Australia, NSW, Bungendore
Joined Jan 2005
Question about washout
When I was building the wing jig mentioned previously, I made some supports for the outer panels to preserve the washout when sheeting later. The 1973 article says that 2 deg of washout should be built in. I have measured mine at 3 deg. I can always compensate with the aileron installation but does 3 deg sound excessive?
Any comments welcome...... Pat |
Latest blog entry: A Big Move.....
Joined Jan 2005
Thanks Mike - reduced it a little by clamping the wing firmly into the jig while doing the top sheeting - it seems to have set at about 2.5 deg -I'll measure it again when I release the clamps!
Pat |
Joined Jan 2005
Almost a wing....
Sheeting such a large (for me) wing was a bit daunting as I'd not done it before. So with the wing skeleton firmly clamped to the jig (also reducing the washout slightly) several sheets of 1/16 balsa were shuffled around, cut to size and taped together. The joints were glued with med. CA and the sheet sanded smooth. I fixed the skins with med CA except where they would need sanding - along the LE. This was stuck down with Titebond and clamped overnight.
After fixing a few places where the skin didn't glue to a rib ( ) It was declared covered - on top only. I have to leave most of the underside open until the servos , flaps, landing gear etc is fitted - ages away!Some foam profiles of the "glasshouse" and the engine nacelles were added to give me a feel of how big a task both will be. The nacelles, I may vacform as both left and right seem to be identical. The nose glazing? - still dreaming about it! Pat
Joined Jan 2005
Sloooooow progress.....
But it is progress.....
The design requires that the tailplane be inserted into its place before the fuselage halves are joined. Also the tail pushrods. The tailplane was set in place, squared away and the fuselage top and bottom glued together with Titebond. I had to forgo my usual CA (sob) as a bit of working time was necessary to correctly align the parts. She was taped up and left for a day to dry. The wing is now fixed with 3/8 dowels in front and two 10-32 nylon bolts behind. The mounting plates for the UC were attached to the engine bearers with bits of HW to make the retract mount level (the nacelles are at the same angle as the wings) I'm having some minor issues with this set of expensive EFlite retracts - they play up at voltages above 4.8 which is no good. Some replacements are coming..... Currently I'm cutting bits for the ailerons - and working out how they are constructed ![]() Pat |
Joined Jan 2005
Casteriing tailwheels...
Does anybody have advice on the viability of a castering tailwheel on this sort of model? I only operate off grass and the design specifies that the tailwheel is castering, not rigid or steered. I cant do anything about internal steering now the fuselage is closed but it may be possible to extend the rudder control to below the fuselage and make a link if necessary.
Any thoughts? Pat |
Joined Jan 2005
Thanks for the comments and suggestions. I'll have a look at Tartago's suggestion - it would be fairly easy to do with an unobtrusive link.
Pat |
Hi Pat
She's a beauty, great work! – I considered having a castoring tail wheel on my Guillows B17 conversions, but was advised by a number of modellers on this site to make it steerable – you can view my solution here http://www.rcgroups.com/forums/showt...5#post22328953 Best Charles |
| Thread Tools | |
| Discussion Here we go again | California Condor | Life, The Universe, and Politics | 37 | Aug 14, 2012 09:41 AM |
| Help! Here we go again! 2 cell UMX newby questions.Miniaviation parallel charger board | richos | Batteries and Chargers | 27 | Aug 13, 2012 04:48 PM |
| Sold Here we go again Sundowner 50 RTF just add radio and lipos..$285 plus shipping | planebldr | Aircraft - Electric - Airplanes (FS/W) | 0 | May 30, 2012 02:06 AM |
| Help! Here we go again--What set of programs for CNC? | Mel Duval | CAD/CAM | 10 | May 29, 2012 08:26 AM |
| Discussion Here we go again grunts leave Iraq go to Jordon to attack Syria | treehog | Life, The Universe, and Politics | 10 | Dec 14, 2011 03:15 PM |
