Old Aug 28, 2012, 05:36 AM
Pete1978 is offline
Find More Posts by Pete1978
Lincoln, UK
Joined Jun 2005
I saw one of these flying about fifteen years ago at the local club, powered by a couple of two strokes. I remember it went well and the builder said it was the nicest twin he'd ever flown, quite manageable one one engine - Not, of course, that an engine out should happen to you with outrunners. I look forward to watching this one come together, I'm sure it'll be yet another masterpiece!
Pete
Pete1978 is offline Find More Posts by Pete1978
Old Aug 28, 2012, 06:09 AM
Pat Lynch is offline
Find More Posts by Pat Lynch
a.k.a Maltone
Pat Lynch's Avatar
Australia, NSW, Goulburn
Joined Jan 2005
Good to hear it should fly well Pete. Masterpiece? it's always something to aim for but there are quite a few firsts for me in this build so much new ground!
Steve - I wasn't thinking of a zwilling, but an alternative nose (F version) is a snap-on alternative!
Pat
Pat Lynch is offline Find More Posts by Pat Lynch
Old Aug 28, 2012, 06:37 AM
trumps is offline
Find More Posts by trumps
What's 3D?
trumps's Avatar
Australia, WA, Ellenbrook
Joined Feb 2008
great idea with the brass tube in the drill chuck, will lock that one away for later!
Cheers
Craig
trumps is offline Find More Posts by trumps
Old Aug 28, 2012, 03:04 PM
Rekitter is offline
Find More Posts by Rekitter
Rekitter's Avatar
Oakland, CA
Joined Nov 2002
Hey Pat:
Great choice of model. I built one about 8 years ago from Tom Hunt's plans. I can tell you that it is a great flyer with those big fat wings and that it always gets a lot of attention. I am looking forward to following your progress and I am sure that this will be a winner.
Alex
Rekitter is offline Find More Posts by Rekitter
Old Aug 28, 2012, 05:23 PM
a.k.a Maltone
Pat Lynch's Avatar
Joined Jan 2005
Thanks Alex - I had read through your build previously. (including the clash of power calculating egos ) I am very glad that the electric power scene has become much more predictable today
This bird is much bigger and designed for twin .25s so I stll have some redesigning to do - battery placement etc. Hopefully my trials and tribulations will be fewer than yours!
Cheers - Pat
Old Aug 28, 2012, 08:30 PM
kdahlhaus is offline
Find More Posts by kdahlhaus
kdahlhaus's Avatar
United States, OH, Westlake
Joined Mar 2002
Pat, what a great choice! My only regret is that you didn't convince Peter to design one. I've been collecting info on HE-111 modesl, hope you don't mind me posting it here.
paper card build thread with links to many details
http://www.zealot.com/forum/showthre...=146040&page=3
nice one from card model
http://www.rcgroups.com/forums/showthread.php?t=259789
real he-111 pics:
http://www.richard-seaman.com/Aircra...111/index.html
or ~/parkflyers/plans/he-111
89" kit: http://www.vanvan.us/he111.htm
http://www.rcgroups.com/forums/showthread.php?t=1001036
graupner 60"
I got it from Motors and Rotors in the UK
www.motorsandrotors.com
https://shop.graupner.de/webuerp/servlet/AI?ARTN=9594
Wingspan 1750mm
Length 1280mm
Weight Approx 3000g
Wing section symm. 17%
Wing area 48dm sq.
[img[http://static.rcgroups.net/forums/at...d=1263712457]]
55" Tom Hunt design - plans http://www.aerocraftrc.com/planepage.php?id=79
Heinkel He-111
German medium bomber (after war spanish CASA version)
Sport scale, geared 480 model
Designed for H-100/Speed 480
16 CP-1300 (series motors) or 8 cell CP-1700 (parallel motors)
Wing span: 55"
Wing area: 510 sq.in.
Length: 40"
Contact Bill at Aerocraft. He has the cut files. I do not know what he charges.
aerocraft@aerocraftrc.com
http://www.rcgroups.com/forums/showthread.php?t=100895
http://www.rcgroups.com/forums/showthread.php?t=1349769
Finished Tom Hunt's He-111 about a month age. She is weighing in at a 'svelt' 76 ounces with battery and 58 without battery (2400mah Nicad). I ended up using a 2 liter bottle and a bubble gun machine top for the nose. The camo was lustercote painted on monokote. The gear are fixed. All of the riging is for scale appearance.
[img[http://static.rcgroups.net/forums/at...d=1062351251]]
[img[http://static.rcgroups.net/forums/at...d=1062351622]]
[img[http://static.rcgroups.net/forums/at...d=1074509471]]
[img[http://static.rcgroups.net/forums/at...d=1119215313]]
kdahlhaus is offline Find More Posts by kdahlhaus
Old Aug 28, 2012, 09:28 PM
a.k.a Maltone
Pat Lynch's Avatar
Joined Jan 2005
Thanks for all the links! - I have already done a fair bit of research and your photos were noted on rcgroups As noted earlier, this design is about 19" greater in span than Tom's plan and has additional complextity to go with it. No Coke bottle noses unfortunately - unless they make them 6" diameter I also have several card model versions - they almost convinced me to make a Depron version - still tempting down the track!
