Old Oct 11, 2012, 02:37 AM
Pat Lynch is offline
Find More Posts by Pat Lynch
a.k.a Maltone
Pat Lynch's Avatar
Australia, NSW, Goulburn
Joined Jan 2005
Thanks Charles - I suspect you posted the link to the spitfire build, but I found your steering solution in the B17 thread - beautiful model
Pat
Pat Lynch is offline Find More Posts by Pat Lynch
Old Oct 12, 2012, 05:15 AM
a.k.a Maltone
Pat Lynch's Avatar
Joined Jan 2005
In a bit of a flap.....
I had to take a break while Titebond dries on the flap sheeting before I can sand it so took some pictures of progress.
The original plan had a rather '70s method of hingeing with bits of balsa, ply, Formica and wire where the hinges had to assembled and fitted before the flapwas sheeted over - tricky stuff! So I modified the design and will use large Robart pin-hinges - much easier.
I have carried on a bit about the curved flaps - these pictures dont show it very well yet but the flap follows the root curvature of the wing plus the TE curves upward and blends into the large fillets at the roots to be fitted later. Also, the LE curves slightly inward which I'll show later when the hinges are installed. But now it's done - almost.
Although the flap spar is quite curved, the hinges must obviously be in a straight line (I could leave the middle one out so a simple jig was made for the drill press to get them straight and vertical - both essential.
The LE of each flap is curved in two dimensions and will be strip planked and sanded to fit snuggly into the wing.
An interesting little trick was to change the grain direction of the flap undersheeting so the inboard curvature had the grain at right angle to make it easier. Photo #2 shows the splice...
The flap horns are internal and I'm thinking about that now (my brain hurts.......)
Although somewhat off-topic - it is Spring here in Oz but this morning it snowed - bitterly cold+damaging wind = no flying........
Pat
Old Oct 12, 2012, 11:58 PM
a.k.a Maltone
Pat Lynch's Avatar
Joined Jan 2005
...and yet more flapping....
The basics of the flaps finished with the planking of the leading edge with 3/32 strips. As usual, I put a bead of Titebond (aliphatic) along the edge joints to make sanding easier, and then medium CA (wonderful stuff) on the plank-to-rib joints. The back of the strip was sprayed with CA accelerator and careful pushed into place until the CA grabbed. Half an hour later, the planking was sanded until it was a close fit into the flap location and a few pins and another picture.....
The hingeing arrangement has been decided and that should be next.
Everything was thrown together for a reality check and the flaps just start to give a clue that it is an He-111
Flying day tomorrow - getting more stick time on the Great Lakes and the D.VII...
Pat
Old Oct 13, 2012, 10:04 AM
Mike Smart is online now
Find More Posts by Mike Smart
Mike Smart's Avatar
Aylesbury, Buckinghamshire, Great Britain (UK)
Joined Jan 2000
Looking great Pat
Mike Smart is online now Find More Posts by Mike Smart
Old Oct 14, 2012, 09:14 AM
JIMA is offline
Find More Posts by JIMA
JIMA's Avatar
New Boston, Texas, United States
Joined Jan 2003
Nice
JIMA is offline Find More Posts by JIMA
Old Oct 14, 2012, 01:25 PM
Bill Smudge is offline
Find More Posts by Bill Smudge
Bill Smudge's Avatar
United States, KY, Bowling Green
Joined Jul 2011
Great work Pat, your doing a very nice job.
Bill
Bill Smudge is offline Find More Posts by Bill Smudge
Old Oct 15, 2012, 05:59 PM
a.k.a Maltone
Pat Lynch's Avatar
Joined Jan 2005
Thanks folks - it's sort of a holiday building something that's WW2-ish rather than a biplane (although the next biplane is in the planning/negotiation stages....)
A few days have been spent swearing, changing, pulling apart, learning and finally succeeding (mostly). Those curvy flaps are logical enough once the geometry is sorted but a bit of a pain while trying to make it all work!
Basically, the hinges must all be in a straight line (obviously) but the curved wing TE and flap LE should ideally coincide at full up and down. I got it fairly good given the limitation of balsa and ply but it should suffice for all but the picky
The hinge trunnions are of 1/4 or 3/8 balsa with 1/32 ply sides for reinforcing. The large Robart hinges will be glued down through the trunnions and into the rear spar. The trick was getting the right amount of hinge in the wing AND the flap so the opened and closed properly. It's now close enough and I can move on......
