Old Aug 27, 2012, 06:08 AM
Pat Lynch is offline
Find More Posts by Pat Lynch
a.k.a Maltone
Pat Lynch's Avatar
Australia, NSW, Goulburn
Joined Jan 2005
Build Log
Heinkel He111 74" Plan build
With the Fokker DVII done and dusted (although Pete is waiting for a bit more stuff for his FSM column) and the SPAD nearing completion, I was starting to feel a yearning for some real modelling that involved cutting balsa I have another Rakian project somewhere down the track, and had considered slipping in a small IPS design to keep my cutting hand from seizing up! But fate stepped in and a local aeromodeller (who also owns the cafe I drink coffee and eat meat pies at) shoved a bunch of plans in my face and said "...these look right up your alley...". Always a mug for big plans of scale models, they were duly perused One was a largish JU-88 and the other ....... one near the top of my 'bucket list', a 74" Heinkel HE111 . Despite its popularity as an aeoplane, only a few models of it seem to be built - probably the awkward shapes (lack of straight lines) make it a bit daunting. Anyway, in for a penny, in for a pound - I was hooked
The model was designed in the early '80s by Chas Maund and published in 'Radio Modeller' in 1983. Some searching the web turned up a copy of the original article (here on rcgroups!) but only one mention of anyone having built and flown it apart from the designer. At 74" span (1/12 scale) it is not HUGE, but should have a fair presence in the sky as the wing is of substantial chord and about 2.5" thick!
Construction is quite difficult with an all-planked fuselage, scale-ish hingeing of all control surfaces (including the strange flaps), balsa skinned, retracts and that marvellous greenhouse of a cockpit! Also, the plan is for twin .25 2 strokes but nowdays electric substitutes will be easy. Only have to work out where to put the battery(s).
As it was never designed as a beginner's project, instruction in the article or the plan are sparse. Many of the techniques and materials are very '80s but I'll only change them if it will be an improvement. Substituting individual servos for flaps and ailerons instead of a maze of pushrods, bellcranks and central servos is an example.
So, much studying of the 3 large plans and attempt to work out this beast!
Here is a picture of the real aircraft for those who may not know it (no-one on this forum surely ) and a model built from the plan.
Pat (sharpening his #11 blade)
Pat Lynch is offline Find More Posts by Pat Lynch
Old Aug 27, 2012, 07:13 AM
jhspring is online now
Find More Posts by jhspring
Oh no, not again!
jhspring's Avatar
United States, LA, Carencro
Joined Dec 2005
How cool Pat. Looking forward to this build. You going to build functional machine guns? Can't wait to see what over-the-top scale details you put in this one.
Regards,
Jeff
jhspring is online now Find More Posts by jhspring
Old Aug 27, 2012, 07:24 AM
a.k.a Maltone
Pat Lynch's Avatar
Joined Jan 2005
Jeff - just for a change, I'd like to keep it 'as per plan'. It's difficult enough! And 1/12 scale means, I'm afraid, no working guns.......
Pat
Old Aug 27, 2012, 07:50 AM
Oh no, not again!
jhspring's Avatar
Joined Dec 2005
Pat
ROFL. Good luck with that! The little demon sitting on your shoulder will soon be saying things like, "You really know it needs scale mass balances, and since you are doing those, working trim tabs and...."
Regards,
Jeff
Old Aug 27, 2012, 09:48 AM
trumps is offline
Find More Posts by trumps
What's 3D?
trumps's Avatar
Australia, WA, Ellenbrook
Joined Feb 2008
Great project Pat, should be another cracker build to follow! are the wings removable as one piece, or is the center section part of the fuse? just thinking in terms of battery location, maybe a big stick of LiFe's inside the fuse and charge them in plane?
Looking forward to it!
Craig
trumps is offline Find More Posts by trumps
Old Aug 27, 2012, 05:24 PM
ozybard is offline
Find More Posts by ozybard
Fugative Pom
ozybard's Avatar
Queanbeyan, NSW,Australia
Joined Jul 2009
Looking forward to seeing what you do with this.
ozybard is offline Find More Posts by ozybard
Old Aug 27, 2012, 05:51 PM
a.k.a Maltone
Pat Lynch's Avatar
Joined Jan 2005
A Start......
I figured the fuselage would be the best place to start - that was before I found the 1983 construction article! Oh well.........
The model has a one-piece wing which is where most of the action is! 4 servos, engines, retracts and maybe batteries and escs. The jury is still out regarding a large central battery or individual ones. The glasshouse makes forward access a bit tricky but I'll play it by ear. In any event, I'd run paralleling wiring to couple two batteries if fitted.
The fuselage is built exactly as Peter Rake would have done Two halves built on a horizontal crutch. The 'crutch' is not shaped parts as is usual but 1/4X1/8 strip curved and pinned to the board like longerons. The 1/2 formers hold it in shape when glued. The plans show where to remove large chunks of the bigger formers after the shell is finished - I precut them to make the job easier later.
The fuselage is planked like a model ship hull - not hard when into the swing of things. Tapered strips are cut with bevelled edges and applied on alternating sides. To make the job quicker, I cut a strip and laid it against the fuselage marking its upper edge. A bead of aliphatic glue was run along the previous edge, medium CA was applied to the former up the pen mark, and CA accelerator sprayed on the strip where it will touch the former. The strip is progessively pressed into place and held until the CA grips and the aliphatic oozes out. Then do the other side plank. I finished up with a couple of odd shaped bits and no filler needed.
A tip - when marking the plank edge on the former, put a spot of ink on the plank - it shows where to spray the accelerator!
