Old Oct 14, 2012, 12:50 AM
jabsten is offline
Find More Posts by jabsten
Can't get enough
jabsten's Avatar
United States, WA, Puyallup
Joined May 2010
Short 2 min video
I am flying my stock nano with stock lipo. Very stable and awesome for indoor 3D. I have 2 and go back to back. Thank you HH!
Bland nano (1 min 51 sec)
J
jabsten is offline Find More Posts by jabsten
Old Oct 14, 2012, 02:06 AM
Zoide is online now
Find More Posts by Zoide
Joined Feb 2008
How comparable is the difficulty of flying the nCP X vs that of the Ladybird? I'm especially interested in indoor flight.
Zoide is online now Find More Posts by Zoide
Old Oct 14, 2012, 03:04 AM
Nighthawk74 is offline
Find More Posts by Nighthawk74
RC addict? I'm not addicted...
Nighthawk74's Avatar
Danmark, Midtjylland, Roslev
Joined Jul 2011
Did you use hot melt? I have never had a HG joint come off[/QUOTE]
No I just grabbed the little kiddie safe HG gun, my son uses. It was on hand. Mine is harder to get at. Must find the time to clean out the basement...sometime.
Nighthawk74 is offline Find More Posts by Nighthawk74
Old Oct 14, 2012, 07:05 AM
erdnuckel2 is online now
Find More Posts by erdnuckel2
erdnuckel2's Avatar
Joined Mar 2009
I would say it is a very kind of flying ... not sure if it even should be compared. As far as flying a CP heli however, it is probably the best idea you can have to learn it ...
erdnuckel2 is online now Find More Posts by erdnuckel2
Old Oct 14, 2012, 07:15 AM
cfossa is offline
Find More Posts by cfossa
cfossa's Avatar
Stow, MA
Joined Mar 2002
Originally Posted by indoorheli View Post
I can flip the nano in my shower and even a little bit under a table..had to try
The mcpx Smallest area I could go was my bathroom.
The nano I can run into anything without worrying about damage.
So yes IMHO if you have a mcpx the nano is still well worth it but skill dependent you might have to still practice a bit with a pretend ceiling outside before flipping inside
Thanks! Sound like exactly what I "need" over the winter
Carl
cfossa is offline Find More Posts by cfossa
Old Oct 14, 2012, 07:16 AM
cfossa is offline
cfossa's Avatar
Stow, MA
Joined Mar 2002
Originally Posted by Matt Ls Thumbs View Post
Yes, it is that different. You can fly it indoors with a bit of practice. I do recommend outside first.
A few weeks with the Nano will help your mCPX skills too.
Thanks!
Carl
Old Oct 14, 2012, 07:48 AM
TurboCinqy is offline
Find More Posts by TurboCinqy
TurboCinqy's Avatar
Tiel, The Netherlands
Joined Apr 2007
Just installed Phoenix on my notebook.
Probably better for my nano to get more basics.
always hate the phoenix after a few minutes but it's the cheapest way to memorize stick inputs.
btw Why the didn't deliver a 230V supply for the charger.
Thought the Walkera 4#3 had the same connector but it didn't After about 15 charges the AAA batt died.
Tried to find a 6V adaptor but the one I had was nog stabilized and Almost thought I blew up my charger DMM gaved met 18Volts without load.
Centerhole was a bit bigger so probably I even didn't make contact with it.
Now it had rechargeable batteries. in it and I think it works.
TurboCinqy is offline Find More Posts by TurboCinqy
Old Oct 14, 2012, 08:05 AM
MrRcAddict is offline
Find More Posts by MrRcAddict
Joined Apr 2011
I don't think a cp heli can be compared to a quad. The quad is wayyy more stable. The only thing it may help prepare you for is orientation. However, the nano is probably the best and most crash resistant cp if you are just starting out.
MrRcAddict is offline Find More Posts by MrRcAddict
Old Oct 14, 2012, 08:19 AM
Number1BSArtist is offline
Find More Posts by Number1BSArtist
Don't tell me, I overdid it.
Number1BSArtist's Avatar
Joined Oct 2010
Man this thing is maybe a bit too awesome. It's definitely letting me get sloppy.
Tonight I had quite a few sessions of going crazy trying to even out the thrust by adjusting my pitch trim and then going nuts further by adjusting my pitch travel.
Much later, I finally noticed that I had broken the swash and the right arm was just hanging by a couple of strands of plastic. Still flew, upright/inverted, pitch pumps etc. until I noticed and replaced.
Just a reminder to check your stuff.
Number1BSArtist is offline Find More Posts by Number1BSArtist
Old Oct 14, 2012, 10:15 AM
shahram72 is offline
Find More Posts by shahram72
United States, SC, Irmo
Joined Sep 2011
Last time I emailed HH about a bad motor for my MQX they told me that there is no warranty on little brushed motors, so I ordered V929 motors to replace it with. They are cheap, well, not the Blade ones.
Anyway, I HAVE A QUESTION, I have my Nano ordered but need a charge cable. What kind of battery does this take? I have multi charge cable for 1 3.7 mini eflight connector like used in the UMX 1S planes. Does this use a different connector? Is this what I need?
http://www.hobbyking.com/hobbyking/s...dProduct=18867
It says for Mcpx but I always thought mcpx uses same tiny 1S connector as on UMX planes
shahram72 is offline Find More Posts by shahram72
Old Oct 14, 2012, 10:36 AM
rcflyair is offline
Find More Posts by rcflyair
rcflyair's Avatar
United States, OK, Ada
Joined Jun 2007
The mcpx connector looks the same, but its just a little bigger than the ones for 1S UMX planes.......
rcflyair is offline Find More Posts by rcflyair
Old Oct 14, 2012, 10:46 AM
Joined Sep 2011
OK, I how about the nano connector, same as mcpx? have charge cords for the tiny umx planes AND the above one on order.
Thanks for the info!
Old Oct 14, 2012, 10:49 AM
rcflyair is offline
rcflyair's Avatar
Joined Jun 2007
Ooops sorry. The nano cpx uses the smaller connector just like on the smaller one on UMX planes and the msrx...
Old Oct 14, 2012, 11:34 AM
dway is offline
Find More Posts by dway
Joined Mar 2007
I got one of these and really like it. It will do ncpx and mcpx batteries.
http://epbuddy.com/index.php?main_pa...roducts_id=347
dway is offline Find More Posts by dway
Old Oct 14, 2012, 11:50 AM
JLink125 is online now
Find More Posts by JLink125
JLink125's Avatar
United States, CA, Highland
Joined Mar 2009
Not sure if you can use this but here is the charge lead I made so that I could use my normal Lipo charger. All I did was simply open up the stock charger that comes with the Nano and remove the connector by clipping the wires at the board and soldering a deans ultra plug to the other end, really easy, the only down side is that I can't charge multiple packs at once but hey it's far better then the stock charger.
JLink125 is online now Find More Posts by JLink125
Cool Walkera MiNi CP - Smallest 100 sized 3D helicopter zadaw Micro Helis 6122 Feb 12, 2016 11:15 AM
Discussion is there anything better than mcpx v2 at same or smaller size? Legendary_Agent 3D Electric Heli Flying 33 Feb 24, 2012 09:46 PM
Question Whatís Better than a Blade CP and Smaller than a Trex? HavingFun2002 Micro Helis 74 Mar 05, 2006 06:07 PM