Anybody know what colour the spaces inside the wing would be in this class of aircraft? Obviously it is aluminium and may be some sort of chromate stuff......
Pat
Old Oct 15, 2012, 11:30 PM
a.k.a Maltone
Pat Lynch's Avatar
Joined Jan 2005
A question of balance.....
A small scale detail I did before it was forgotten was the aileron mass balances. Just bits of hard sheet glued into the ail. LE and corresponding slots cut in the wing which had already been reinforced to allow the cuts......
I wanted to start thinking about the huge wing fillets so have reassembled it all and am pondering.......
Pat
Old Oct 16, 2012, 12:45 AM
Deuce is offline
Find More Posts by Deuce
Übung macht den Meister..
Deuce's Avatar
United States, OR, Fairview
Joined Jul 2006
I notice Pat simply dumped the GLT nose first in the bin out front after he found such a compelling read!
The He is looking very nice... and dwarf-size!
James
Deuce is offline Find More Posts by Deuce
Old Oct 16, 2012, 01:00 AM
trumps is offline
Find More Posts by trumps
What's 3D?
trumps's Avatar
Australia, WA, Ellenbrook
Joined Feb 2008
Very impressive mate!
Craig
trumps is offline Find More Posts by trumps
Old Oct 16, 2012, 04:24 AM
a.k.a Maltone
Pat Lynch's Avatar
Joined Jan 2005
a couple of tips.....
The wing just didn't look right in the clipped configuration so I made the rounded 'proper' ones
Having read Frank Von J's 109 thread several times, I was interested in an alternative to the usual ".....fashion from soft block..." - the tips are about 3/4" thick so thought about two layers of 3/8 with some hollowing but didn't have any 3/8 left but lots of soft 1/4. A core was cut to shape and glued to the end rib centreline (also the aileron), a bunch of lightening holes drilled (cut with a brass tube in the electric drill), a tiny sub-rib added to support some sheet and the outline edges chamfered to glue the sheet at the edge. The grain of the tip core was fore-and-aft and the covering 1/16" sheet, span-wise. The sheet was stuck down with Titebond and when dry, sanded back to match the wing. The edge will be sanded properly when the underside is finished. Then the ailerons will be cut away and finshed off.
That'll do for today - dinner is calling.......
Pat
Old Oct 16, 2012, 10:49 AM
TPfingston is online now
Find More Posts by TPfingston
Retired and Lovin' it!
United States, KY, Sturgis
Joined Jul 2007
Looks great Pat, as usual.
Tony
TPfingston is online now Find More Posts by TPfingston
Old Oct 16, 2012, 11:28 AM
Tartago is offline
Find More Posts by Tartago
Back to EDF
Tartago's Avatar
Joined Apr 2006
I like the flaps hidden hinges.
Tartago is offline Find More Posts by Tartago
Old Oct 16, 2012, 05:16 PM
a.k.a Maltone
Pat Lynch's Avatar
Joined Jan 2005
"....I notice Pat simply dumped the GLT nose first in the bin out front after he found such a compelling read! ..."
I doubt that book would win any lit'ry prizes but I couldn't pass it up on the title It was 50c at a local womens institute garage sale!
Wing tips are done so I'm still pondering the wing fillets. We have a district scale comp in a couple of weeks and while I may enter and fly the DVII and GLT, I'd like the 111 as a 'work in progress' to show the ARFers some real balsa wood. I hope I'll have the wing fillets started and maybe get some of the nose framing cut to make it more 111-ish
Pat
Old Oct 16, 2012, 07:41 PM
trumps is offline
What's 3D?
trumps's Avatar
Joined Feb 2008
All the "fully scaled out foamie" crew will stand there scratching their heads with no idea what they looking at! You will have some explaining to do mate
Craig
Discussion Here we go again California Condor Life, The Universe, and Politics 37 Aug 14, 2012 10:41 AM
Help! Here we go again! 2 cell UMX newby questions.Miniaviation parallel charger board richos Batteries and Chargers 27 Aug 13, 2012 05:48 PM
Sold Here we go again Sundowner 50 RTF just add radio and lipos..$285 plus shipping planebldr Aircraft - Electric - Airplanes (FS/W) 0 May 30, 2012 03:06 AM
Help! Here we go again--What set of programs for CNC? Mel Duval CAD/CAM 10 May 29, 2012 09:26 AM
Discussion Here we go again grunts leave Iraq go to Jordon to attack Syria treehog Life, The Universe, and Politics 10 Dec 14, 2011 04:15 PM
