Old Sep 27, 2012, 11:23 PM
vfrank59 is offline
Find More Posts by vfrank59
vfrank59's Avatar
Joined Jan 2007
Clarence,
Thanks for the welcome. i will take photos along the way. You guys yell if ya see me building something wrong!
Vern
vfrank59 is offline Find More Posts by vfrank59
Old Sep 28, 2012, 05:44 PM
onethermal is offline
Find More Posts by onethermal
LSF # 7390 IV
onethermal's Avatar
Sandy, Utah
Well I got some more time today to work on Oculus #22 the covering is basically done it is coming time for the final items in the fuse and get the rudder hinged.
I sure like the green and white it shows up good against the sky.
it won't be too long before I start on My E-Oculus
Clarence
onethermal is offline Find More Posts by onethermal
Old Sep 28, 2012, 05:52 PM
tailsld is offline
Find More Posts by tailsld
United States, NY, Hamburg
Joined Aug 2011
wow C... the green looks awesome
Rick
tailsld is offline Find More Posts by tailsld
Old Sep 28, 2012, 08:42 PM
jcstalls is offline
Find More Posts by jcstalls
Dragons, WindMills, all Same
jcstalls's Avatar
United States, IN, Indianapolis
Joined May 2002
Yes, Awesome.
Sorry, forgot, which covering did you chose?
Jared
jcstalls is offline Find More Posts by jcstalls
Old Sep 29, 2012, 05:16 AM
LSF # 7390 IV
onethermal's Avatar
Sandy, Utah
Jared
Ultrakote.
Clarence
Old Sep 29, 2012, 03:33 PM
Mr B.... is offline
Find More Posts by Mr B....
Mfg of the Marauder & Oculus!
Mr B....'s Avatar
Downey, CA
Joined Aug 2002
After doing a few lay ups for the E-Oculus I have found the right lay up formula. When I cut the opening under the wing mount and with out the servo mount in the canopy area I found that the fuse was not stiff enough. Thinking of what to do with out adding weight. I remembered that I had some glass tow. One strand of 12K glass tow under the last layer in the lay up. It was laid in from the nose under the canopy opening back under the wing mount in the corners to the TE. It's almost like running a stringer along the insides. The Elevator servo mount is now under the wing with the Rudder servo is in front of the tail post. It did make a difference in the end.
Merrill
Mr B.... is offline Find More Posts by Mr B....
Old Sep 30, 2012, 08:28 PM
Mr B.... is offline
Mr B....'s Avatar
Downey, CA
Joined Aug 2002
All flight testing is complete and now it's time to go fly a contest!
First contest for the new E-Oculus will be this Friday the 5th at noon in Visalia, CA.
Wish us luck.
Merrill
Old Sep 30, 2012, 08:56 PM
jcstalls is offline
jcstalls's Avatar
Joined May 2002
Yes, best of luck.
Jared
Old Oct 01, 2012, 11:30 AM
jcyr1 is offline
Find More Posts by jcyr1
United States, AZ, Surprise
Joined Jul 2002
Merrill,
What motor/prop combo did you end up with?? Also what was your cell count
and current draw? Good luck at Visalia!!!
John
jcyr1 is offline Find More Posts by jcyr1
Old Oct 01, 2012, 09:47 PM
Mr B.... is offline
Mr B....'s Avatar
Downey, CA
Joined Aug 2002
Bench testing from the other day.
This info is after peck start up.
1300mah 3c 65s
13X7 EMP prop
759 RPM
10.1 V
38 Amp
385 Watt
Same Battery
14X10 EMP prop
669 RPM
10.V
56 Amp
560 Watt
I went with the 13X7 prop for this Sundays test and everything went well. Climb was good, motor sounded better with no bog sound change on launch. It wanted to climb vertical.
Merrill
Old Oct 01, 2012, 09:50 PM
rev.iain is offline
Find More Posts by rev.iain
Mesa AZ, it's a dry heat!
USA, AZ, Mesa
New Fuse layup?
Hi Merril.
I just recieved an e-fuse for the Oculus which I got from my buddy Tim.
I was wondering if I have the new lay-up. It was shipped last week, (W/E Sept 29th)
By the way, Good Luck in Visalia. Wish I could be there. Next year I hope!
Iain
rev.iain is offline Find More Posts by rev.iain
Old Oct 01, 2012, 10:19 PM
LSF # 7390 IV
onethermal's Avatar
Sandy, Utah
Originally Posted by Mr B.... View Post
1300mah 3c 65s
Merrill
I think you meant to say 1300mah 3s 65 c
a 65s would be a motor melter
Clarence
Old Oct 01, 2012, 10:57 PM
Mr B.... is offline
Mr B....'s Avatar
Downey, CA
Joined Aug 2002
Originally Posted by rev.iain View Post
Hi Merril.
Iain
I think so what id the fuse # Look inside the canopy just under the rail and if has a one glass tow strand each side it's the new lay up.
Merrill
Old Oct 02, 2012, 01:57 PM
rev.iain is offline
USA, AZ, Mesa
Fuse Question
It is number 32 Merrill.
Iain
Old Oct 05, 2012, 08:03 PM
LSF # 7390 IV
onethermal's Avatar
Sandy, Utah
Merrill Brady with his Oculus finishes 8th place out of 34 pilots at the Fall Fest ALES Friday event.
Clarence
Build Log Oculus RES Build onethermal Thermal 1204 May 12, 2016 10:13 AM
Rant A mistake buying from CENTURY JET MFG!! Kmot Fuel Warbirds 81 Apr 27, 2016 02:56 AM
Discussion Good kit mfgs, dying breed? (non-ARF) UPDATE: active mfgs. listed! Wacky1 The Builders Workshop 26 Apr 27, 2012 02:42 PM
Question Search plan : Tri-Star from SIG mfg Zappi Electric Plane Talk 7 Apr 10, 2005 01:01 PM
TP2100 pack ruptured from MFG Darren Hintze Batteries and Chargers 2 Mar 29, 2004 10:58 AM
