Old Sep 25, 2012, 10:21 AM
J_skaggs is offline
Find More Posts by J_skaggs
United States, CA
Joined Jan 2012
Originally Posted by indoorheli View Post
I think stock is pretty tuff ..at least 40 plus crashes on mine
yeah my wife hates the txt beeps..luckily my new on you can turn them off.
yeah it has vibes..I'll look into it today. Haven't notice it do anything to flight characteristics though.
I haven't even tried to fly scale yet but out of all my crashes the heli is looking good! I hit thold the moment I feel it going which always made the mcpx last and last
Mine also flies fine. I was able to reduce the tail vibs by playing with the tightness of the rotor blades and feathering shaft bolt tightness. I'm going to replace the feathering shaft if I can get my hands on one. If not, I may buy another nano as a backup.
J_skaggs is offline Find More Posts by J_skaggs
Old Sep 25, 2012, 10:59 AM
indoorheli is offline
Find More Posts by indoorheli
2 seconds from crashing
indoorheli's Avatar
United States, WA, Seattle
Joined Sep 2007
Originally Posted by erdnuckel2 View Post
We are BOTH talking about the skids, right?
Also, can you use the mCPX batteries on your nano? the point of these skids is that U CAN!!
Yep same skids...while I dont think they are the best looking they seem to be quite durable..if you crash well
I am not too concerned about using double mAh batteries on this micro, if i wanted a high disk loading I would buy another mcpx. Instead I would like to go the opposite way to keep this as light as I can so it flies well inside and walls and floors dont hurt it too much.
Originally Posted by RoboHeli View Post
LOL. This guy makes good looking stuff. I couldn't find an english translation for the site though. Or is it pretty obvious when trying to order something that you don't need it? (Haven't tried yet obviously...)
Use google chrome it will auto translate
indoorheli is offline Find More Posts by indoorheli
Old Sep 25, 2012, 11:06 AM
indoorheli's Avatar
Joined Sep 2007
I havent messed with anything other than pitch yet but I did think the blades for how light they are seemed quite loose
Old Sep 25, 2012, 11:18 AM
Daryoon is online now
Find More Posts by Daryoon
Team WarpSquad
Daryoon's Avatar
United States, CA, San Diego
Joined Dec 2010
I've heard of people putting on mCPX skids and apparently they fit. I'll have a look as to what other skids we can possibly put on.
Check your feathering shaft if you have vibration issues. Either it's bent, or the nut has worked itself loose.
It's suggest you put a dab of white glue or rubber cement to help keep the nut in place.
Daryoon is online now Find More Posts by Daryoon
Old Sep 25, 2012, 11:19 AM
queadlunnrau is offline
Find More Posts by queadlunnrau
Luck is my skill
queadlunnrau's Avatar
Joined Jun 2009
UPS just brought me a smile!
WOW the BNF box is TINY
I normally hate yellow, but dayam this heli is SEXY!
Can't wait for lunch bwahahahahahahahahahahah
queadlunnrau is offline Find More Posts by queadlunnrau
Old Sep 25, 2012, 11:29 AM
TMO is offline
TMO
Find More Posts by TMO
TMO
TMO's Avatar
Stonington, Ct.
Joined Nov 2001
Heads up- those bars on the upper left corner are signal strength- just like a cell phone. AFAIK that's the only telemetry function.
Originally Posted by jhroof View Post
Does the same thing on the 130X.
TMO is offline Find More Posts by TMO
Old Sep 25, 2012, 11:35 AM
rcflyair is offline
Find More Posts by rcflyair
rcflyair's Avatar
United States, OK, Ada
Joined Jun 2007
Anyone heard anything about when parts availablity will loosen up?
rcflyair is offline Find More Posts by rcflyair
Old Sep 25, 2012, 12:40 PM
indoorheli's Avatar
Joined Sep 2007
Well I guess I spoke too soon about breaking something
I had a feeling when i was doing speed passes through the ladder, it wasnt the best idea
Well on tail boom down and moving to solid until i get another one
Old Sep 25, 2012, 01:02 PM
jhroof is offline
Find More Posts by jhroof
Orlando, Fl
Mine is at the LHS with my name on it. I'll pick it up after work.
jhroof is offline Find More Posts by jhroof
Old Sep 25, 2012, 01:05 PM
jhroof is offline
Orlando, Fl
So, you are saying the receiver signal strength telemetry works? Have you checked it?
Old Sep 25, 2012, 01:40 PM
d2tw4all is offline
Find More Posts by d2tw4all
United States, RI, Smithfield
Joined Dec 2011
Just got back from the LHS, they got them in this morning. Luckily I set everything up right there in the store, first one out of the box had a lot of negative pitch at the center point, went to adjust the links and found that the balls on the swash on 2/3 servos were bend upwards at about a 30 degree angle. Pretty sure that's where the negative pitch was coming from. Opened another one and bound it, zero degrees at center stick and the balls are all straight out at 45 degrees level with the swash. Keep an eye on this if you are buying one, you can see pretty easily if the balls are straight or angled up just by looking at the swash!
Tom
d2tw4all is offline Find More Posts by d2tw4all
Old Sep 25, 2012, 01:41 PM
d2tw4all is offline
Joined Dec 2011
Even with pitch at zero at midpoint, this still doesn't feel like it has a ton of power when doing pitch pumps. What are others finding? Not sure how they do tic toc etc. with this little pitch authority...
Tom
Old Sep 25, 2012, 02:24 PM
TMO is offline
TMO
TMO
TMO's Avatar
Stonington, Ct.
Joined Nov 2001
Yep. An easy way is unplug the heli with the transmitter on. All the bars will disappear.
Different brick but same concept: I've had my carbon cub so far out that only two bars were showing.
Old Sep 25, 2012, 02:28 PM
asosestrom is offline
Find More Posts by asosestrom
United States, CA, Santa Rosa
Joined Mar 2011
Tom
The motor needs to break in. Mine got stronger after about 15-20 short flights.
asosestrom is offline Find More Posts by asosestrom
Old Sep 25, 2012, 02:31 PM
d2tw4all is offline
Joined Dec 2011
AH ok this one has only seen 2 flights and I was wondering. Thanks!
Tom
Cool Walkera MiNi CP - Smallest 100 sized 3D helicopter zadaw Micro Helis 6160 May 20, 2016 04:10 PM
Discussion is there anything better than mcpx v2 at same or smaller size? Legendary_Agent 3D Electric Heli Flying 33 Feb 24, 2012 08:46 PM
Question Whatís Better than a Blade CP and Smaller than a Trex? HavingFun2002 Micro Helis 74 Mar 05, 2006 05:07 PM