You are obviously an He111 enthusiast!
I doubt Peter Rake would be convinced to design a 2 engined model let alone a WW2 machine with retracts But then again........
Pat
Old Aug 28, 2012, 10:59 PM
a.k.a Maltone
Pat Lynch's Avatar
Joined Jan 2005
Finny Business....
Because it was the next simplest subassembly, the fin/rudder/trimtab was next.
Like the tailplane/elevators to be done next, the vertical bits are built in two halves. They are also sheeted while pinned down flat on the board - much easier with a flat side! Blocks are built into the parts to support two Robart hinge-point hinges. These are invisible when finished as the fin skin extends past the rudder-post forming a channel for the rudder LE. 1mm sheet was used for skinning to save a gram or two of weight over 1/16". The trim tab is separate but non-functional
Rudder post and fin LE extend down into the fuselage and will be secured later.
The tailplane/elevator is built the same way but much more complex. Both tail sections are quite thick - around 3/4" The horizontal parts are being cut now - lots....
Pat
Old Aug 29, 2012, 07:34 AM
Vik_ is offline
Find More Posts by Vik_
Vik_'s Avatar
Prague CZ
Joined May 2010
Hallo Pat
Please find bellow few pictures of the CASA version I took from Museum in München
Vik_ is offline Find More Posts by Vik_
Old Aug 29, 2012, 08:11 AM
trumps is offline
What's 3D?
trumps's Avatar
Joined Feb 2008
some great photos there, i wonder how many hours it took to get all that plexiglass so clear, better than out of the factory i bet!
Craig
Old Aug 29, 2012, 09:55 AM
jhspring is offline
Find More Posts by jhspring
Oh no, not again!
jhspring's Avatar
United States, LA, Carencro
Joined Dec 2005
You're really smoking with this one, Pat. Interesting construction method, makes things a lot easier in some ways.
Regards,
Jeff
jhspring is offline Find More Posts by jhspring
Old Aug 29, 2012, 01:39 PM
darook is offline
Find More Posts by darook
darook's Avatar
Johannesburg, South Africa
Joined Apr 2006
Oh yes Pat! Real excited now!
darook is offline Find More Posts by darook
Old Aug 29, 2012, 03:47 PM
a.k.a Maltone
Pat Lynch's Avatar
Joined Jan 2005
Thanks for the photos Vik - some great shots into the cockpit from above!
Craig
Craig - if I could make a canopy that clear, I'd be a very happy chappy
Pat (still tailplane-ing.....)
Old Aug 30, 2012, 05:38 AM
a.k.a Maltone
Pat Lynch's Avatar
Joined Jan 2005
The horizontal bits are mostly done with the exception of the hinges. The original design uses some dismantled hinge-point style hinges but the modern versions are a bit different so I'll visit the LHS tomorrow and have a look. The scale type hniges are in cutouts in the elevators so the elevator is balanced (LE extends upward when the TE goes down). A U-link has to be embedded between the elevator upper and lower halves so am still working out a jig to get it aligned!
A very useful method of holding fragile stuff (like wings and tail frames) when sanding is a sheet of 120 grade sandpaper stuck to the bench with double-sided tape. Just a light downward pressure holds a frame in place while sanding etc....
A potential delay in this project arrived today in the form of yet another Peter Rake kit. I have worn out my Funtana and want a sturdy mildly aerobatic machine which is scale and Pete suggested a ............... build thread soon when I get some bits together Thanks for the box Charlie!
Pat
Old Aug 30, 2012, 11:01 AM
Bare is online now
Find More Posts by Bare
Canada
Joined Nov 2000
Been in a "spanish" He 111. Merlin powered :-) Believe it's crashed since?
It was actually a surprisingly small aircraft.
Basic memorable impression was of an odd /goofy design.. far smaller than I had ever imagined.
Clearly from the transition of the golden age to 'moderne'.
Simply cannot image being in it as a "bomber' on a run... with it's dozen wee bombs. Pee-shooter machine guns, lumbering /slow/ flight, fish bowl cockpit... etc. Might just as well of painted them with target rings... instead of camo.
Looks to be an interesting project though.
Bare is online now Find More Posts by Bare
Discussion Here we go again California Condor Life, The Universe, and Politics 37 Aug 14, 2012 09:41 AM
Help! Here we go again! 2 cell UMX newby questions.Miniaviation parallel charger board richos Batteries and Chargers 27 Aug 13, 2012 04:48 PM
Sold Here we go again Sundowner 50 RTF just add radio and lipos..$285 plus shipping planebldr Aircraft - Electric - Airplanes (FS/W) 0 May 30, 2012 02:06 AM
Help! Here we go again--What set of programs for CNC? Mel Duval CAD/CAM 10 May 29, 2012 08:26 AM
Discussion Here we go again grunts leave Iraq go to Jordon to attack Syria treehog Life, The Universe, and Politics 10 Dec 14, 2011 03:15 PM
