Old Aug 30, 2012, 11:37 AM
Chad Veich is online now
Find More Posts by Chad Veich
Scale Builder
United States, AZ, Litchfield Park
Joined Jul 2002
Originally Posted by Bare View Post
Been in a "spanish" He 111. Merlin powered :-) Believe it's crashed since?
The last regularly operated CASA belonged to the Commemorative Air Force and was operated by the Arizona wing. It was destroyed in a fatal crash in 2003. I had the pleasure of seeing the old girl many times and it was always a treat. The loss of the crew and the aircraft was a huge blow.
Chad Veich is online now Find More Posts by Chad Veich
Old Aug 30, 2012, 02:14 PM
turbonut is offline
Find More Posts by turbonut
Pro Hoarder
turbonut's Avatar
upland CA
Joined Dec 2004
Yea what a loss..I was able to Play around inside it about 6months before the crash
Old Aug 30, 2012, 10:32 PM
Tartago is online now
Find More Posts by Tartago
Plane crazy
Tartago's Avatar
Joined Apr 2006
Subbed.
Tartago is online now Find More Posts by Tartago
Old Aug 31, 2012, 04:21 AM
Pat Lynch is offline
Find More Posts by Pat Lynch
a.k.a Maltone
Pat Lynch's Avatar
Australia, NSW, Goulburn
Joined Jan 2005
The Tale Continues...
I spent the morning at the opthalmologist (did I get that right? ) but while having an afternoon nap (joys of retirement!) I worked out how to do the elevator hinges. The axis of the hinges is about 15mm back into the elevators themselves making the LE extend upward when deflected down. I wanted to use hinge-points as I had a lot and they seemed easier than the plan method of bits of Formica, balsa and other stuff. The hinges are supported in little triangle shaped hard balsa blocks fixed to the tailplane TE bringing the pivot out 15mm. The other side is fixed into balsa blocks in the elevator LE. I got all six hinges aligned and moving freely as one Not only that, the elevator assembly can be reversed end-for-end and they STILL lineup - amazing!
The wire U-link joining the elevators was epoxied in place before the upper and lower halves were finally glued. AND I didn't forget to silver solder the brass horn in place first! The rudder will have a similar horn and all hidden behind a balsa tailcone later.........
Now I have to start cutting main wing parts. I want to get this started before rushing into another Rakian build.....
Pat
Pat Lynch is offline Find More Posts by Pat Lynch
Old Sep 02, 2012, 01:42 AM
a.k.a Maltone
Pat Lynch's Avatar
Joined Jan 2005
Slow Progress..
It's taken a few days to get this basic centre-section done. Most of it was trying to interpret the plans! The various ply/balsa laminated spars were not at all obvious but I've dry-assembled the basics to see what I may have done wrong. Mostly nothing Some adjustments to slot depths/widths are needed but mostly it looks about right. The nacelles are situated adjacent to the outermost ribs shown. The main spar has vertical shear-webbing to be fitted after it is all glued together. But before then, I need to cut access holes for servo leads (many) and battery leads to the motors. Every thing will be sheeted in 1/16 balsa with most of the front wing section double-skinned.
The ribs under the fuselage are exactly 3" deep - I get two or three ribs from each sheet of balsa ........ now I've almost run out and will have to wait for the next trip to town for more! I also need the motors and retracts before going much further so building may slow considerably. But, as always, there is another Peter Rake model to be built...........
Pat
Old Sep 02, 2012, 09:35 AM
Steve85 is offline
Find More Posts by Steve85
The "pro" in procrastination
Steve85's Avatar
Canada, ON, Kingston
Joined Mar 2004
She's already a beaut, Pat. It sure looks as though you've captured the smooth lines of the fuselage and tail surfaces. Any chance you could post some close-ups of your elevator hinges?
Steve
Steve85 is offline Find More Posts by Steve85
Old Sep 02, 2012, 04:17 PM
a.k.a Maltone
Pat Lynch's Avatar
Joined Jan 2005
Steve - your wish is my command......
The little balsa stubs are a bit fragile at the moment but will obviously be plenty strong enough when the hinges are epoxied in place.
Pat
Old Sep 02, 2012, 04:40 PM
trumps is offline
Find More Posts by trumps
What's 3D?
trumps's Avatar
Australia, WA, Ellenbrook
Joined Feb 2008
She is looking great, , looks very sleek, are the wing fillets built up balsa, or another method Pat?
Cheers
Craig
trumps is offline Find More Posts by trumps
Old Sep 02, 2012, 04:44 PM
D-Rock is offline
Find More Posts by D-Rock
D-Rock's Avatar
Phoenix, AZ
Hey Pat, wow another really cool bird. And you are really cranking this one out! My hat is off to you, I always liked the 111 but so many compound curves . Keep up the good work.
D-Rock
D-Rock is offline Find More Posts by D-Rock
Old Sep 02, 2012, 05:07 PM
a.k.a Maltone
Pat Lynch's Avatar
Joined Jan 2005
Thanks folks - Craig, the wing fillets will be planked over triangular formers. They are why I wanted to get the CS done so the fuselage doublers could be cut accurately to match the wing. But I've almost run out of balsa so may have to put this aside for a short while.
Pat
Old Sep 02, 2012, 05:22 PM
trumps is offline
What's 3D?
trumps's Avatar
Joined Feb 2008
Ah, makes sense, she will look a treat when done. So any clues on what your, and Pete's next masterpiece will be? A nationality at least must be about due for something from the Royal Flying Corps eh
Cheers
Craig
Old Sep 02, 2012, 05:56 PM
a.k.a Maltone
Pat Lynch's Avatar
Joined Jan 2005
Hey Craig - the next Rakian endeavour will be (I hope) a quickish build, CIVILIAN! and from North America! Now there's some clues for you.
Pat
Old Sep 02, 2012, 07:07 PM
JIMA is offline
Find More Posts by JIMA
JIMA's Avatar
New Boston, Texas, United States
Joined Jan 2003
Something with a "Curtis" in the name?
JIMA is offline Find More Posts by JIMA
Old Sep 03, 2012, 09:58 AM
Steve85 is offline
Steve85's Avatar
Joined Mar 2004
Thanks for the close-ups, Pat. That's really slick, and I've filed your pics away for future use!
Steve
Old Sep 06, 2012, 10:22 PM
a.k.a Maltone
Pat Lynch's Avatar
Joined Jan 2005
To keep Ian (Ozybard) at bay, a recent trip to the LHS resulted in 20 sheets of balsa, misc wire, tube, glues etc, plus, $$$ worth of E-Flite retracts. I'd considered the cheaper HobbyKIng ones but the LHS has these in stock so........
Meanwhile, back to the Great Lakes Trainer
Pat
Discussion Here we go again California Condor Life, The Universe, and Politics 37 Aug 14, 2012 09:41 AM
Help! Here we go again! 2 cell UMX newby questions.Miniaviation parallel charger board richos Batteries and Chargers 27 Aug 13, 2012 04:48 PM
Sold Here we go again Sundowner 50 RTF just add radio and lipos..$285 plus shipping planebldr Aircraft - Electric - Airplanes (FS/W) 0 May 30, 2012 02:06 AM
Help! Here we go again--What set of programs for CNC? Mel Duval CAD/CAM 10 May 29, 2012 08:26 AM
Discussion Here we go again grunts leave Iraq go to Jordon to attack Syria treehog Life, The Universe, and Politics 10 Dec 14, 2011 03:15 PM
