Old Mar 02, 2013, 06:27 PM
J_skaggs is offline
Find More Posts by J_skaggs
United States, CA
Joined Jan 2012
Originally Posted by Billz_01 View Post
STOP Finguz, it's your main gear.
I recently purchased a new main gear and found this same problem, put the old one back on and bam, problem gone. Went back and replaced it at my LHS and it was perfect, just like my old one but not worn out.
Grab yourself a new main gear, again. Clean any crud off of your pinion gear before installing, and you should be fine.
Good luck.
+1. I bought two new main gears because, the old gear fit too loose and both new gears were out of round. I put the old gear back on and the rotor assembly rotated smooth without the ratcheting effect.
J_skaggs is offline Find More Posts by J_skaggs
Old Mar 02, 2013, 07:14 PM
Greg Head is offline
Find More Posts by Greg Head
Joined Aug 2012
Originally Posted by Greg Head View Post
I replace it because I have no idea how to straiten the little bugger. It is so small and in all but one case the bend is so slight that I would rather just spend the 5 bucks. I am kind of a noob so is there a trick to straitening and is there something else that would make my blades not track well. It wasn't a big problem until I went brushless, not when I go idle up hi I can see the blades tracking terribly and the tail won't stay put. My sport setting is idle up with lower head speed and it flies fine but flip the switch and the tail is terrible and I can see the blades not tracking well. I assumed that blades not tracking = bent feathering shaft but is there something else I can adjust? I slapped some broken mcpx skids on it to put a bigger battery and that helped a lot, I figure the motor is pulling a lot of extra juice because the blades are dragging. I only have 3 mcpx batteries and like 6 nano batteries so would prefer to fix the blade tracking and use the right batteries. Plus I use the charging adapter to use the battery so I can't charger that type battery while I fly.
It was a cracked blade grip! I replaced several perfectly good parts trying to fix the blade tracking and it was a darn blade grip. Went to check feathering shaft and the grip split in two. Is this a common problem because i have been eying the cnc set.
Greg Head is offline Find More Posts by Greg Head
Old Mar 02, 2013, 07:34 PM
J_skaggs is offline
United States, CA
Joined Jan 2012
I don't think this is a common problem. I have nearly 350 flights on mine with many hard crashes. My blade grips are original.
Old Mar 02, 2013, 09:15 PM
Joined Aug 2012
you are answering my questions all over the place jskaggs. I was happy to finally find the problem, I got a mild kit on it and it was flying like crap and now I know why, flew awesome today I kind of like the bling of cnc blade grips but if they aren't a failure point I will probably just save the weight and my money.
while you are feeling helpful do you know where I can get a board fixed. My mqx board went up in a puff of smoke because of stripped wires in one of the booms. Just a fet, unplug that motor and everything works fine, plug that one in and it just runs even without bind. just like a blown fet I had on my nano tail. Someone mentioned a service or site that fixes boards but I don't remember what board it was on and can't find it with a quick search.
Old Mar 02, 2013, 09:51 PM
iTz Nicholas72 is offline
Find More Posts by iTz Nicholas72
Joined Nov 2010
Try www.megamicros.com
Wonder if my Nano was flying like crap because the blade was weakened and I never noticed it until it finally broke?
iTz Nicholas72 is offline Find More Posts by iTz Nicholas72
Old Mar 02, 2013, 09:55 PM
Joined Aug 2012
That's the link I remember seeing! A member here already pm'd me so I should be set. Thanks
Old Mar 03, 2013, 01:55 AM
Billz_01 is offline
Find More Posts by Billz_01
Billy
Australia, NSW, Newcastle
Joined Jun 2012
No worries Finguz, if your motor is rough then definitely replace it. I just checked my 3 old ones, my new one and my spare, they all spin smooth here.
I've broken a few blade grips, they aren't necessarily a failure point within normal crashes, but you land inverted on them and they will crack (at least that's how mine broke each time). I am yet to bling anything I own, but my 130x is about to receive a bit of tail bling due to weak stock parts. Nano will be getting a swash plate at the same time I'm thinking, as I've broken 3 of them so far. Add that to my airtime skids and solid tail boom and she should be indestructible, well aside from canop posts and main motors lol.
