Old Dec 28, 2012, 02:38 PM
Pat Lynch is offline
Find More Posts by Pat Lynch
a.k.a Maltone
Pat Lynch's Avatar
Australia, NSW, Goulburn
Joined Jan 2005
Yes Phil, it is a bit daunting! Mostly the size of that wing (which is by far the most difficult bit). If I ever built it again (highly unlikely!) there are many things I'd do better, if not differently. Sorting out UC retracts, tailwheel steering, wing servos etc Plus paying a bit more attention to the tricky areas around the nacelles and where they fit the wings.............
But I'm sure you will have fun.
I just got the plans for a project in the near future and it's even more intimidating although not a lot bigger Challenges are good for you - I think............
The long delay since my last progress report is not only Xmas but prepping he wing for its final paint....
Pat (challenged..)
Pat Lynch is offline Find More Posts by Pat Lynch
Old Dec 28, 2012, 09:20 PM
a.k.a Maltone
Pat Lynch's Avatar
Joined Jan 2005
Pressing on........
With the excitement of a couple of new builds looming (Christmas presents - sort of ) it is getting harder to keep on with this beast! But, a bit of masking and some Tamiya acrylic and the upper-surface painting is mostly done.
The areas to be masked were edged with Tamiya 1/4" wide tape (the nicest and most expensive I've found...) and the upper surface dark green (Dunkelgrun) areas sprayed Tamiya Dark Green. When dry, the remaing black-green zones (Schwartzgrun) was masked and sprayed Tamiya Black-Green. The undersides had been previously sprayed light blue without any masking.
There is a bit of touching up to do yet but I'll leave that until the flaps and ailerons are ready for paint. The slightly blotchy look was deliberate to avoid a 'factory fresh' look and make the grottying up a little easier later.
The cowls have a lot of work to do as, like the BF109 (similar engines), there are air scoops, big supercharger intakes and exhausts to do yet.......
Pat
Old Dec 28, 2012, 10:33 PM
Bart83 is offline
Find More Posts by Bart83
71% of the world is runway . .
Bart83's Avatar
Nederland, ZH, Oostvoorne
Joined Jun 2009
This plane is really becoming very nice !! also like the wheather on the other side of the globe
Keep up the good work !!
Cheers,
Bart
Bart83 is offline Find More Posts by Bart83
Old Dec 29, 2012, 12:40 AM
Robert R is online now
Find More Posts by Robert R
It's a fine fiddly business.
Robert R's Avatar
United States, WA, Marysville
Joined May 2009
Really pretty in a pit bull sort of way. Very good work.
Best,
Robert
Robert R is online now Find More Posts by Robert R
Latest blog entry: Hidden Kit Built Projects
Old Dec 30, 2012, 12:07 AM
a.k.a Maltone
Pat Lynch's Avatar
Joined Jan 2005
A Day in the Workshop....
I didn't go flying today (Sunday) because of the wind, so finished off the wing control surfaces.
Like the rest, the surfaces were filled/tissue-covered/doped and then painted.
For anybody interested, the balsa was fine sanded and then given a sloppy mix of dope thinned about 50% and mixed to a slurry with talcum powder. When dry, it was sanded and then any cracks or dips were filled with lightweight spackle crack filler and the dope/talc reapplied and sanded smooth.
000 grade 'silkspan' tissue was doped over the area using a sponge to smooth out any wrinkles. It was applied dry as I've found a damp application makes the tissue very easy to tear. A further couple of dope coats and fine sanding prepared it for paint. The pale blue underside was airbrushed on first and then the upper surfaces given the Nato Green Tamiya acrylic. When dry, the Black-Green areas were masked with lo-tack tape and the paint applied. After removing the masking straight away, the areas that are usually in shadow (various slots and the surface LE) were also given a coat of black-green feathering it out to the surface. It may help creating the illusion of shadow in the hinge areas. But more of that yet to do.
The many Robart hinge-points were fitted and the whole lot test-assembled and checked for movement. All OK! Nothing is glued yet.........
One picture shows a fuselage with extra paint (untintentional) My lack of peripheral vision (glaucoma) often lets me not see things when waving an airbrush around ...........I cleaned it off and repainted - no worries
I guess the nacelles are next!
Pat
Old Dec 30, 2012, 05:51 AM
Tartago is offline
Find More Posts by Tartago
Back to EDF
Tartago's Avatar
Joined Apr 2006
Exemplary work of art!
She´s looking every time better and better.
Tartago is offline Find More Posts by Tartago
Old Dec 31, 2012, 01:45 AM
a.k.a Maltone
Pat Lynch's Avatar
Joined Jan 2005
Thanks for the kind comments everyone But....
