Just incase the thread to follow is this one http://helifreak.com/showthread.php?t=459685
You will find all the info and a larger knowledge base if you have any questions
I was thinking that the bullet on the bullet blades is what makes the helicopter more stable, similar to the weights on a flybar. As the blades are spinning, the added weight at the bullets creates a centripetal force right there at the location of the bullets. Now this works similar to a bicycle wheel, if you take a bicycle wheel of lets say 3 feet in diameter and spin it, then try to rotate it you feel the opposition to your rotating it, now if you choose a wheel that is 4 feet in diameter, it's even harder to rotate, and of course a smaller wheel makes it easier, etc. So those bullets are creating the same effect as that wheel, with the centripetal force being located at the bullet, this opposes any movement to the helicopter, making it more stable. If the bullets were located farther out, it would be more stable, and closer in less stable, etc. I could be wrong, this was just how I was thinking it worked, hell, maybe we are both right!
Latest blog entry: My new Precision Aerobatics Katana MD
I think we're both right, the only thing is that there is zero weight in the bullets other then the weight of the plastic so saying the force made by them spinning is stabilizing is probably true. However, the weight difference is quite small so I think the bullets are actually causing drag on the blade making it swing back a little during rotation thus helping with the stability. Just a thought, from my flying with both blades I really prefer the lightweight ones verses the bullets, with the stock motor it's better for aerobatic flight.
Joined Oct 2007
I have a 40amp charger and unlike indoorheli, I charge most of my batteries in parallel and the charger does all of the calculations for me. I have never had any issues and every once in a while I charge them by themselves to insure proper balancing. The Powerlab does an excellent job at parallel charging and the batteries stay pretty balanced. For the nano 1S batteries, I set it up for a 2C charge at 300mah and it ask me how many batteries I am charging and it sets everything else up. I do not have to tell it how many cells or nothing because it already knows and it will make all of the calculations and charge up to 9 batteries at once. It was a little costly but man it is a great charger and you spend less time worrying about your batteries and more time flying! Plus charging in parallel, your charge times are dramatically decreased! BTW, I hardly ever charge above 2C. |
Say, I'm about to fly to Singapore this Friday, and I plan on bringing my Blade 130x, and Nano. And I was wondering if any of you have had experience with bringing lipo batteries on the plane? I've been doing some research about this on the web, and found that I should be ok if I wrap my batteries individually either with plastic or tape off the ends so that they can't short out, and to put them in a lipo bag, and bring as carry on.
I also had a friend tell me that he brought an extra laptop battery with him as carry on, and he had it in a lipo bag. And that the TSA screener told him that if he didn't have it in a lipo bag it would have been confiscated. Anyhow, just wanted to know if anyone has had a problem bringing their lipos with them on the plane. Thanks. |
) phone browsing...I have been charging parallel and series for years without issues but dont like series parallel due to balancing not being 100% all the time If you charged your series as larger series instead of parallel charging series packs you would not ever have to charge them by themselves to insure proper balancing. As each cell in the series would always be individually balanced Again this is why I do not parallel charge series packs
Paderborn DE
Latest blog entry: Turnigy dlux 80A HV: Soft Start and...
| Thread Tools | |
| Cool Walkera MiNi CP - Smallest 100 sized 3D helicopter | zadaw | Micro Helis | 5192 | Jun 13, 2013 11:46 AM |
| Discussion is there anything better than mcpx v2 at same or smaller size? | Legendary_Agent | 3D Electric Heli Flying | 33 | Feb 24, 2012 08:46 PM |
| Question What’s Better than a Blade CP and Smaller than a Trex? | HavingFun2002 | Micro Helis | 74 | Mar 05, 2006 05:07 PM |
