Old Sep 27, 2012, 07:50 PM
McMoron is offline
Find More Posts by McMoron
Joined Dec 2007
Had a look at my Celectra 4-port charger. It turns out the .3A rated charger is in fact only .24A (at least my copy from an mSR).
I decided to 'detune' two ports to .15A for 1C charging for better longevity and keep two channels in stock form as a 'fast charger'. Yes, I know the stock batteries are rated 3A, but it's only an indicator. The gentler you treat them, the longer and better they perform.
Originally Posted by Heli Pad View Post
Thanks, nice blog, but what's really needed is SHTF testing, that would be 3A or so. That's where the tail motor usually is starved and blows out.
McMoron is offline Find More Posts by McMoron
Old Sep 27, 2012, 07:56 PM
jabsten is offline
Find More Posts by jabsten
Can't get enough
jabsten's Avatar
United States, WA, Puyallup
Joined May 2010
I get tail wag on both mine but it flies fine. Don't know why...
J
jabsten is offline Find More Posts by jabsten
Old Sep 27, 2012, 07:58 PM
sideburn is offline
Find More Posts by sideburn
sideburn's Avatar
USA, CA, Cardiff-by-the-Sea
Joined Nov 2005
J
make sure theres no play in the blade grips.. tighten the spindle up until there is no play and then back off a little so they arent too tight. make sure theres no play but they dont bind either. That elimated all vibrations from mine. I dont have grommets on the plade grips either. But people are saying that helps.
sideburn is offline Find More Posts by sideburn
Old Sep 27, 2012, 09:17 PM
jabsten is offline
Can't get enough
jabsten's Avatar
Joined May 2010
I did tighten the grips but maybe too much.
J
Old Sep 27, 2012, 09:26 PM
indoorheli is offline
Find More Posts by indoorheli
2 seconds from crashing
indoorheli's Avatar
United States, WA, Seattle
Joined Sep 2007
I do the same as Sideburn, tighten all the way until they are snug and then back off until they move without resistance.
I notice the more times i bend my feathering shaft that the worse it bends the more the tail kicks in flight...lets me know when i need to straighten it again. I have straightened it so many times now it is like butter.
indoorheli is offline Find More Posts by indoorheli
Old Sep 27, 2012, 09:35 PM
d2tw4all is offline
Find More Posts by d2tw4all
United States, RI, Smithfield
Joined Dec 2011
Originally Posted by jasmine2501 View Post
My batteries must be really bad then - they still fly the plane just fine, and the mSR, but they are 150mAh Hyperion batteries, and the Nano just cuts out as soon as you put the pitch to it. Sometimes it will act like it's about to take off, but it just wobbles around. Funny thing is, I tried those first, while I was making my review video, and I thought... "wow, maybe this is the first broken Blade I've ever bought" but it was just the batteries, it flies great on the new ones. I fully expected a slightly used Hyperion 150 would be better than a new E-flite 160, but I guess not
I have 2 Hyperions, I think they are 160's not 150's, but they did the EXACT same thing as you describe, even when fully charged it will fall out of the sky as soon as you get off the ground, and act screwed up. ALL of my eflite 25C batteries that I used in my msrx work perfectly fine though. I think this bird doesn't like hyperions for some strange reason!
Tom
d2tw4all is offline Find More Posts by d2tw4all
Old Sep 27, 2012, 10:18 PM
asosestrom is offline
Find More Posts by asosestrom
United States, CA, Santa Rosa
Joined Mar 2011
My hyperions don't work either. Stock are much better, but my hyperions are older.
I know most people realty like them but I haven't been that impressed with the 1s hyps
asosestrom is offline Find More Posts by asosestrom
Old Sep 27, 2012, 10:48 PM
sirzeppu is online now
Find More Posts by sirzeppu
sirzeppu's Avatar
United States, TX, Kilgore
Joined Aug 2011
I don't think the connection locks as well to the Hyperion connector. It's noticeable on mine....less positive click when I connect the Hyperion. If the connection is not good, there will be voltage drop that may trigger the lvc.
sirzeppu is online now Find More Posts by sirzeppu
Old Sep 27, 2012, 10:57 PM
crvnation is offline
Find More Posts by crvnation
Joined Sep 2012
Weird. I use Hyperions on my BL mCP X and mSR X with no issues other than some of them seem to be getting a little tired, but I have a LOT of flights on them.
crvnation is offline Find More Posts by crvnation
Reply With Quote  (Disabled)
Old Sep 27, 2012, 11:02 PM
turbovector is offline
Find More Posts by turbovector
"Kneel before Zod!"
turbovector's Avatar
Tacoma, WA. USA
Joined Dec 2003
Just got mine in today. Waaaaay too twitchy for my first experience with a CP heli. I was thinking of 60% (or less) travel with 40% (or more) expo on the low rates to begin with. Also considering tweaking the pitch curve at the low end until I get used to flipping the t-hold switch as I seem to be planting it down hard when I get into trouble (mSR habit). Any thoughts or advice would be helpful, thanks.
turbovector is offline Find More Posts by turbovector
Old Sep 27, 2012, 11:14 PM
sideburn is offline
sideburn's Avatar
Joined Nov 2005
Did some flips in the kitchen (and out of camera view rolls and a ceiling landing)..
And even a side cabinet touch and go
Blade Nano CP X - Kitchen Flips (1 min 55 sec)
Old Sep 27, 2012, 11:15 PM
fastphil_v is online now
Find More Posts by fastphil_v
fastphil_v's Avatar
United States, TX, Lucas
Joined Feb 2012
Flew several packs this evening outside. Got some head shake again so tightened up the spindle nuts - problem solved. I guess thats why they put those tools in the bag! Lots of flips and rolls - big progress for me. Dropping the expo more every day...
So I brought out the V120D02S - wow forgot how fast that thing is (which side is the TH switch on again!) but I can now handle it better than ever. Flips and rolls with confidence though still not pretty. Point being that the nano is making me a better pilot and that is a big deal. Love this thing.
Btw, I haven't had another case of power loss since I discarded the one questionable battery I had.
fastphil_v is online now Find More Posts by fastphil_v
Old Sep 27, 2012, 11:19 PM
Aphro is offline
Find More Posts by Aphro
ChuckTseeker Super Fan
Aphro's Avatar
Joined Jan 2012
Ditto on loose spindle... checked mine before maiden and it was 3-4 turns loose
Aphro is offline Find More Posts by Aphro
Old Sep 27, 2012, 11:25 PM
indoorheli's Avatar
Joined Sep 2007
I would switch your pitch curve to 50-50-50-70-85 or something of the like. Should always keep 0 pitch at center for thumb memory so you don't learn more bad habits.
Get in the habit when you THINK you might loose it just hit throttle hold and dont lower the throttle stick
Old Sep 27, 2012, 11:26 PM
jabsten is offline
Can't get enough
jabsten's Avatar
Joined May 2010
I use more expo than I usually do on helis but keep DR at 100...Flips and rolls are awesome indoors.
J
Cool Walkera MiNi CP - Smallest 100 sized 3D helicopter zadaw Micro Helis 6160 May 20, 2016 04:10 PM
Discussion is there anything better than mcpx v2 at same or smaller size? Legendary_Agent 3D Electric Heli Flying 33 Feb 24, 2012 08:46 PM
Question Whatís Better than a Blade CP and Smaller than a Trex? HavingFun2002 Micro Helis 74 Mar 05, 2006 05:07 PM
