Old Nov 24, 2003, 12:06 AM
lttakas is offline
Find More Posts by lttakas
owings mills MD
Joined Feb 2003
20$ U-2 foam glider made in rc air plane
I bough a huge 74 inch glider.Started to looking around and thought to my selph that this thing can be converted so thats what i did.Still in construction but will post pic ASAP
lttakas is offline Find More Posts by lttakas
Old Nov 24, 2003, 12:13 AM
Azygos is offline
Find More Posts by Azygos
United States, UT, Payson
Joined Mar 2003
Neat. I have done a foam glider conversion myself.
Specs?
What motor/battery/prop are you using, as well?
Chris
Azygos is offline Find More Posts by Azygos
Old Nov 24, 2003, 12:45 AM
kansascloud is offline
Find More Posts by kansascloud
Checking the wind
kansascloud's Avatar
Aubry Township, Kansas South of KC.
Joined Jan 2002
Me too!
I started working up one also. Mine has a balsa fuse but I'm using a foam wing from a cheap toy glider. I've cut it down to 38". Power will be an IPS A. Stay tuned for details and photos.
kansascloud is offline Find More Posts by kansascloud
Old Nov 24, 2003, 12:49 AM
Azygos is offline
Joined Mar 2003
Sorry to "take over your thread" but here are some pictures of my glider conversion:
The motor is an EDP 100.
Old Nov 24, 2003, 12:53 AM
Azygos is offline
Joined Mar 2003
Here is the oversized rudder.
The rudder used to be pull-pull so I had to have it this big to get any kind of reaction.
Now the rudder is push-pull (normal pushrod) and the elevator is pull-pull.
Old Nov 24, 2003, 12:57 AM
Azygos is offline
Joined Mar 2003
The polyhedral was self-added. I just cut a "V" into the foam, bent it up, added some glue, let it cure overnight, and spackled it. Before this was added (when it had a flat wing) it couldn't fly outdoors. Any little breath of wind would start it into a turn and it would slide right into the ground. Now it is soooo slow and is the most stable plane I have owned. I fly it in my backyard.
AMTJIM is offline
Find More Posts by AMTJIM
"Bible Thumper"
AMTJIM's Avatar
United States, AZ, Tucson
Joined Mar 2001
There are several threads on the 74 inch lanier U-2 and Condor in the foamies section, it's hard to beat for 20.00. If you cut the W/S down and remove the dihedral, also shorten the tail end of the fuse, it flies at decent speed with a 400 series GWS gear drive and KAN 1300 or 1050. Also the fuse is molded with a high angle of attack, leveling that out helps alot, it rolls and loops very well. The 2 bad weak spots are at the nose of the fuse and right behind the trailing edge of the wing.
AMTJIM is offline Find More Posts by AMTJIM
Old Nov 24, 2003, 05:40 AM
LuckyArmpit is offline
Find More Posts by LuckyArmpit
Rehab is for quitters
LuckyArmpit's Avatar
West Middlesex, PA, US
Joined Jun 2001
$20???? I did this one for $3.84....
Dave...
LuckyArmpit is offline Find More Posts by LuckyArmpit
Old Nov 24, 2003, 10:22 AM
lttakas is offline
owings mills MD
Joined Feb 2003
yeah i know that 20$ is alot but that air plane can take ALOT of weight si it means i can put lots of batts in it ans fly for a long time.(-:
Old Nov 24, 2003, 10:40 AM
lttakas is offline
owings mills MD
Joined Feb 2003
here is my giant
http://rcgroups.com/gallery/data/500/15289u-2-med.JPG
http://rcgroups.com/gallery/data/500..._gears-med.JPG
Old Nov 24, 2003, 10:41 AM
lttakas is offline
owings mills MD
Joined Feb 2003
oh yeah and another thing all the metal tape m i alowed to do that can i have problems with it because there is so much foil on it could i get in trouble by air space????????????????
Old Nov 24, 2003, 11:47 AM
AMTJIM is offline
"Bible Thumper"
AMTJIM's Avatar
Joined Mar 2001
Here's my last one, it had a few initial problems, but flew very well after a little more tweaking.
Sold Super Tigre 90S 2 stroke engine - Made In Italy - Price REDUCED Bill2005 Aircraft - Fuel - Engines and Accessories (FS/W) 1 Feb 02, 2007 05:17 PM
My BN-2 burst into flames in mid-air!!! blakbird Parkflyers 15 Sep 06, 2003 01:31 PM