The bottom side was done the same way but has ply doublers behind the planking around the wing seat area.
The 1/2 shells were rough sanded in-situ before unpinning. Now I have two half-Heinkels - a couple of day's work
Pat
Old Aug 27, 2012, 06:34 PM
a.k.a Maltone
Pat Lynch's Avatar
Joined Jan 2005
Originally Posted by jhspring View Post
... "You really know it needs scale mass balances, and since you are doing those, working trim tabs and...."
Jeff
Jeff, the plans already show the mass balances, scale-style hinging etc All moving surfaces except the rudder are a nightmare! Hinges are of 1/16 Formica on the elevator and flaps, the ailerons show Robart hinge-points but with scale dummy hinges - all different sizes The flaps have internal linkages but the ailerons seem to be external - but I'm not certain. The trim tabs are all separate but fixed ()
So I dont need much more complication than that
Pat
Old Aug 27, 2012, 07:05 PM
Steve85 is offline
Find More Posts by Steve85
The "pro" in procrastination
Steve85's Avatar
Canada, ON, Kingston
Joined Mar 2004
I'm subscribed!
Steve85 is offline Find More Posts by Steve85
Old Aug 27, 2012, 07:42 PM
Deuce is offline
Find More Posts by Deuce
Übung macht den Meister..
Deuce's Avatar
United States, OR, Fairview
Joined Jul 2006
Deuce is offline Find More Posts by Deuce
Old Aug 27, 2012, 08:21 PM
JIMA is offline
Find More Posts by JIMA
JIMA's Avatar
New Boston, Texas, United States
Joined Jan 2003
Wonderful subject. Should make a real floater of an airplane with that big thick wing. Should go well with your D-Rock Hurricane. I for sure will be watching.
Jim
JIMA is offline Find More Posts by JIMA
Old Aug 27, 2012, 10:28 PM
Wolpertinger is offline
Find More Posts by Wolpertinger
Formerly "vonJaerschky"
Wolpertinger's Avatar
Canada, BC, Comox
Joined Nov 2003
Nice choice, Pat. I always like the 111, too. To be honest, I prefer the models up to the "F" series, with the more conventional nose. But that big piece of glazing up front sure is interesting, too. By the way, how are you going to do that? Can't wait to see what you come up with!
Wolpertinger is offline Find More Posts by Wolpertinger
Old Aug 27, 2012, 11:11 PM
a.k.a Maltone
Pat Lynch's Avatar
Joined Jan 2005
Frank - I'll show the nose part of the plan later. The nose is all fully framed with wisps of 1/8 ply cut to make the frames and each panel of glazing added individually!
I had just read through your ill-fated 109 thread looking for treatment of balsa skins - I've never tried dope-on-tissue-over balsa but it sounds about right for this.
I'd considered a mod for an early mk. and do it in pseudo-civilian colours but the wings had even more curves being semi elliptical so was drawn back to the dark side Then there is the Condor Legion variant - still possible I think with the conventional, longer nose. Could be easier to fit a nose battery too. Hmmm......
Jim, I'd love to make it a floater - at 1" = 1' scale, a max speed of 273 mph is only 22mph - definitely floating! So weight will be important.....
Pat
Old Aug 28, 2012, 03:35 AM
a.k.a Maltone
Pat Lynch's Avatar
Joined Jan 2005
I tacked the two fuselage halves together to sand them more carefully. Best way to eliminate bumps, ridges etc, is to work with a single light source that casts shadows where the blemishes occur and sand that area with a sanding block or stick until the shadows are gradual. Rotating the fuselage and watching for the bumps and imperfections then sanding them out should give a smooth surface.
Another little trick I tried was cutting holes in balsa sheet. A wood bit invariably gives a woolly or rough hole and while sharpened brass tube cuts OK by hand, I had dozens to do so mounted the tube (1/2" in this case) in the drill press on lowest speed and bingo! - perfect holes, no chipping, or split edges The tube needs cleaning out occaisionally but otherwise works well. The holes are just to remove unneeded wood from the rear formers.
The second picture shows the assembled fuselage over the wing plan.....
Pat
Old Aug 28, 2012, 05:14 AM
floss is offline
Find More Posts by floss
floss's Avatar
Auckland, New Zealand
Joined Sep 2005
Always been one of my favourites, a real sinister looking aeroplane. When I see a picture of a He111 I always think of that much printed photo of one taken from above as it passed over the Thames and London during the blitz.
You say Pat that it is seldom modeled and I have always wondered if this is because of that glasshouse nose that looks so distinctive, I think this would put a few people off not so much for the work involved in building it but more the fact that one not so perfect landing and
Watching this one for sure, maybe you can just carry on after that first fuselage and make another one for a Zwilling
Steve
floss is offline Find More Posts by floss
Discussion Here we go again California Condor Life, The Universe, and Politics 37 Aug 14, 2012 09:41 AM
Help! Here we go again! 2 cell UMX newby questions.Miniaviation parallel charger board richos Batteries and Chargers 27 Aug 13, 2012 04:48 PM
Sold Here we go again Sundowner 50 RTF just add radio and lipos..$285 plus shipping planebldr Aircraft - Electric - Airplanes (FS/W) 0 May 30, 2012 02:06 AM
Help! Here we go again--What set of programs for CNC? Mel Duval CAD/CAM 10 May 29, 2012 08:26 AM
Discussion Here we go again grunts leave Iraq go to Jordon to attack Syria treehog Life, The Universe, and Politics 10 Dec 14, 2011 03:15 PM
