Old Sep 25, 2012, 02:41 PM
flowmotion is offline
Find More Posts by flowmotion
Joined Feb 2008
Get mine today....
Also designed a new landing skid in the TDR-style.
Hannes
flowmotion is offline Find More Posts by flowmotion
Old Sep 25, 2012, 02:46 PM
indoorheli is offline
Find More Posts by indoorheli
2 seconds from crashing
indoorheli's Avatar
United States, WA, Seattle
Joined Sep 2007
Originally Posted by TMO View Post
Yep. An easy way is unplug the heli with the transmitter on. All the bars will disappear.
Different brick but same concept: I've had my carbon cub so far out that only two bars were showing.
Are you sure it isnt false telemetry readings? My dx18 only shows a flat line where transmision lines should be....which indicates it is bound to an rx. Ill go look through the menu to check and make sure it works or not in just a few
indoorheli is offline Find More Posts by indoorheli
Old Sep 25, 2012, 03:02 PM
TMO is offline
TMO
Find More Posts by TMO
TMO
TMO's Avatar
Stonington, Ct.
Joined Nov 2001
Just tried it. Signal strength indicated by darkness of all the bars (i.e.: As I walked away, all the bars slowly faded/greyed until I just had the flat line at the limits of my range.)
Not quite the same as the AS6410NBL brick as I said earlier, but same idea.
TMO is offline Find More Posts by TMO
Old Sep 25, 2012, 03:09 PM
queadlunnrau is offline
Find More Posts by queadlunnrau
Luck is my skill
queadlunnrau's Avatar
Joined Jun 2009
Got back from my lunchtime maiden, wow she's everything I was hoping the mCPX would be, did some really tight flips and rolls, even backward loops are cake. I did manage to get 1 tail blow out in a backwards loop, but it's pretty gusty today and still held better than the V1 mCPX.
Still need to get used to the AS3X tho, seems like it's been turned way up for this bird, wierd seeing the heli correct it's self in wind gusts, gotta get used to trying not to manually correct.
I almost always sell my Blades after a month or so, but this one I can tell is a keeper! I havn't had a smile like this in a long time!
queadlunnrau is offline Find More Posts by queadlunnrau
Old Sep 25, 2012, 03:56 PM
jhroof is offline
Find More Posts by jhroof
Orlando, Fl
According to Andy from Horizon, this might just be true.
http://www.rcgroups.com/forums/showp...ostcount=19109
TMO, what was the limit of your range?
jhroof is offline Find More Posts by jhroof
Old Sep 25, 2012, 04:01 PM
grovey is offline
Find More Posts by grovey
Just wanna fly!
grovey's Avatar
United States, TX
Joined Apr 2008
My nCPX has been delivered, can't wait to get home and fly it!
Hopefully get some 3D flying going indoors too!
grovey is offline Find More Posts by grovey
Old Sep 25, 2012, 04:08 PM
sideburn is offline
Find More Posts by sideburn
sideburn's Avatar
USA, CA, Cardiff-by-the-Sea
Joined Nov 2005
tips: http://www.helifreak.com/showthread.php?t=455520
sideburn is offline Find More Posts by sideburn
Old Sep 25, 2012, 05:12 PM
PKM_Heliman is offline
Find More Posts by PKM_Heliman
United States, TX, Belton
Joined Sep 2009
Mine flies GR8 too! A bit of a problem at first with the 'bind'...but then I looked at the instructions (IKR, what r those for...)and it showed that when you release the bind switch to push the ruder all the way to the left, until it binds, this will let the receiver know that it is bound to a computer radio, instead of a DX4...
LOVE THIS LITTLE BIRD!!!
PKM_Heliman is offline Find More Posts by PKM_Heliman
Old Sep 25, 2012, 05:17 PM
dkfuji is offline
Find More Posts by dkfuji
RC Helis: My Healthy Obsession
The OC, California
Joined Feb 2007
Trying to practice flipping in my living room which of course resulted in a couple of wall banging moments. LOL. As a result, my first mod (other than using an 8t pinion on my outdoor one) was replacing the stock boom tube with a solid carbon rod. Much more durable.
dkfuji is offline Find More Posts by dkfuji
Old Sep 25, 2012, 05:32 PM
Daryoon is online now
Find More Posts by Daryoon
Team WarpSquad
Daryoon's Avatar
United States, CA, San Diego
Joined Dec 2010
You guys need to hide your latest purchase from your spouse?
Or do you like the sound of $1 canopies that's more durable than the stock?
Latest blog post on HacksMods.com details the answer to these questions.
Daryoon is online now Find More Posts by Daryoon
Old Sep 25, 2012, 05:33 PM
Team WarpSquad
Daryoon's Avatar
Joined Dec 2010
Thanks...but I remember you're suppose to push all the way to the right.
Old Sep 25, 2012, 05:38 PM
indoorheli's Avatar
Joined Sep 2007
I was forced to make that mod earlier as well I dont think it will break again being solid 2mm
What expo are you flying with at 100% rates? I had to up to 45 (AIL/ELE)just so it wasnt crazy twitchy..super responsive heli
Old Sep 25, 2012, 05:51 PM
Maddog20 is offline
Find More Posts by Maddog20
United States, OH, Mason
Joined Nov 2011
New out of the box, I noticed the blade tracking to be slightly off. Is this a concern or with heli this size it should have little effect on performance?
Maddog20 is offline Find More Posts by Maddog20
Old Sep 25, 2012, 06:02 PM
indoorheli's Avatar
Joined Sep 2007
Blade tracking would be off either because you do not have 0 pitch at center stick or the blades are bent/off balanced.
My bet would be not 0 at midstick...but if they are bent or off balance you will get the shakes
Old Sep 25, 2012, 06:25 PM
sideburn is offline
sideburn's Avatar
Joined Nov 2005
mine is also off by a tiny bit but it doesnt seem to effect anything.
But why would them not being 0 at midstick have anything to do with tracking?
Cool Walkera MiNi CP - Smallest 100 sized 3D helicopter zadaw Micro Helis 6160 May 20, 2016 04:10 PM
Discussion is there anything better than mcpx v2 at same or smaller size? Legendary_Agent 3D Electric Heli Flying 33 Feb 24, 2012 08:46 PM
Question Whatís Better than a Blade CP and Smaller than a Trex? HavingFun2002 Micro Helis 74 Mar 05, 2006 05:07 PM