I've come to recognise over the years the symptoms of an oncoming bout of 'burn-out' - the 111 has been about 4 months work at 4-6 hours per day AND with a 3 week panic in the middle to do Peter Rake's Great Lakes Trainer.
The obvious answer might be to go fishing or take up heavy drinking! But for me it's a simple matter of starting something new - maybe even another model build, until the urge returns
So faced with some more vac-form work on the 111 nacelle details and the undercarriage generally (not to mention finishing the cockpit glazing) I'm starting another model! With the almost finished bomber hanging over my head (literally as well as figuratively) I've tidied the workshop and am studying some new plans..........
Pat
Old Dec 31, 2012, 08:36 AM
dglo is offline
Find More Posts by dglo
Cut it twice, still too short
dglo's Avatar
Bay City, MI
Joined Oct 2007
So close and yet so far. I know the feeling, but I was looking forward to the finish of this one.
When it stops being fun, it's time for a change. Waiting to see what's next!
Doug
dglo is offline Find More Posts by dglo
Old Dec 31, 2012, 12:01 PM
Clancy is online now
Find More Posts by Clancy
Clancy
Clancy's Avatar
Davis,CA US
Joined Jun 2005
It is looking pretty awesome! Starting another model because burnout from the model your building? I am trying to come up with an alcoholic equivalent. Like drinking Vodka when I am burnt out on Scotch? Happy New Years!
Clancy is online now Find More Posts by Clancy
Old Dec 31, 2012, 01:46 PM
a.k.a Maltone
Pat Lynch's Avatar
Joined Jan 2005
Dont panic folks - I'm still working on the aforementioned bits but while I allow myself to think of other projects I'm not at all happy with the UC arrangement and the UC doors so am rebuilding the plug to mould some more. But more than anything else, I love the planning, researching and woodwork of a new project and so will just slow down on the finishing up of the Heinkel........
Pat
Old Dec 31, 2012, 08:03 PM
Longhorne is offline
Find More Posts by Longhorne
Res Ipsa Aviatur
Longhorne's Avatar
Sonoma County CA!
Joined Jul 2007
Whew! I feel better. I fully appreciate the burn out factor but I'm looking forward to seeing this one fully Maltone'd.
Happy New Year, Pat!
Paul
Longhorne is offline Find More Posts by Longhorne
Old Dec 31, 2012, 09:34 PM
trumps is offline
Find More Posts by trumps
What's 3D?
trumps's Avatar
Australia, WA, Ellenbrook
Joined Feb 2008
fair enough Pat, glad to hear you are still pottering away with it.
happy new year to you and yours
Craig
trumps is offline Find More Posts by trumps
Old Dec 31, 2012, 10:14 PM
a.k.a Maltone
Pat Lynch's Avatar
Joined Jan 2005
Just to keep the thread ticking over I modified the underside cowl plug. It is now closer to the real thing. Sadly the plan shows it somewhat incorrectly even though a model built from the plan had it right!
I'll give the plug a coat of epoxy to harden the surface before attempting some more vac-forming. Just in case I needed to make any more!
Pat
Old Jan 01, 2013, 11:36 AM
JIMA is offline
Find More Posts by JIMA
JIMA's Avatar
New Boston, Texas, United States
Joined Jan 2003
Glad to hear you will be drifting back to the He from time to time. I know how you feel about the greener grass of a new model. I always seem to have 2 or 3 models at varying stages of completion. There is nothing like the promise of a new project at the beginning stage. However, the He looks too good to let languish too long. Now that I am getting over the flu and the holidays, I need to get finished writing up the N17 for Peter. Would one of your new projects be something Peter has dreamed up?
Jim
JIMA is offline Find More Posts by JIMA
Old Jan 08, 2013, 08:21 AM
Smokin' Beaver is offline
Find More Posts by Smokin' Beaver
Registerd Beaver
Smokin' Beaver's Avatar
Australia, WA, Warwick
Joined Jul 2003
Hey Pat,
Bungendore made the news here tonight with the bush fires there.
Stay safe mate.
- Phil
Smokin' Beaver is offline Find More Posts by Smokin' Beaver
Discussion Here we go again California Condor Life, The Universe, and Politics 37 Aug 14, 2012 10:41 AM
Help! Here we go again! 2 cell UMX newby questions.Miniaviation parallel charger board richos Batteries and Chargers 27 Aug 13, 2012 05:48 PM
Sold Here we go again Sundowner 50 RTF just add radio and lipos..$285 plus shipping planebldr Aircraft - Electric - Airplanes (FS/W) 0 May 30, 2012 03:06 AM
Help! Here we go again--What set of programs for CNC? Mel Duval CAD/CAM 10 May 29, 2012 09:26 AM
Discussion Here we go again grunts leave Iraq go to Jordon to attack Syria treehog Life, The Universe, and Politics 10 Dec 14, 2011 04:15 PM