Billz_01 is offline Find More Posts by Billz_01
Old Mar 03, 2013, 02:20 AM
finguz is offline
Find More Posts by finguz
finguz's Avatar
United States, CA, San Diego
Joined Mar 2012
Horizon is sending me a new motor to try, so we'll see.
I thought about a microheli (or something cnc) swash when the time comes to replace it. I've read here it works great.
Yeah I wish there was a different setup other than the stock canopy posts. On my mcpxthey broke all the time. I could get a cf frame for $$. Tarotrc makes a mcpx one for $30... no nano one yet though. I'll probably pretty much keep mine stock too.
finguz is offline Find More Posts by finguz
Old Mar 03, 2013, 06:53 AM
Petrie is offline
Find More Posts by Petrie
United States, AR, Lockesburg
Joined Feb 2012
Originally Posted by heritageflyer View Post
Wow! Just had the first solid test flight on the new G-Force 160/30C batt with the Linyx Blades and MH Alum. Blue Swash.
Awesome! Restored my Fun!
NO Tailwag period!. I think it's the better Bearings in the Swash. They sound better. I have not even lubed them yet. More Stable and Precise!
IWinter is more tolerable when you have a nicely flying Nano....
Do you have a Brushless kit installed?
Petrie is offline Find More Posts by Petrie
Old Mar 03, 2013, 10:07 AM
danford1 is offline
Find More Posts by danford1
Innovator
danford1's Avatar
United States, MI, White Lake
Joined May 2011
Does your nano hover hands off ?
Does a stock Nano hover hands off?
I have one and it won't hover hands off. It seems I constantly have to give it some sort of input from the sticks. I'm trying to determine if my swash needs a linkage adjustment or perhaps replacement.
I bought the Nano used so I don't know if it ever hovered hands off when new...
Is there an easy way to set the swash level without buying an expensive tool?
Thanks in advance.
Danford1
danford1 is offline Find More Posts by danford1
Old Mar 03, 2013, 10:26 AM
jasmine2501 is offline
Find More Posts by jasmine2501
Rocket Programmer
jasmine2501's Avatar
United States, AZ, Mesa
Joined Jul 2007
It should, yes... but it won't stay in one spot. It will hold attitude, but a helicopter holding attitude doesn't hover in one spot. You need cyclic correction to hold in one spot. In the video flight test, I do show hands-off behavior, so if your heli is doing this, it's ok. If it's not holding this well, then maybe you have a trim problem, the gyro didn't initialize right, or you need to adjust the links.
Flight test starts about 7:15
Blade Nano CPX Consumer Review and Flight Test (12 min 33 sec)
jasmine2501 is offline Find More Posts by jasmine2501
Old Mar 03, 2013, 10:27 AM
J_skaggs is offline
United States, CA
Joined Jan 2012
Thanks in advance.
Danford1
If set up correctly, they will hover hands off for a few seconds before they start to drift based on my experience.
Old Mar 03, 2013, 10:34 AM
heritageflyer is offline
Find More Posts by heritageflyer
Time to Fly AJ's Best!
heritageflyer's Avatar
Hills of Eastern Ohio
Joined Nov 2008
+1, mine is very stable now, no wag but will still sit there and drift off different directions occasionally, whatever the air currents it is generating are doing, bouncing off furniture and surroundings. Unseen forces...
heritageflyer is offline Find More Posts by heritageflyer
Old Mar 03, 2013, 10:48 AM
crashj is offline
Find More Posts by crashj
USA, MN, Redwood Falls
Joined May 2010
Can u fly a nano with a dx6i. Nano is 140 degree swah and dx6 is 120
crashj is offline Find More Posts by crashj
Old Mar 03, 2013, 11:25 AM
Palle_Plutt is offline
Find More Posts by Palle_Plutt
Kingdom of Sweden, Västra Götaland County, Lindome
Joined Jul 2011
Nano is internal mixing so its a single channel swash.
So it's working great with dx6i.
Palle_Plutt is offline Find More Posts by Palle_Plutt
Cool Walkera MiNi CP - Smallest 100 sized 3D helicopter zadaw Micro Helis 6160 May 20, 2016 04:10 PM
Discussion is there anything better than mcpx v2 at same or smaller size? Legendary_Agent 3D Electric Heli Flying 33 Feb 24, 2012 08:46 PM
Question What’s Better than a Blade CP and Smaller than a Trex? HavingFun2002 Micro Helis 74 Mar 05, 2006 05:07 PM
