bit' - later
The nose turret is often sen as too much of a 'bubble' on the front. The upper line of the turret is almost at the same curve as the fixed glazing behind it but because the joint angle slopes back, it, as you say, droops. Stil looking for a suitable bubble.......
Pat
Old Oct 24, 2012, 03:25 PM
floss is offline
floss's Avatar
Joined Sep 2005
My grandmother was a motorcycle despatch rider in England during the war and told me as a boy that watching the dogfights over Kent and London were 'better than a good football match' as she put it
She and another man were severly reprimanded at one point for dragging crew from a fallen German bomber that was alight in a field - reprimanded because they were not given permission to leave their post and enter the aircraft endangering their own lives. My gran said the crew were 'just boys and bloody scared like the rest of us'.
I remember she had a great book called 'Hells Corner' about the air battles over Kent during the BoB. Lots of good photo's and text, unfortunately it perished in a house fire and I've never seen another copy since.
Old Oct 24, 2012, 03:45 PM
Wolpertinger is offline
Find More Posts by Wolpertinger
Formerly "vonJaerschky"
Wolpertinger's Avatar
Canada, BC, Comox
Joined Nov 2003
What a great story! You should be very proud of both her courage and her humanity.
Wolpertinger is offline Find More Posts by Wolpertinger
Old Oct 24, 2012, 03:54 PM
Rekitter is offline
Find More Posts by Rekitter
Rekitter's Avatar
Oakland, CA
Joined Nov 2002
Hey Pat:
I am watching your build rapidly unfold. Your He-111 is looking great. Love the work on the nose. Not sure if you guys have these down in OZ, but you should consider using a clear plastic casing from a toy in a 'bubble gum' dispenser for the tip. It would save a lot of work. Great job. Alex
Rekitter is offline Find More Posts by Rekitter
Old Oct 24, 2012, 04:39 PM
Desert Flyers is offline
Find More Posts by Desert Flyers
Desert Flyers's Avatar
Palm Desert, California
Joined Sep 2009
Also check out a container of tennis balls. Approximately right size - slightly smaller diameter and very flexible. Beautifully clear plastic. Also the top aluminum ring is perfect 1/10
scale gun ring.
We are all watching your progress with great anticipation of another fabulous masterpiece..
------Bert
Desert Flyers is offline Find More Posts by Desert Flyers
Old Oct 24, 2012, 07:23 PM
trumps is offline
Find More Posts by trumps
What's 3D?
trumps's Avatar
Australia, WA, Ellenbrook
Joined Feb 2008
Pat has people scouring the world for oddsnsods, lucky nobody has his postal address, i can just imagine the rubbish truck turning up and tipping it's load of plastic packaging rubbish on his verge, all covered in international postage stamps
Craig
trumps is offline Find More Posts by trumps
Old Oct 24, 2012, 08:56 PM
a.k.a Maltone
Pat Lynch's Avatar
Joined Jan 2005
No please guys - it's bad enough that my wife dumps every likely looking bit of plastic on the table and refers to every found item as a 'nose cone' - no doubt I was looking for one once
I finished the last solid bits of the birdcage - some rather crazy panels underneath the gunner/bomber's position. All the remaining panels must be glazed sometime in the future. Time to move on, but where?
I may start looking at the nacelles. I will probably vac-form much of them but the plan shows rather substantial built-up radiator housings - strong enough to assist in wheels-up landing according to the designer Other nacelle parts are the forward emgine housings, upper fairing over the wing and the larger lower fairings housing the UC - including the gear doors. A lot to do.
AUW incl. wheels and retracts is 3.5 lb - not a floater nor a brick (yet)
Pat
Old Oct 24, 2012, 09:15 PM
floss is offline
floss's Avatar
Joined Sep 2005
We are Frank She mentioned the rescue only once ever to me but we found out that they wanted to court martial her and the other man involved from army records that were referred too at her funeral a couple of years back. She just said she got into a lot of trouble for doing it.The records also said that she was calm under fire when truck convoys that she would escort on her motorbike were strafed so we were especially proud of her hearing that.
Looks brilliant Pat, is there a colour scheme in mind? May have to check the threads beginning to see.
Steve
Old Oct 24, 2012, 09:16 PM
trumps is offline
What's 3D?
trumps's Avatar
Joined Feb 2008
very nice mate, 3.5lb is quite good i would think, especially as the retracts are already in.
Old Oct 24, 2012, 11:07 PM
Tartago is offline
Find More Posts by Tartago
Plane crazy
Tartago's Avatar
Joined Apr 2006
That greenhouse nose is amazing!
Work of love!
Tartago is offline Find More Posts by Tartago
Discussion Here we go again California Condor Life, The Universe, and Politics 37 Aug 14, 2012 09:41 AM
Help! Here we go again! 2 cell UMX newby questions.Miniaviation parallel charger board richos Batteries and Chargers 27 Aug 13, 2012 04:48 PM
Sold Here we go again Sundowner 50 RTF just add radio and lipos..$285 plus shipping planebldr Aircraft - Electric - Airplanes (FS/W) 0 May 30, 2012 02:06 AM
Help! Here we go again--What set of programs for CNC? Mel Duval CAD/CAM 10 May 29, 2012 08:26 AM
Discussion Here we go again grunts leave Iraq go to Jordon to attack Syria treehog Life, The Universe, and Politics 10 Dec 14, 2011 03:15 PM
