Old Oct 14, 2012, 11:06 AM
Scarface26 is offline
Find More Posts by Scarface26
Colorado Springs, CO.
Joined Mar 2009
The ad from HobbyKing referenced above is WRONG. There are 3 small battery connectors used in the E-Flite line of Ultra Micro planes and helis. Starting with the smallest connector is the UM (Ultra Micro) also known as a Pico connector. It is a 2 pin connector used in MSR/MCX/MCX2/nano CP X/ Champ/Vapor/UM T-28, etc.
The next larger connector is the JST-PH 2 pin. It is also sometimes shown as the JST-PH2 or a MCPX connector. This connector is used in the MCPX heli, and a few planes.
The largest of the 3 battery connectors is the JST-PH 3 pin. It is also sometimes shown as the JST-PH3 or a UMX connector. This connector is used in the UMX Beast plane.
Please note that I am only talking about the smaller connectors used by E-Flite/ Parkzone etc. The larger Deans/ EC3/ APP/EC5 and other connectors are better discussed in other threads. Connectors can be a very confusing topic.
Scarface26 is offline Find More Posts by Scarface26
Old Oct 14, 2012, 12:42 PM
Zoide is offline
Find More Posts by Zoide
Joined Feb 2008
Does the nCP X work with Walkera radios running the Deviation TX firmware?
Zoide is offline Find More Posts by Zoide
Old Oct 14, 2012, 12:47 PM
dimastep is offline
Find More Posts by dimastep
Joined Jul 2009
Guys, how long does a battery last if I am flying normal calm MCX-style, no 3D maneuvers?
dimastep is offline Find More Posts by dimastep
Old Oct 14, 2012, 01:00 PM
dway is offline
Find More Posts by dway
Joined Mar 2007
Once the battery and motors have a few runs on them, about 4 minutes or just over is what I am getting.
dway is offline Find More Posts by dway
Old Oct 14, 2012, 03:29 PM
dimastep is offline
Joined Jul 2009
Hm...not much
MCX can easily go twice that long.
Old Oct 14, 2012, 03:44 PM
turboparker is offline
Find More Posts by turboparker
Gopher huntin' stick jockey
turboparker's Avatar
Joined Jul 2009
The nCP X uses a Spektrum DSM2/DSMX receiver, just like all of the other Blade RTF & BNF birds. Check the Deviation website & forum to see what they say about compatibility. BTW - running firmware in a tx that alters the modulation scheme and/or RF output is illegal in most countries. I suggest checking to be sure that the firmware is legal in your country. For instance - in the US, it is a very serious violation (felony) of FCC rules to make non-FCC type-accepted modifications to any transmitter.
Hm...not much
This is to be expected. The mCX has but a fraction of the power, a top-speed of only 2-3 MPH, and is incapable of aerobatics. The nCPX is a high-performance 3D heli.
Joel
turboparker is offline Find More Posts by turboparker
Old Oct 14, 2012, 04:00 PM
indoorheli is offline
Find More Posts by indoorheli
2 seconds from crashing
indoorheli's Avatar
United States, WA, Seattle
Joined Sep 2007
Hm...not much
My son can fly the Champ for about 15 minutes or more on a single 150mAh battery. It is actually quite amazing how long a battery lasts with it if you are mellow on the throttle...but just like the mcx you cant compare the two for power usage
I get about 3 minutes on the nano and I am quite happy with that for what I can do with it
indoorheli is offline Find More Posts by indoorheli
Old Oct 14, 2012, 04:09 PM
dimastep is offline
Joined Jul 2009
Joel
Yeah, I agree in 3D aerobatics mode. But if I were to fly it "like an old man" (for argument's sake), would it not last longer?
Old Oct 14, 2012, 04:10 PM
bwoollia is offline
Find More Posts by bwoollia
bwoollia's Avatar
United States, CO, Colorado Springs
Joined May 2008
The manual says 3 minutes for agressive flying, 4 minutes for milder flying.
bwoollia is offline Find More Posts by bwoollia
Site Sponsor
Latest blog entry: Crash Compilation
Old Oct 14, 2012, 04:30 PM
rcflyair is offline
Find More Posts by rcflyair
rcflyair's Avatar
United States, OK, Ada
Joined Jun 2007
lol. If you get a 160mah battery and fly like an old man, you could probably push 5 or 6 minutes.
Please don't ask me how I know that......
rcflyair is offline Find More Posts by rcflyair
Old Oct 14, 2012, 04:46 PM
Joined Jul 2009
It does last longer. 3 minutes of aerobatics vs 4 minutes of sport-flying. But expecting the flight-time of a high-performance CP 3D heli (even when flown very conservatively) to be similar to that of a similar-weight, extremely low-performance FP coaxial bird when flown aggressively is similar to expecting the the gas mileage of a Ferrari F12berlinetta driven as if there were an egg under the gas pedal to be similar to that of, say, a Toyota Camry with a 4-banger when driven aggressively (the cars are of similar weight). However, things very rarely work out that way - due to differences in efficiency. For instance - the nCP X uses symmetrical blades, while the mCX uses undercambered blades. The mCX has a very low headspeed, while the nCP X has a much higher headspeed. Therefore, the nCP X requires more input power to the rotor just to hover & fly around, even though the birds weigh about the same.
Joel
Old Oct 14, 2012, 04:50 PM
shahram72 is offline
Find More Posts by shahram72
United States, SC, Irmo
Joined Sep 2011
I look at it this way when flying a CP heli. If I haven't crashed it in 4 minutes, it's time to put it down cause it's going to happen if I fly much longer. Plus that motor needs to cool for 5 minutes at that point anyway.
I went ahead and ordered mine and got off the fence. I figured I have wasted at lease this much money on junk that won't fly or won't fly well. I need to get something that flies nice. I'll just be hovering and flying circuits and practicing my coordinated turns so that by the time I actually get a 450 in the air, I'll have much better chances of keeping it in the air. Money well spent, plus I can take it everywhere.
shahram72 is offline Find More Posts by shahram72
Old Oct 14, 2012, 05:46 PM
Matt Ls Thumbs is offline
Find More Posts by Matt Ls Thumbs
Joined Aug 2012
Seven 001 silicone o-rings seem to help. I replaced the three black rings on the lower swash, and put an additional ring on each end of each link.
Matt Ls Thumbs is offline Find More Posts by Matt Ls Thumbs
Old Oct 14, 2012, 07:01 PM
queadlunnrau is offline
Find More Posts by queadlunnrau
Luck is my skill
queadlunnrau's Avatar
Joined Jun 2009
Hm...not much
If you have a computerized radio, you can experiment lowering the throttle curve and trying non semetrical blades ... but then why not just fly an msr or an mcx?
queadlunnrau is offline Find More Posts by queadlunnrau
Old Oct 14, 2012, 07:05 PM
dimastep is offline
Joined Jul 2009
Joel
That's actually a very good analogy and good explanation. Thanks!
Cool Walkera MiNi CP - Smallest 100 sized 3D helicopter zadaw Micro Helis 6139 Apr 16, 2016 11:21 PM
Discussion is there anything better than mcpx v2 at same or smaller size? Legendary_Agent 3D Electric Heli Flying 33 Feb 24, 2012 08:46 PM
Question Whatís Better than a Blade CP and Smaller than a Trex? HavingFun2002 Micro Helis 74 Mar 05, 2006 05:07 PM
