Old Oct 13, 2012, 08:04 AM
Razors edge 29 is offline
Find More Posts by Razors edge 29
QuAd FaNaTiC
Razors edge 29's Avatar
Canada
Joined Aug 2009
No but i remember what it flew like
Seems to flip tighter now; that or i am getting better lol
Originally Posted by indoorheli View Post
Did you try a stock length solid boom before adding length?
Razors edge 29 is offline Find More Posts by Razors edge 29
Old Oct 13, 2012, 08:12 AM
indoorheli is offline
Find More Posts by indoorheli
2 seconds from crashing
indoorheli's Avatar
United States, WA, Seattle
Joined Sep 2007
I think you are getting better
Here is a vid I did yesterday of my stock, brushless and horrible Mad dog 180mAh 25c battery test (dont buy they are crap). I'll do a thrust test later today and then switch back to the 8T and do the same
Nano cpX stock and brushless flight (4 min 4 sec)
indoorheli is offline Find More Posts by indoorheli
Old Oct 13, 2012, 08:59 AM
Willyboy is offline
Find More Posts by Willyboy
Willyboy's Avatar
United States, CA, Tehachapi
Joined Sep 2007
Nice flying. What D/R were you using inside your office?
Bob
Willyboy is offline Find More Posts by Willyboy
Old Oct 13, 2012, 10:04 AM
scrape is offline
Find More Posts by scrape
Joined Mar 2006
Bob
+1
I'd like to know your radio setup too.
TIA
scrape is offline Find More Posts by scrape
Old Oct 13, 2012, 10:11 AM
noobiznessflying is offline
Find More Posts by noobiznessflying
Fly more, bitch less.
noobiznessflying's Avatar
United States, CA, Arcadia
Joined Nov 2010
...well finally after about 2 weeks I got my serviced nano back from hh. They fixed her right up and even replaced some of the parts I broke. She now flies like a champ with no issues and now back to more flyin!
Thanks again for the great kickass customer service at horizon hobby. I'll gladly spend more of my money on you guys.
peace bras
noobiznessflying is offline Find More Posts by noobiznessflying
Old Oct 13, 2012, 10:15 AM
indoorheli's Avatar
Joined Sep 2007
Bob
I was flying 100%R and 10%E all around with 100% pitch as well. Though I am going to up my expo on my elevator and rudder to 15% or so. I am a thumb flyer so for me horizontal interaction with vertical stick movement is amplified on this heli
Old Oct 13, 2012, 10:34 AM
JLink125 is offline
Find More Posts by JLink125
JLink125's Avatar
United States, CA, Highland
Joined Mar 2009
http://www.youtube.com/watch?v=ddByvJq-LSg
Thanks for the heads up on those Maddog batteries, I agree, no where near 25c. What do you guys think about the Thunder Powers? At first I was a little disapointed in the punch but after cycling a couple times it's getting noticibly better.
JLink125 is offline Find More Posts by JLink125
Old Oct 13, 2012, 10:37 AM
Torch8 is offline
Find More Posts by Torch8
Torch8's Avatar
NYC
Joined Aug 2010
Tail Adjustments
Using 100% D/R and 15% Expo on Elev/Aile. 100 D/R on Rudder and no Expo.
Idle-up pitch curve is Linear and Throttle cure is flat 100%
The tail doesn't hold that well, on hard left turns tail over swing to the right. What adjustments can I try?
This thing is very squirely, sometimes it'll overswing left/right
Torch8 is offline Find More Posts by Torch8
Old Oct 13, 2012, 10:40 AM
indoorheli's Avatar
Joined Sep 2007
If the tail doesnt hold well then you either have a bad motor, vibrations or a bent tail blade.
Old Oct 13, 2012, 10:41 AM
Teckos is offline
Find More Posts by Teckos
Teckos's Avatar
Joined Jan 2009
Nice flying indeed!
Unfortunately I can't fly anymore... Seems the main motor died
The motor sops every now and then when I throttle up and it even cuts the board off.
Has anyone tried to fix his motor yet?
Teckos is offline Find More Posts by Teckos
Old Oct 13, 2012, 11:25 AM
Deltaalphalima1 is offline
Find More Posts by Deltaalphalima1
Joined Sep 2012
Wow so good
Just flown mine for the first time
IT IS SO GOOD
Flys great but had to turn dual rates down to 23%
Tail hold is incredible
Over all great heli
Deltaalphalima1 is offline Find More Posts by Deltaalphalima1
Old Oct 13, 2012, 11:43 AM
brushless55 is offline
Find More Posts by brushless55
big ignore list
brushless55's Avatar
United States, CO, Longmont
Joined Nov 2011
Thank you for posting that side by side video
brushless55 is offline Find More Posts by brushless55
Old Oct 13, 2012, 01:33 PM
Willyboy is offline
Willyboy's Avatar
Joined Sep 2007
I am a thumb flyer also. I had to tighten the tension on both my horizontal sticks on my radio to the max and I find that helped me a lot. Left the vertical sticks soft. I am using 120 D/R no expo at the field. I was practicing inverted flying today and broke the tail boom on one of my birds . I will just replace it with 2mm solid CF like I did on the other one. Got a way to go before I can do indoor flying like you.
Bob
Old Oct 13, 2012, 02:16 PM
TurboCinqy is offline
Find More Posts by TurboCinqy
TurboCinqy's Avatar
Tiel, The Netherlands
Joined Apr 2007
Great flight.
I can barely fly circles in my room with it. Okť my room without any stuff is about 2.5m2 or i need to fly around tables, TV or hanging lights.
No good idea for now.
I almost never fly nose-in but this gives me an opportunity to get better with slow corners and nose in hovers.
Weather is terrible at the moment so Didn't try another loop.
And will try inverted flight soon. But not in my living room.
My goal is fly it whole winter to learn and fly my hk500 much better next season.
Got my new maingear on it. Hopefully this one lives longer. Ordered two but just got one and now they are out of stock :S
TurboCinqy is offline Find More Posts by TurboCinqy
Old Oct 13, 2012, 02:18 PM
AWDstylez is offline
Find More Posts by AWDstylez
Joined Aug 2012
Without digging through all 90+ pages of this thread, what other helicopters share the Nano skids?
Helidirect lists it as msr/msrx/nano, but I have an MSRX sitting right here and the skids absolutely do not fit, they're significantly longer between the mounting pins.
AWDstylez is offline Find More Posts by AWDstylez
Cool Walkera MiNi CP - Smallest 100 sized 3D helicopter zadaw Micro Helis 6160 May 20, 2016 04:10 PM
Discussion is there anything better than mcpx v2 at same or smaller size? Legendary_Agent 3D Electric Heli Flying 33 Feb 24, 2012 08:46 PM
Question Whatís Better than a Blade CP and Smaller than a Trex? HavingFun2002 Micro Helis 74 Mar 05, 2006 05:07 PM
