Australia, NSW, Bungendore
Joined Jan 2005
Dont get too excited Steve - in this case 'feral' probably refers to 11 deg C and 50 K winds niether being conducive to outdoor Springtime activities! Ah well, more time in the workshop (or painting ceilings as is Ian's want
)Pat |
Latest blog entry: A Big Move.....
Joined Jan 2005
Komet - it's still hanging from the ceiling - a few small issues that I haven't resolved yet - so I move on rather than get frustrated. But it will happen.....
![]() Pat |
Joined Jan 2005
I'm Back.....
After a brief interlude attending to a Great Lakes Trainer, the bench was cleared and the He111 box of bits retrieved from the shelf. Where was I at? After a ponder and a read of this thread (memory is getting rusty) I was attempting to match the embryo wing centre-section to the fuselage. Lots of cutting and sanding got it to roughly agree with the plan and a period of plan-scrutinising followed trying to make sense of a fairly complex structure!
The main spars out to the engines are built up of a balsa core with 1/32 ply skins. After the centre ribs, LE and TE were fitted, the whole section was fitted with vertical-grained shear webbing - BOTH sides of the main spar. It is strong! Then the area forward of the mainspar is sheeted with 1/16 balsa and later, the whole wing will be skinned in 1/16 double-skinning the main D-box leading edge from the centre out past the engine mount area. Even without the second layer of skin, it is very difficult to twist. Making things even more difficult, is the underside of the wing out the engines seems like a big compound curved area - there two minor dihedral breaks to the engines. Well that's how the 1973 plan shows it! Next will be the complicated nacelle basics - engine mounts, retracts and probably flap servos live here....... Pat |
Joined Jan 2005
A Bit Off-Topic...
It's my thread - O/T is OK
I thought it was a bit incongruous pushing a WW2 German bomber aside, to effect some maintenance on my 1900's era Ewbank carpet sweeper - about 100 years old now and still in regular use! It's good keeping contact with stuff that is older than I am (WW2 vintage )Going slightly back on-topic, the cleaner needs some new tyres - and I've often wondered about making tyres for my models. Any easy ideas? Pat |
Joined Jan 2005
Building from old plans.........
You really know what '..back to basics...' means when building from plans drawn about 40 years ago! I suppose the builder was expected to understand what was required and interpret the sometimes confusing drawings to get the desired result. That is certainly the case here
Apart from the dimensional innacuracies a hand-drawn plan inevitably brings, some aspects of the construction have been omitted, some drawn innacurately and some almost impossible. I imagine the original was a design as you go and the builder must understand-as-you-go. But it is all good character developing stuff. Things become obvious only when the preceding stages are completed. Then slight changes to the design are needed to achieve what the designer intended.Anyway, here is the result of todays work. The beginnings of the nacelles. The original had a pair of .25 glow engines hence the usual wooden bearers. I felt that redisgning would be a chore and the bearers will support the retracts so they will also be used to hold the motor mounting plates at the correct offsets. The LE sheeting shown is the underlayer of 1/16 balsa - another layer will go on top after the wing is fully framed. Now I'll ponder the plans and sort out what is needed for the outer wing panels. Pat |
Joined Jan 2005
....a bit further on.....
The wings on this beast took more time revealing their construction philosophy than I spent building them. I still didn't get it right but some minor corrections will make it good enough to sheet some day. I made some simple jigging to get this far but believe the wing panels need to be held rather accurately when 14" wide balsa sheet is applied each side! I plane to sheet one side and maybe the LE seperately and then will have to spend a lot of time on servos etc. The CS will house the Rx and the four wing servos will be in the usual modern place - in the wings
The 1973 version was a nightmare - all servos (throttles, UC, flaps, ailerons) were in the centre bay with a zillion pushrods and bell cranks out into the wings. I guess servos were expensive then ![]() The ailerons and flaps are the next nightmare.... Pat |
Joined Jan 2005
Thanks Tony - I'm glad prices are within range of my pocket nowdays
I only need 6 servos as the retracts are electric but even that will be about $100 worth!I spent a few hours today trying to understand the trailing edge stuff - ailerons and flaps. After adding many of the parts it is starting to dawn on me - the inboard trailing edge IS curved! No wonder the flap drawings look weird! The '111 always had an odd curve in the wing TE and now I understand - why? no idea. Ask Ernst Heinkel! The TE is sort of 'scaleish' with various rib extensions, aileron balance horn slots etc. All of which conspire to give me much head scratching. Add a couple of degrees of washout, tapering spars and curves, it is quite interesting ![]() The flap hinges will be next - they are close to scale in appearance and with internal horns on the curved flaps, they promise more fun......... Pat
| Thread Tools | |
| Discussion Here we go again | California Condor | Life, The Universe, and Politics | 37 | Aug 14, 2012 09:41 AM |
| Help! Here we go again! 2 cell UMX newby questions.Miniaviation parallel charger board | richos | Batteries and Chargers | 27 | Aug 13, 2012 04:48 PM |
| Sold Here we go again Sundowner 50 RTF just add radio and lipos..$285 plus shipping | planebldr | Aircraft - Electric - Airplanes (FS/W) | 0 | May 30, 2012 02:06 AM |
| Help! Here we go again--What set of programs for CNC? | Mel Duval | CAD/CAM | 10 | May 29, 2012 08:26 AM |
| Discussion Here we go again grunts leave Iraq go to Jordon to attack Syria | treehog | Life, The Universe, and Politics | 10 | Dec 14, 2011 03:15 PM |
