Old Sep 29, 2012, 09:37 PM
indoorheli is offline
Find More Posts by indoorheli
2 seconds from crashing
indoorheli's Avatar
United States, WA, Seattle
Joined Sep 2007
Originally Posted by turnerm View Post
I'm always confused as to how it's really expected that the factory nails zero pitch. I mean, do we really think they bind up a radio and center these servos on EVERY single model? Without having it bound there's really no way to ensure that the pushrods are physically calibrated right? Without being bound the servo can easily move with slight pressure...
Linear servos do not move under pressure the same way as regular servos and they naturally center them selves and hold center when you turn them off. Then there is the marks..if the marks are really intentionally there for zero pitch i see no reason why every heli shouldnt have perfect pitch out of the box. They are 0 for 2 on my heli's and probably 0-4 when i get the other 2 130x's on Monday
The servos they use for this heli have the same center pulse width and all cp helis are mechanically setup the same using a linear pitch curve with 0% at midstick. With these things you can setup 0 at midstick on any radio and it will be 0 at midstick on another as long as you have no trim, offset endpoints and a linear curve with 50%/0 pitch at midstick
I also do think they bind every single one to verify it functions and all the rtf's are prebound
indoorheli is offline Find More Posts by indoorheli
Old Sep 29, 2012, 09:54 PM
sideburn is offline
Find More Posts by sideburn
sideburn's Avatar
USA, CA, Cardiff-by-the-Sea
Joined Nov 2005
My main motor went out after maybe 50 fights.
I also just found out that the swash plate breaks.. and not the balls on the links but the rear swash arm itself broke where it connects to the center ring.
So far in the last 50 or so flights I have had:
• one tail motor bushing break and destroy the motor.
• 2 booms crack
• one main motor die
• one swash plate break
A little pricey but oh well..
sideburn is offline Find More Posts by sideburn
Old Sep 29, 2012, 09:57 PM
indoorheli's Avatar
Joined Sep 2007
an easy reinforcement/fix to the swash is epoxy or hot glue around the base of each arm.
You should stop using the stock booms and go solid..i beat the heli out of mine all day long and it shows no sign of wear.
Old Sep 29, 2012, 11:03 PM
Giovanni Day is offline
Find More Posts by Giovanni Day
Gettin back into it!!
Giovanni Day's Avatar
KY
Joined Apr 2002
• 2 booms crack
I have beat the crap out of mine as you can see in my video, but have yet to break anything but a pair of landing gear. I have noticed my main motor getting a little weak.
Giovanni Day is offline Find More Posts by Giovanni Day
Old Sep 29, 2012, 11:13 PM
Tony0007 is offline
Find More Posts by Tony0007
Joined Sep 2012
Throttle stick question
How much % of throttle stick travel are you supposed to have on the Nano RTF before it lifts off the ground?
With a centered throttle trim position mine requires between 70-80% before it will even lift off the ground.
Is there something wrong?
Tony0007 is offline Find More Posts by Tony0007
Razors edge 29 is offline
Find More Posts by Razors edge 29
QuAd FaNaTiC
Razors edge 29's Avatar
Canada
Joined Aug 2009
anyone else having issues with nano on dx6i and no throttle hold?
Razors edge 29 is offline Find More Posts by Razors edge 29
Old Sep 29, 2012, 11:14 PM
erdnuckel2 is offline
Find More Posts by erdnuckel2
erdnuckel2's Avatar
Joined Mar 2009
curious when the first aluminum swash will be released and who does it ...
Old Sep 29, 2012, 11:54 PM
Daryoon is online now
Find More Posts by Daryoon
Team WarpSquad
Daryoon's Avatar
United States, CA, San Diego
Joined Dec 2010
On the DX6i...you setting TH to 10 like the manual suggest?
Sharing my nCPX:
More photos/details:
http://www.hacksmods.com/2012/09/nano-cp-x-mtdr-canopy/
Daryoon is online now Find More Posts by Daryoon
Old Sep 30, 2012, 01:47 AM
sideburn is offline
sideburn's Avatar
Joined Nov 2005
Yeah, its weird. I haven't even crashed much.. but the few times I did I must have just hit the table etc just right to crack the boom. Not sure how I pulled off busting a swash arm. that's never happened to any of my helis before.
No bend spindles no busted skids.. Funny how that works out.
Yeah I have some solid carbon fiber left over form the mcpx days when I usedd a 2mm boom..
Ill probably start using a solid one after this one cracks.
tiguytrem is offline
Find More Posts by tiguytrem
tiguytrem
tiguytrem's Avatar
Canada, QC, Québec
Joined Jan 2012
Sharing my nCPX:
Very nice!!
tiguytrem is offline Find More Posts by tiguytrem
Old Sep 30, 2012, 03:04 AM
Nighthawk74 is offline
Find More Posts by Nighthawk74
RC addict? I'm not addicted...
Nighthawk74's Avatar
Danmark, Midtjylland, Roslev
Joined Jul 2011
I fly mine with the dx6i, the older non dsmx version. No throttle hold issues yet. Did you double check your programming? Could be a bad 3in1? Apart from the bind issue, there have been no probs in my neck of the woods.
Nighthawk74 is offline Find More Posts by Nighthawk74
Old Sep 30, 2012, 07:09 AM
cale10 is offline
Find More Posts by cale10
3dizzle 4 lyfe
cale10's Avatar
United States, OH
Joined Jul 2011
older non dsmx version? it just came out!!!
cale10 is offline Find More Posts by cale10
Old Sep 30, 2012, 11:32 AM
indoorheli's Avatar
Joined Sep 2007
Older tx that isn't dsmx.
Maybe check to make sure your throttle hold is not inhibited in the systems menu
Old Sep 30, 2012, 11:43 AM
jasmine2501 is offline
Find More Posts by jasmine2501
Rocket Programmer
jasmine2501's Avatar
United States, AZ, Mesa
Joined Jul 2007
With my dx7 i am having binding trouble almost every time. It is inconvenient but it seems to work fine when it binds. Outside, it flies pretty good even staying solid with my funky flying. I like it so far
jasmine2501 is offline Find More Posts by jasmine2501
Old Sep 30, 2012, 12:22 PM
indoorheli's Avatar
Joined Sep 2007
Its weird these binding issues both of mine bind great (from two different stores states apart)
Cool Walkera MiNi CP - Smallest 100 sized 3D helicopter zadaw Micro Helis 6160 May 20, 2016 04:10 PM
Discussion is there anything better than mcpx v2 at same or smaller size? Legendary_Agent 3D Electric Heli Flying 33 Feb 24, 2012 08:46 PM
Question What’s Better than a Blade CP and Smaller than a Trex? HavingFun2002 Micro Helis 74 Mar 05, 2006 05:07 PM
